Tacoma 2016 - Piston Knocking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ciscom, Jul 12, 2016.
  1. Jul 12, 2016 at 11:18 AM
    ciscom
    ciscom [OP] Active Member
    2nd Complaint I've got on my "new" truck.
    Piston knocking/slapping when the truck accelerates from around 1200RPM @40MPH.
    First things First: I'm using 91 to 93 oct Gas since day 1.
    It started doing it uphill, since the transmission shifts too soon, sometimes when going uphill the RPM's drop
    under 2000. When I step on the pedal to accelerate it . .. Piston knocking right away for a few seconds, then it stops. Whenever the truck goes under the 1200RPM and I need to accelerate again, it knocks. And I'm not confusing this sound with the valve sound (the sewing machine sound) that Toyota still saying that "it's normal". I know what piston knock/slap is and that sound can't be confused. At first I thought I was a casual thing, but it started to doing it even on the Highway.
    According to the advantages of an Atkinson Engine: piston knocking is virtually "impossible" or less likely to happen because of the Direct Injection system. When fuel injection happens inside the chamber it is supposed to cool it down to prevent pre-ignition due to overheating. I hope to got this right. Well, if it is not a matter of high temperatures at the combustion chamber, then could it be a too lean air/fuel mixture. And this could explain that hesitation feeling when accelerating/lugging the engine. We know now that there's an under power feeling due to the transmission shifting too soon to higher gears, but this might a stacking issue as well.
    Things I found weird....MPG. Frequently this truck is giving me more than 28MPG. That's weird. I mean, or something is f.ckd up, or the MPG calculations are wrong or the ECU just want to save fuel or run the truck with air only ?
    I took the truck to the dealer, and guess what ? They didn't find a thing and they've stated that my truck is on spec. I'm taking it back to the dealer again an try to contact Toyota corp. because this is something that needs to be addressed and fixed accordingly.
    I'm posting this complaint here because I haven't heard of this before and I really don't know if this is an isolated issue, but the truth is it is not acceptable on a new car.
    The hammer and DeadEyeWI like this.
  2. Jul 12, 2016 at 11:27 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    About 97.3% sure 2gr-fks is non interference engine. Havent seen a piston out of one, but doubt they are "high" compression pistons that could even hit valves. Does obviously have vvt, but highly doubt it could get so far off timing it would cause audible metal on metal slamming without setting a over/under advanced timing code
    Fenwick1993 and scottalot like this.
  3. Jul 12, 2016 at 11:45 AM
    brich999
    Bryan
    all tore up already
    Seems quite certain if you read OP
    Sorry long day and internet tech drive me silly sometimes. This is one of them. Dont hypothesize, we only have a little to go by, might as well use info provided right?
  4. Jul 12, 2016 at 11:59 AM
    ViOTeK
    ViOTeK New Member
    Dreaming of a 2017 TRD Pro :(
    If it's audible in the cabin, try and get a recording of it. Or take the go-pro off the dash and mount it under the hood. :)
  5. Jul 12, 2016 at 12:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If anyone wants to be a shit head to a new member, they will be removed from the site.
  6. Jul 12, 2016 at 12:03 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    take it to the dealer
  7. Jul 12, 2016 at 1:49 PM
    ciscom
    Hi guys,
    I forgot to say Hi, I'm new here! This is my first Tacoma, but not the first truck I owned. I've always wanted to buy a Tacoma since I rode a 2001's, but back then i couldn't afford it, not even a compact car.
    Anyways I've been reading a lot of threads from different forums and haven't seen anyone reporting a knocking problem, at least not for the 2016 Tacoma. I know about the ECU flash/update for a knocking issue for the 2015 one, a friend of mine were affected by this.
    I'm not an expert nor a mechanic, but working with cars since 12yrs, I think I know a couple of things. But with all these modern cars, now it is very difficult to diagnose an issue. Everything is done or monitored by the ECU. I really don't have the time, nor the proper tools to diagnose such a thing, and I have to rely this completely to the dealer. Anyways it is a new car, so if there's warranty, why bother right ? The only thing can do to make sure there is indeed an issue before having to struggle with the dealerhip. I said struggle, because we now that was this is going to be.
