Tacoma 4x4 conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by D_Roy86, Aug 23, 2016.
  1. Aug 23, 2016 at 5:11 PM
    D_Roy86
    D_Roy86 [OP] Member
    Darrin
    2001 Toyota Tacoma Prerunner sr5 2wd
    Non yet
    Hello Tacoma World friends. I have a question that I am hoping that someone can help me with.
    I am collecting parts to convert my 2001 4cyl sr5 Prerunner 2wd to a 4x4. So far I bought the front differential/axel, both knuckles with manual locking hubs, and a 4x4 automatic transmission. I am looking for the correct transfer case for my automatic trans. I know that I need the j-shift with 2-hi, 2-low, 4-low and neutral gears but I want to make sure that I get the right one. Are the ones from a manual transmission interchangeable? Can I use one from a v6 4Runner? Is there a specific part number that I can use to find the correct tcase? Please help! Thank you!
  2. Aug 23, 2016 at 5:20 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yes! I used a auto tranny in my manual.
    ChadsPride and D_Roy86[OP] like this.
  3. Aug 23, 2016 at 6:30 PM
    NateGB
    NateGB Well-Known Member
    Nate
    Los Angeles, CA
    04 Tacoma
    Icons, uniball upper arms, ome leafs, bilstein 5100
    You'll want to look for a transfer case without an actuator on it. If there's no actuator that means it's the J shift type you're looking for. One from a 4 runner will work.
  4. Aug 23, 2016 at 6:36 PM
    D_Roy86
    D_Roy86 [OP] Member
    Darrin
    Non yet
    Hello NateGB,
    Thank you! Can I use a j-shift tcase from a v6 4Runner or Tacoma without the actuator?
    Also.. Thank you Anthony250f
  5. Aug 23, 2016 at 6:45 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  6. Aug 23, 2016 at 6:49 PM
    NateGB
    Nate
    Los Angeles, CA
    04 Tacoma
    To be honest, I can't remember if the 4 cyl and 6 cyl transmissions have the same spline count on the output shaft. I know the info is out there though. Just browse some google info and you'll be able to come up with it.
    D_Roy86[QUOTED][OP] likes this.
  7. Aug 23, 2016 at 6:54 PM
    jbreezin
    jbreezin Member
    Jay
    north califonia
    05 4.7l sport 4runner
    I purchase the 4Runner in 8/16 Interior Custom white leather interior seats and door panels.Total stereo system kenwood deck JL front, JL component speakers in rear, comp kicker 12 with a polk 5 channel amp. Sound incredible The must do's with new truck Change the oil to synthetic, change transmission filter and fluid. Change fluid in both diffs and transfer case. Suspension Sway a way RR 2.5 coilovers, Sway bar relocate, dif. Drop, camburg upper control arms, all new adjustable rear control arms, toy tec 2.5" HD coils, Fox 2.0 shocks rear. If i could do over Id of got the icon stage 5 kit Spent $4300. Icon stage 5 kit 4900 and way way better Wheels & tires 20" Rock star wheels with 33.12.5. 20 mt. Tires. De Mello single hoop front bumper 6 weeks out still. mid nov. Soon a 05 Tacoma custom grille
    I have a question off topic. I have a chance to get laid upper control arms and a front end of a sway way lift kit. From 08 Tacoma will those work on my 05 4 Runner
  8. Aug 23, 2016 at 7:08 PM
    anthony250f
    Anthony
    San Diego, CA
    Can't use one from a 4cyl different spline count
    D_Roy86[OP] likes this.
  9. Aug 23, 2016 at 7:37 PM
    D_Roy86
    D_Roy86 [OP] Member
    Darrin
    Non yet
    Thanks guys. Just did a lil research and the 2.7 4cyl has the 26 spline count and the automatic 4x4 trans came with the forward shift transfer case. The 3.4 6cyl has a 23 spline count with a top shift tcase.
    Thanks!!
  10. Aug 23, 2016 at 10:00 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I guess you have your reasons for buying parts a few at a time.
    So much easier to have the complete donor vehicle right there.
    So many little things you will find missing as you go.
    As long as you have no pressure and lots of time.
    ChadsPride likes this.
  11. Aug 24, 2016 at 4:03 AM
    D_Roy86
    D_Roy86 [OP] Member
    Darrin
    Non yet
    True if I found a donor car I would get it for sure.
  12. Aug 25, 2016 at 4:50 PM
    D_Roy86
    D_Roy86 [OP] Member
    Darrin
    Non yet
    Sorry 23- spline for the 4cyl
    26- spline for the 6
  13. Aug 28, 2016 at 2:22 PM
    erik530195
    erik530195 Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    Very curious to see how this turns out. How much do you think it will cost when its all done?
  14. Aug 28, 2016 at 3:03 PM
    jbreezin
    jbreezin Member
    Jay
    north califonia
    Me too. Price depends on where I draw the line. Use stock wheels"I don't want too" should be 4200 to 4500 depending on tires. Add 1 or 2 k with new wheels. Another 1200 to 2000 if bumper is added. And so on and so on.
    Finish price is probably something that will never be reached.
    List so far
    Sway a way 2.5 front coil overs and 2 rear shocks
    Camburg upper control arms
    Toytec 2.5 lift rear coils
    All new adjustable rear control arms
    Diff drop
    Shock rebuils kits
    Sway bar relocate. $2750
    And one bad ass 05 4runner. $5900
    With any luck it will arrive on Friday and be installed by Monday,but more likely the next weekend though
