Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Jul 15, 2017 at 2:36 PM
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    I posted this thread in the technical chat, but apparently that forum doesn't get much traffic. So here is the link
    https://www.tacomaworld.com/threads/2015-v6-hard-to-start-when-warm.500076/#post-15599452
    Basically the issue is, when my truck has warmed up from driving, and I let it sit for around an hour, it is hard to start. It will turn over fine, but won't start for about 5 seconds. Cold starting is fine, and if I start it after only shutting it off for a short period it does fine.
    So far I have:
    Installed new plugs, old ones looked good, but we're definitely worn down.
    Installed new air filter
    Had battery tested, and it was good
    Cleaned MAF
    Cleaned pcv, will replace it, but Napa didn't have in stock so had to order.
  2. Jul 15, 2017 at 2:38 PM
    Jake.A
    Jake.A Well-Known Member
    California
    2014 Tacoma TRD Sport
  3. Jul 15, 2017 at 2:41 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Lots of potential problem here.
    Cam/ crank position sensors
    Fuel pump
    Fuel pump relay
    And more
  4. Jul 15, 2017 at 3:58 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  5. Jul 15, 2017 at 4:36 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I am not intimately familiar with these beasts, however I have seen bad ECT and/or IAT sensors cause this on other engines--if either is defective the ECU does not know that the engine is "cold" and does not enrichen the start-up AFR. As others have suggested low fuel pressure, dirty injectors and fuel filter are also suspect candidates. Do not discount the CPS either they can get temperature dependently wonky...
    Radarninja likes this.
  6. Jul 15, 2017 at 4:52 PM
    Radarninja
    Northern California
    06 taco
    FWIW the IAT is with the mass air sensor not separate.
    The Ect "should" throw a check engine light. It's near fire wall and hard to spot.
    Let us know what you find
  7. Jul 15, 2017 at 5:53 PM
    Fike
    Not much so far
    Thanks for all the responses. I'm not throwing any codes, so I believe the ect is good, but I might just go ahead and replace it.
    I'm going to try to do a fuel pressure test sometime in the next week, and I'll update everyone on what comes from that
    Also, I'm going to try to resistance test the CPS sensors
  8. Jul 15, 2017 at 6:32 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm going through the EXACT same thing as you and it's driving me crazy. I haven't had the truck not start yet, but it's just really weird since I haven't thrown any codes/check engine light/etc. PLEASE post back if you figure this out!
    How many miles are on your truck by the way? I'm at 30k.
  9. Jul 15, 2017 at 6:37 PM
    Fike
    Not much so far
    I haven't had mine not start either. Just takes a while sometimes. But cranks right up when it's cold.
    My truck has 70k. I bought it about a month ago.
  10. Jul 15, 2017 at 6:40 PM
    Radarninja
    Northern California
    06 taco
    Funny. I have the same issue except it long starts when it has sat for a day or so. Not when warm. I should have time to change crank sensor next week.
    I'll let you know when mine stops the weirdness
  11. Jul 15, 2017 at 6:41 PM
    Fike
    Not much so far
    Please do. Do you have new sensors? Where did you get them and how much did they run you?
  12. Jul 15, 2017 at 6:46 PM
    Radarninja
    Northern California
    06 taco
    Yes I have everything I got it from rock auto using Denso OEM stuff. Changing the water pump so I'll just do the crank position sensor then.
    I've change the fuel pump,the fuel pressure regulator, the injectors, and the cam position sensor. I just change the fuel pump relay I'll let you know if that does anything.
    Bebop likes this.
  13. Jul 15, 2017 at 6:50 PM
    Fike
    Not much so far
    Damn, sounds like you covered all your bases
  14. Jul 15, 2017 at 6:55 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I would've done a little more diagnostics before throwing all those parts at it, but more power to you!!! Hopefully you have nailed it.
    daryl lict likes this.
  15. Jul 15, 2017 at 7:00 PM
    Radarninja
    Northern California
    06 taco
    Well 185k I figured parts were warranted anyhow.
    Also not sure exactly how to diagnose this mystery problem.
    Fuel pressure was good thought pump was flaky or leaky injector. What diagnostics would you recommend cuz I need the help
    boogie3478 likes this.
  16. Jul 15, 2017 at 7:05 PM
    Bebop
    Nick
    I would've started with duplicating the condition. Put a fuel pressure gauge to it and start with the key off then have a buddy turn the key on. I've seen fuel pressure regulators give a long crank symptom. If you got good fuel pressure as soon as you hit the key the pump and regulator are fine, if it's taking a long time to build chances are the regulator is fucked. If everything is all good. It's time to bust out the scanner and start checking crank sensor voltage.
    Radarninja[QUOTED] likes this.
  17. Jul 15, 2017 at 7:10 PM
    Radarninja
    Northern California
    06 taco
    I actually did not think about throwing a scanner and watching live data. Good idea. I'll see if mine does that. Parts weren't too pricey. I figure I've saved compared to a shop attempting fixing this.
  18. Jul 15, 2017 at 7:17 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I did this with a buddy's scanner and everything looked fine as far as the computer was concerned.
  19. Jul 16, 2017 at 11:51 AM
    Fike
    Not much so far
    Can anybody explain alittle better what you need to put a temporary fuel pressure gauge on? The parts in the link earlier didn't pull up anything on Google, and there isn't alot of info out there on adding the port.
    BTW, tacomaholic, I really enjoy your YouTube channel. I've been watching alot of your videos lately. Good work
  20. Jul 16, 2017 at 11:52 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Thanks man! Much appreciated! I just crossed 1,000 subscribers. :D
