Tacoma 4.0L mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SamSin, Sep 3, 2013.
  1. Feb 11, 2014 at 5:01 PM
    #101
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    That's good mileage. You drive a stick?
    Just caught your sig, so yes you do. my truck is new, so I am expecting it to be somewhat better a few months down the road. Speaking of cold, its cold here this winter, and I drive 14 km to work. Truck sits in the cold all day and then I drive home. I doubt my diff fluids even reach optimal temps. I'm aware t all plays a part. I have an ultragauge in a box and its too frickin cold to hook it up.
    Guys, I accept mileage for what it is. But I like FACTS, and I like to understand those facts. I plan to see how good I can do when I hook up the gauge. But I also intend to drive like a maniac for a couple of tanks. I want to see what my truck is capable of, at its best, and worst.
  2. Feb 11, 2014 at 5:37 PM
    #102
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    14 km is a problem especially if you need to warm up before hitting the road. I drive 10 miles, (17 km) but I don't spend more than a few seconds warming up and with a max mph of 50 I'll get to work between 26-30 depending. -4F and it will be 23-26, tomorrow should be 27F and I might get 29 mpg. Very few lights that I can time pretty well. A couple poorly timed (unskilled) stop lights and it could be 21-23.
  3. Feb 11, 2014 at 5:59 PM
    #103
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    i have found if you remove the secondary filter run under 2k rpm and put 93 octane you will get good milage even better if you can find a non eth gas station
  4. Feb 11, 2014 at 8:26 PM
    #104
    Sky King
    Sky King Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    My drive to and from work is about 20 miles each way. About 16 of that is interstate. I have about 2 miles at each end of non interstate. So the interstate portion is, depending on traffic, between 55 and 70. Fortunatey my morning commute is around 5:30 AM so not much traffic but the evening drive is not so clear.
    I don't let it sit and warm up for long. The question is the trade off. Sitting at idle just burns gas at ZERO mpg. I also understand that the engine/drive train is more efficient at normal operating temperature. So the question is at what time do you cut off the warm-up and start driving?
    We have been been experiencing abnormally cold temps this winter. A lot of single digit and teen temps in the morning.
  5. Feb 11, 2014 at 8:33 PM
    #105
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I'm sorry but that is amazingly good. I get 32 in a 2013 1.6L Hyundai Accent hatchback (my commuter). But I live in the People's republic of Retardifornia and they put ethanol in all their fucking gas.
  6. Feb 11, 2014 at 8:48 PM
    #106
    worthywads
    It's E10 around here, my best tanks were on E0, haven't had that in 5 years.
  7. Feb 11, 2014 at 9:05 PM
    #107
    ajw1986
    ajw1986 Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    14.5 - 15 MPG but i have a heavy foot and do a crapload of driving for my job, usually cruising at 100-130 km/h so about 2k rpm steady for an hour + at a time. Mind you it is a 4L and automatic, i'm scared to see what happens when my lift and new tires go on in a couple weeks
  8. Feb 12, 2014 at 2:36 AM
    #108
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    I'm testing a couple things now. I upped my tire pressure to 38 psi for this current tank. Next fill up I'm going to try a tank of premium. I THINK its ethanol free in Canada??
  9. Feb 12, 2014 at 2:47 AM
    #109
    Hot2na
    Hot2na Well-Known Member
    I average 20mpg in the warm months and 18-19 in the winter...(winter gas)
  10. Feb 12, 2014 at 7:15 AM
    #110
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    The cold and the effects it has on Lubricity and friction plays a bigger part then you can imagine. And that is Scientific/Engineering fact.
  11. Feb 12, 2014 at 7:18 AM
    #111
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    I do know that. I intend to change it all out to synthetic eventually.
  12. Feb 12, 2014 at 7:18 AM
    #112
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    V6 Auto? 2wd or 4wd? Long box or short box. Stock?
  13. Feb 12, 2014 at 8:38 AM
    #113
    13TRDsport
    13TRDsport Well-Known Member
    NE PA
    13 Access cab TRD Sport
    Aero Turbine 2525XL, K&N air filter, TRD Shift knob. Bilstein 5100's w\Eibach springs.
    im getting about 16 city with lots of hills and crappy PA roads...hahaha
  14. Feb 20, 2014 at 8:08 PM
    #114
    liftedf25099
    liftedf25099 Member
    tacoma double cab 4x4
    stock
    checked my mpg yesterday 22.6 i gained just a little by using non ethanol 93 octane cost more runs better smoother throttle smoother idle stock 265/60/17 tires 4x4 4.0 v6 mobile 1 extended life 15000 mile oil.. just changed from regular 5w30 mobile 1 ran it 10000 miles clean oil i drove a f250 diesel and used synthetic 10k in it and had 250000 miles taco has 90000 now purrs like a kitty
  15. Feb 17, 2015 at 12:22 PM
    #115
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    ^ lolwut?!!
    Is that Imperial gallons?
    Just gassed up again for 15.3mpg. Avg temp 20 degrees 30% 4wd 70% 2WD.
  16. Feb 17, 2015 at 12:37 PM
    #116
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Nice bump to a year old thread. :D
  17. Feb 17, 2015 at 1:11 PM
    #117
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Thread was started in 2013 and is still relevant.
  18. Feb 17, 2015 at 6:57 PM
    #118
    worthywads
    That was the last post by liftedf25099, who you called out about imperial gallons. Not relevant to him, he may drive slower than you.
  19. Feb 17, 2015 at 6:59 PM
    #119
    cstallings
    Arkansas
    Great
  20. Feb 17, 2015 at 7:32 PM
    #120
    tommyg29
    tommyg29 Well-Known Member
    South Miami, FL
    12 DCLB PreRunner Sport
    My 2012 DCLB trd sport gets about 16-17 with my regular driving using 87 octane. Ive done some experimenting and found that 93 octane gets me about 1mpg better across the board, but I have never got better than 18-19mpg on highway trips (75mph avg). The engine/tranny/aerodynamics of this vehicle are not made for great mileage.
    My fuelly listed below only shows my first year of fillups. Ive had it almost 3 years now and 48k miles since I bought new.
    If I had the patience to try hyper-miling for a fillup I doubt I would ever reach 20 mpgs. :(
