Tacoma 4.0 vs Tundra 4.0
Discussion in 'Performance and Tuning' started by BIGGJERRYC, Aug 21, 2012.
  1. Aug 21, 2012 at 7:45 PM
    BIGGJERRYC
    BIGGJERRYC [OP] Well-Known Member
    Jerry
    Lansdale, PA
    2011 TRD Off Road DC 6spd
    Assuming the 4.0 in both the tundra and the tacoma are the same short block,
    Why does the tundra version have 35 more hp?
  2. Aug 21, 2012 at 7:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Different heads.
  3. Aug 21, 2012 at 8:27 PM
    BIGGJERRYC
    Jerry
    Lansdale, PA
    So are head swaps an option to add power?
    No intentions of doing this... Just curious
  4. Aug 21, 2012 at 8:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    A member recently transplanted a Tacoma engine into his Tundra, so it might be possible, but the intake and exhaust are different, air switching valves, and other parts of the emissions system.
    And since rated HP is RWHP, you may still not gain the full 35... the heads may or may not be responsible for the difference. Could also be in the trans, gearing... or even the ECU programming.
  5. Aug 21, 2012 at 8:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  6. Aug 22, 2012 at 5:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    '07-09 FJ is the same as the '05-11 Tacoma 1GR. So his would have to be the same, to make a direct swap.
    Also, side note. The all of the 1GR's that are NOT dual vvti are stronger than the new ones with dual vvti.
    They run less compression, and have a fully counterweighted crank versus the new ones which have less counterweights.
