Tacoma Antenna Mast Tool
Discussion in 'New Members' started by CarolinasSenior, Mar 19, 2015.
  1. Mar 19, 2015 at 2:00 PM
    CarolinasSenior
    CarolinasSenior [OP] New Member
    2015 Prerunner V6 SR-5 Double CaBSHORTBED
    I bought my first Tacoma last October and read the manual a couple of times to familiarize myself after a lifetime of Silverados. Noted that the manual recommended removing the antenna before running the vehicle through a car wash. Didn't think anything more about that since I don't usually use carwashes until we got several snow storms. The local practice is to spray the roads with a brine solution prior to the storm. Again not an issue since I'm retired and don't go out until the roads are cleared and dry. Recently had to go out before the roads were clear and worried about the effect of the brine on the undercarriage. Toyota headquarters told me that the wrench should have been in the glovebox but could not tell me anything more than the fact that it was an 8mm wrench. The dealership told me (eventually) that they used the wrench to install the antenna mast and then tossed them BUT would order one for me for $6.95 + tax. I would have to drive to the dealership, pay for the item and then return when it arrived. No offer to replace at no charge. Found this forum on my own and one poster had a picture of the nylon wrench. Looks like I found a reliable source of information on my Tacoma. Thanks
  2. Mar 19, 2015 at 2:16 PM
    Joe D
    Joe D .
    Welcome to TW.
    I've NEVER removed or had problems with an antenna mast going through an automatic car was.
    The "wrench" is cheesy. You're not missing much though it's crappy of the dealer dispose of your wrench, admitting to it and then charging you for a replacement when the manual recommends its usage.
  3. Mar 19, 2015 at 4:30 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    The dealer confessed about the mistake they made in regards to the nylon wrench.Even with that being said i wouldn't pay for it!They should give it to you.
  4. Mar 20, 2015 at 6:59 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I just used a small crescent wrench.
    Read about the Toyota "wrench" on TW and started looking for it.
    Found a tiny plasticy thing in the folder with the manuals.
    Will probably continue to use a crescent wrench.
  5. Mar 20, 2015 at 7:11 AM
    jparf
    jparf blissfully biased
    Mechanicsburg, PA
    15 Silver Highlander Limited
    Dealer didn't include with mine either when they delivered. I called and they gave me one, no charge.
  6. Mar 20, 2015 at 7:15 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I remove my antenna every time though the auto wash. AutoBell around here removes antennas prior to pulling into the wash. Have heard of them snapping off inside there. removed it the first time with that plastic doodad wrench, now just hand tight, and unscrews easy when needed. Good thing about the plastic one is it wont scratch the black metal, but I wouldn't pay for one, they should give you one.
  7. Apr 29, 2015 at 6:42 AM
    Taco Yota Liker
    Taco Yota Liker Member
    Grayson
    Augusta, GA
    07 PreRunner SR5 TDR OffRoad
    Just FYI, be sure to take the antenna off before the wash... its not worth the pain of fixing the dent and replacing the antenna just to save a few seconds.
    If you can't tell, I'm speaking from experience.
  8. Apr 29, 2015 at 6:45 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    My antenna sits under my back seat collecting dust, I took it off and don't intend on using it
    carneasada likes this.
  9. Apr 29, 2015 at 9:03 AM
    TacoLand
    TacoLand Well-Known Member
    I'd tell the dealer to give you the wrench for the next mast they install since they just throw them away ;)
    BamZipPow likes this.
  10. Apr 29, 2015 at 9:17 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    my antenna wrench was in the compartments behind the back seats on my double cab.
  11. Apr 29, 2015 at 9:19 AM
    ODNAREM
    Ron
    Also yes you should remove it prior to the car wash because if there's no major damage done its going to at least get slightly bent or loosen up.
  12. Apr 29, 2015 at 10:57 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Wait they sell a special tool? LOL A small crescent wrench is my antenna tool.
  13. Apr 29, 2015 at 12:29 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Well it comes with it, mine was in the glove box but I guess it depends on where your dealer puts it
  14. Apr 29, 2015 at 12:37 PM
    mattgecko
    South San Jose, CA
    My dealer must have kept mine or I have yet to find it.
  15. Apr 29, 2015 at 12:41 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Lol it is like a prize in the cereal box
    mattgecko[QUOTED] likes this.
