Tacoma alignment specs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wanoyee, Mar 5, 2010.
  1. Mar 5, 2010 at 9:26 AM
    wanoyee
    wanoyee [OP] Member
    Sorry if this is posted in the wrong section... I did a search and couldn't find the info I needed about alignment specs for my Tacoma.
    I have a 2004 Tacoma Extended Cab SR5 with larger factory tire option (265/70-16), 4WD, suspension is factory spec, and would like to find a place where I can read the range of alignment specs for my make and model (unless you know it by heart!). Someone said that 0º for both tires but what is the range? Finding a good alignment shop is the hardest thing. I'm tired of people doing crappy half-done work.
  2. Mar 5, 2010 at 11:10 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    I am goign through this right now...
    The FSM (Factory Service Manual) has what you need. It can be a challenge to find info. When I get home, I will check the exact pages I grabbbed... http://www.tacomaworld.com/forum/1st-gen-tacomas/5696-2001-2004-tacoma-factory-service-manual.html
  3. Mar 5, 2010 at 11:34 AM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    the alignment machine should have the specs on it and ready! your right though finding a good alignment shop can be very hard. i would suggest the dealer(they see more taco's than anyone) or a good 4x4 shop. good luck.
  4. Mar 5, 2010 at 1:30 PM
    bivey
    bivey Well-Known Member
    Camber is 0.10 w/ tolerance of 0.75, caster is 2.03 w/ tolerance of 0.75, and toe is 0.03 w/ tolerance of 0.20
  5. Mar 7, 2010 at 10:20 PM
    wanoyee
    wanoyee [OP] Member
    Thanks! As for toe-in, is that .03º? With a tolerance of .20º?
