Tacoma 4x4 questions
Discussion in 'New Members' started by rigger7, Jan 1, 2012.
  1. Jan 1, 2012 at 7:16 AM
    rigger7
    rigger7 [OP] New Member
    Plan getting a Tacoma in the spring to use as a daily driver and a firewood hauler.
    I'm undecided as to weather or not to get the V6 or the 4 cly Tacoma.
    I plan on sticking with the Extra cab as I might have to once and a while drive around my kids,but I do not want to sacrifice bed length.
    Suggestions?
    rigger7
  2. Jan 1, 2012 at 7:20 AM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    4 cyl/5spd - set of air ride airbags for when you haul wood. That's what worked for me. Just my opinion FWIW.
  3. Jan 1, 2012 at 7:20 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    if your gonna haul wood I would get the 6cyl.. more power and you wont be dissapointed..
  4. Jan 1, 2012 at 8:18 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
    '11 Taco 4x4 AC & '95 2wd PreTaco both 4Banger 5 Speeds.
    The '95 PreTaco is used just to haul firewood (1/4 to 1/2 cord at a time 12 times a year) with no problems.
    The '11 is my DD & for hitting the trails.
    4 cyl = power + better mpgs
    6 cyl = more power + less mpgs
    It's your choice.
  5. Jan 1, 2012 at 8:23 AM
    Brunes
    Brunes abides.
    Rotorhead
    DD would indicate 4banger. HOw much firewood do you haul and how often?? If it's a business or a weekly thing- Might find that a bit anemic/frustrating.
    If it's a load or two a year to keep the house warm-the 4 fly will do the job.
  6. Jan 1, 2012 at 6:50 PM
    rigger7
    The wood hauling would be done 4-6 times a year,heating the house,for the most part it would be daily driver and not a lot of highway.
  7. Jan 1, 2012 at 6:58 PM
    DeadWeasel
    DeadWeasel ಠ_ಠ
    Rex
    Portland, ME
    09 : 4x4 : 2.7L : 5spd
    32" BFG ATs, Removed 2nd air filter, Brighter Reverse Lights, ARE Cap, LED maps/dome, ScanGauge II, zXe headlights
    4x4 5spd 2.7L '09
    I love my 4banger taco. I hauled 600lbs of solar panels or batteries in it, 5 days a week, for 1.5 yrs with no problem.
    Do I envy the 4L tacos, sometimes. Do I need 4L for anything I do? Not really. Will I regret the 2.7L when I've attached 1000 lbs of plate bumpers, skid plates, rockers, etc? Maybe a little. :dancingbacon:
  8. Jan 1, 2012 at 6:59 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    the 2.7 4 banger will probably do fine for what you want. and with the 4x4 suspension you probably wont need airbags for the wood just as long as your leafs are fine and you dont plan on stacking it as high as possible. the guy i bought my truck from used it for exactly what you want to use yours for. he put about 5k on it a year, mostly driving around mccall and hauling fire wood and occasionally his 2 place snowmobile trailer. unless you get the double cab you wont lose bed space and you will have a 6ft bed.
  9. Jan 1, 2012 at 7:56 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    rigger7,
    I would suggest reading as many pertinant posts here as you can before deciding how to spec out your truck. Your reasons for the access cab are valid, kids. Few adults will like to ride far back there though. If you are looking at new, I caution you. Do not accept Dunlop Tires on your truck under any condition unless you are prepared to change underwear after every drive.
  10. Jan 1, 2012 at 9:50 PM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    My 2007 squatted too much for my liking when I loaded the bed with firewood just a little over level with the side rails. It did the same thing with my 600 lb ATV back there (to provide all the facts, my ATV was loaded aft with tailgate down--I didn't want to take out my tool box). Bought my truck used with 23K and was 2 months past eligibility for the leaf spring TSB. Air bags were a solution for me; I've had them on for 9 months --- no problems to this point. I like them because I can air them up for the occasions I carry a load, and air them down for DD commute.
    Might not be a factor on a newer truck ... I suggest hauling a load stock; if it squats too much for your liking, then it's an option to be considered. FWIW
  11. Jan 1, 2012 at 10:07 PM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    X2! Dunflops = FAIL (especially in rain :eek:)
