Tacoma 4x2 regeared to 4.56, Rear diff stuck in on position!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARoman83, Aug 22, 2020.
  1. Aug 22, 2020 at 3:47 PM
    ARoman83
    ARoman83 [OP] Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Hello TW,
    Just reaching out to see if anyone else has encountered this issue. I just got my Prerunner regeared from stock to 4.56 at a local offroad shop. While I was driving home I realized the rear diff lock was engaged. I tried disengaging it but nothing happens??? The shop is closed now and doesn't open until Monday, so I tried doing some troubleshooting which was futile! I will be taking back to the shop on Monday, but was wondering if anyone has encountered this and was succesful in disengaging the diff.
    Thanks in advance!
  2. Aug 22, 2020 at 6:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the E-locker light on?
  3. Aug 23, 2020 at 4:46 AM
    ARoman83
    Alex
    Wisco
    Only legal stuff
  4. Aug 23, 2020 at 4:59 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Sounds like it could be wired wrong. If the switch to the elocker is off and the locker is still engaged unplug the connector to the elocker and see if it releases. If it does then it is wired incorrectly.
    ARoman83[OP] likes this.
  5. Aug 23, 2020 at 5:03 AM
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Gonna give that a shot. Any possiblity that the teeth are misaligned? If I pull the actuator can I manually turn the internal teeth to try and "reset" or disengage the diff lock?
  6. Aug 23, 2020 at 5:10 AM
    MA_TACO
    Wesley Chapel, FL
    Is it a factory elocker? I'm not too familiar with the internals of those but if its anything like the front ADD with the sleeve then those teeth will eventually line up and lock in place. The same with unlocking. I just installed a Harrop elocker in my front diff which uses a magnet and ramping mechanism with pins that lock the sleeve to the other axle.
  7. Aug 23, 2020 at 5:21 AM
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Yes, it's a stock e-locker. I poped it out already and everything seems to be functioning, just not sure everything is lined up properly.
  8. Aug 23, 2020 at 5:42 AM
    MA_TACO
    Wesley Chapel, FL
    Definitely need to take it back and have them redo it
  9. Aug 23, 2020 at 12:18 PM
    ARoman83
    Alex
    Wisco
    Only legal stuff
    I got it working today. I pulled the actuator and adjusted the teeth inside the DIFF until it was disengaged and light went off in center cluster. It took me a couple of trys positioning the teeth just right to get it to go on and off appropratley, but I got it working. Super easy fix, however, still calling the shop tomorrow and complaining.
    MA_TACO and TnShooter like this.
  10. Aug 23, 2020 at 1:32 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Good job and thanks for the feedback!
    TnShooter and ARoman83[OP] like this.