    But, getting back to the "knocking" issue. At first I thought it was the horrible valve pinging these trucks seems to have (I call it the sewing machine sound) that when you accelerate will scream for your soul, then my dad noticed it, my father and brother in law, and even my wife.
    I haven't record a video yet, but I friend just lend me his goPro, so I hope to post it soon. In the meantime the only thing I can do is to narrate the issue:
    I'm on the road, just plain flat road no hills. Engine Temp. 1/2 gauge. Coasting at 40MPH and around 1200RPM. As soon as I hit the gas, to let's say accelerate to 60MPH, I can hear the friggin' knocking for couple of seconds then it stops. If I'm going uphill, is the same thing. I first noticed at a hill, but after a few rides I concluded that it is whenever I had to step one the gas, and going from 1200RPMs to let's say 3000.
    For now this is all I can tell you guys about the issue. Maybe you can help me out to make sense of it, I mean I know is knocking, but could it be because of a timing issue, too lean mixture, ECU ?
    I mean as for the Atkinson engine, it couldn't be pre-ignition due to chamber overheating. At least this is all I can think of.
    What do you think ?
    BTW, forgive my english, since it is not my primary language.
    The hammer likes this.
  8. Jul 12, 2016 at 2:18 PM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    odd that you're getting that much MPG. I'm curious how this knock sound is. It makes it harder to diagnose with out a CEL going off or flashing. You said the knock eventually goes away after accelerating from 1200 RPM or anything under 2000 RPM. If you decelerate under 2k can the knock be heard when it gets under 2K RPM?
  9. Jul 12, 2016 at 5:10 PM
    BeaverNation
    BeaverNation Well-Known Member
    I've had this happen a couple of times when my truck was younger around 40 mph, hasn't happened in 5,000 miles, just shrugged it off
  10. Jul 12, 2016 at 8:17 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Take it to a Toyota service center
    End of story
  11. Jul 12, 2016 at 9:02 PM
    George1441
    George1441 Much happier
    George
    2016 Chevrolet Colorado Diesel
    I'm absolutely no gear head, but you mentioned the type of fuel you use. I believe they want us to use 87 fuel. Again no mechanic here, but could that have anything to do with it ?
    Pella, over60, kahanabob and 2 others like this.
  12. Jul 12, 2016 at 9:03 PM
    ciscom
    Yeah, I think that's the only thing I could do for now, that and keep you posted.
    Trippin, this happens only for a short period of time during acceleration. Im guessing this might be a too lean mixture, why ? This engine has 2 injection systems, Direct port and intake port injectors and the system change back and forward depending speeds. So it might be a problem with this on my truck. That's what Im guessing for now, at least thats what comes to my head.
    Anyways, lets see what they tell me on my next visit, which btw is next monday.
  13. Jul 12, 2016 at 9:05 PM
    ciscom
    Thats what the manual says, but at the dealership they've told me to use premium gas. Anyways the higher the octane the smoother your car will run.
    George1441[QUOTED] likes this.
  14. Jul 12, 2016 at 9:19 PM
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    This is not true.
  15. Jul 12, 2016 at 9:25 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    no, the higher the octane, the more money you will spend
    over60, Rownan, James_Bond and 14 others like this.
  16. Jul 12, 2016 at 9:56 PM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    OP....Post a video.....
  17. Jul 12, 2016 at 10:11 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    How cold is your truck when this happens. Is your truck up to temp. I ask this because pistons will knock/slap when they are cold until they get up to temp. then the heat causes them to expand allowing the piston to become larger causing everything to seat. Then the knock/slap should be eliminated.
  18. Jul 13, 2016 at 6:20 AM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    Use regular. The only thing premium does is burn cooler. This is not necessarily a good thing if it's not designed for your engine. Our 3.5 is designed to use regular unleaded. Also try driving with the etc button on. The truck likes to shift into the highest gear and lug around. With the button turned on this is virtually eliminated.
  19. Jul 13, 2016 at 6:29 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Has the motor oil level been verified? Could it be oil starvation? Not sure about the 2GR-FKS and whether it even possible, but low oil level or pressure can cause valve noise.
  20. Jul 13, 2016 at 6:42 AM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
    I would run 93 octane (if available) for a few tanks to see if it clears up.
    sounds like a classic example of spark knock @ throttle tip in
