Tacoma and 4Runner E-locker 3rd ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Nov 12, 2009.
  1. Nov 12, 2009 at 8:07 AM
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    Question:
    I landed a 4runner elocker 3rd yesterday with 4.30s. Axle code is A04A from the door jam. The 4runner was an auto with 3.4L V6.
    I have a TRD Taco with elocker and 4.10 gears, axle code B03A.
    Can I "bolt on" this third to my Tacoma's elocker housing axle?
  2. Nov 12, 2009 at 9:34 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Yes - it should work 'as is'. Both your Tacoma TRD e-locker and the 4Runner e-locker are based on the same Toyota differential - the so-called 'V6 / Turbo' unit.
  3. Nov 12, 2009 at 9:38 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Enola: I'm confused on what makes you think 4.30 gears will work with the 4.10 in his truck
  4. Nov 12, 2009 at 9:38 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    he has a prerunner so no front diff ;)
  5. Nov 12, 2009 at 9:39 AM
    Dark Knight
    Jeff
    NC/SC
    didnt see that, stupid me. Apologies...
  6. Nov 12, 2009 at 10:05 AM
    El Taco
    STP MN
    well, the reason i asked this is because i'm thinking about going to 33s.
    yes, she's a Prerunner now but i'm going to do a 4x4 conversion.
    i'm also in the process of gathering parts to do a 4x4 conversion as well. i got a 4.10 front diff but if 4.30s are a good trade-off to run 33s (using factory gears without having to re-gear), then i might as well get 4.30s in the front as well...???
    what are your thoughts?
  7. Nov 12, 2009 at 10:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, match the gears upfront and back.
  8. Nov 12, 2009 at 5:34 PM
    El Taco
    STP MN
    anyone care to shed some light on this???
    running 33s with factory 4.30s??? good or bad??? thx.
  9. Nov 12, 2009 at 6:43 PM
    Dark Knight
    Jeff
    NC/SC
    I think you will be gtg with 4.30's and 3.4 v6 running 33's
  10. Nov 15, 2009 at 2:06 PM
    El Taco
    STP MN
    GREAT then!!!
