Tacoma 6 lug 4x4 BIG BRAKE KIT
Discussion in 'Performance and Tuning' started by socalgasking, Dec 13, 2011.
  1. Dec 13, 2011 at 10:01 AM
    socalgasking
    socalgasking [OP] Well-Known Member
    Ash
    San Diego
    Lifted Supercharged Tacoma 4x4 Crew Winch
    Road Armor bumpers, warn winch, toy tech 3" lift, XD rockstar wheels, all terrain tires. SUPERCHARGED, Exhaust intake
    My tacoma is lifted with larger tires, i also have front and rear ROAD ARMOR bumpers. The mods i have made have added some weight to my truck, the brakes dont feel as responsive as i would like (it could be that i went from a M3 with amazing brakes to a truck) does anyone have experience with TACOMA 6 LUG BIG BRAKE KITS?
    Any help is appreciated. Thanks!!
  2. Dec 13, 2011 at 10:08 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    SS brake lines, new pads and rotors. Good to go :thumbsup:
    To answer your question, personally I haven't seen a big brake kit for the 6 lug Tacoma.
  3. Dec 13, 2011 at 11:20 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I have seen it for the FJ and I would think that they would fit the taco if it fits the FJ.
  4. Dec 13, 2011 at 11:28 AM
    Pugga
    Massachusetts
    Even if you do find one that fits, I'd guess you'll spend well over $2,000 on a kit when you could spend under $500 replacing stock parts and have plenty of stopping power. The main brake components of the Tacoma are plenty strong enough, you just have to remove the swell from rubber hoses and get good pads/rotors. The calipers themselves are strong enough to stop the Taco even when armored up and on bigger wheels. Just my $0.02.
  5. Dec 13, 2011 at 4:07 PM
    socalgasking
    Ash
    San Diego
    What do you guys think of this?
    6 piston calipers bigger rotors and steel lines!!!
    Major stopping power, with a major price to go with it!!!
  6. Dec 13, 2011 at 4:07 PM
    socalgasking
    Ash
    San Diego
  7. Dec 14, 2011 at 1:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    The Stop Tech BBK, even though it is still a 4 Piston, does have a larger rotor. Thus more leverage for braking force. It is of aluminum design vs cast iron, and so it cools better as well. Then add in more brake pad surface area with better compound as well, and stainless braided lines, to reduce expansion of the rubber lines, so more consistent braking is available.
    Currently I am running the Rotora 6 piston BBK. I purchased it from www.tundraracing.com. with the drilled and slotted rotors it was $2500. Yes, I have a 6 lug, and 4x4.
    It is specific to the Tacoma. Rotora has 4, 6, & 8 piston versions available for the 6 lug Tacoma. I just didn't feel like spending an extra thousand for the 8 piston.
    Camel51 likes this.
  8. Dec 14, 2011 at 1:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Edit, I have the 355's.
  9. Dec 14, 2011 at 1:57 PM
    socalgasking
    Ash
    San Diego
    What do you think of them?
  10. Dec 14, 2011 at 2:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    Worth every penny!
  11. Dec 14, 2011 at 2:33 PM
    Adreenaleen
    Adreenaleen Active Member
    Texas
    Speedway Blue 4x4
    :eek::eek::eek: Sounds like a sweet set up. Any pics?
  12. Dec 15, 2011 at 8:22 AM
    atlista
    atlista Active Member
    I second that.
    Masshole_And_His_Taco likes this.
  13. Dec 15, 2011 at 8:37 AM
    Pugga
    Massachusetts
    Sounds like a great set up, I just can't see spending that kind of money on a brake upgrade. Also, I've heard several times that drilled and slotted rotors aren't great for off roading because stones and crap get in the slots and holes. Smoke 'em if you got 'em I guess :thumbsup:
  14. Dec 15, 2011 at 12:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    The smooth rotors are also an option. I just can't see putting really expensive aftermarket brakes on a vehicle that see the mud regularly.
  15. Dec 15, 2011 at 9:59 PM
    modsquad
    modsquad Well-Known Member
    Andrew
    Traverse City, MI
    '10 Taco 4x4
    The brakes are one area that (IMHO) is worth keeping stock except for a decent brake line extension.
  16. Dec 15, 2011 at 10:15 PM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    Sw13 toy tundra calipers and rotors is another option
    thereverend likes this.
  17. Dec 15, 2011 at 10:22 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
  18. Dec 15, 2011 at 11:07 PM
    modsquad
    Andrew
    Traverse City, MI
    '10 Taco 4x4
  19. Dec 16, 2011 at 7:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
  20. Dec 16, 2011 at 8:03 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    no way in hell i could drop 3 gs on brakes....
