Tacoma Audio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nathan S, Feb 21, 2024.
  1. Feb 21, 2024 at 9:39 PM
    Nathan S
    Nathan S [OP] New Member
    Nathan
    2021 Tacoma Sr5
    Hey everybody, looking to get some input on my Tacoma audio system. Currently have OEM Audio + speakers, Stock hu, JL VX600 amp w dsp, JL sub and sub amp. Doors have been sound deadened but not thrilled with the sound quality, highs are bright but a little muddy, DSP was tuned by me so that may be the issue lol. Since the Tacoma wiring doesn’t split the front 6x9’s and the tweeters into separate channels it makes it hard to tune. Should I run wires to separate the channels for the dsp? Or would other components sound better than the OEM audio stuff? Thanks
  2. Feb 21, 2024 at 9:43 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Get rid of the factory speakers and go aftermarket and you’ll be able to tell a huge difference even with the stock head unit.
  3. Feb 21, 2024 at 9:51 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    welcome!
    Lot's of info in the Audio & Video section too
    Stevie17 and Nathan S[OP] like this.
  4. Feb 21, 2024 at 9:53 PM
    Nathan S
    Nathan
    2021 Tacoma Sr5
    I have the upgrade speaker kit from OEM audio plus, fronts rears and tweeters, but I’m a little underwhelmed by the performance of them
    Stevie17 and Hotwheels85 like this.
  5. Feb 21, 2024 at 10:43 PM
    Stevie17
    Stevie
    Crossville, Alabama
    Sounds like you probably need to put them on an amp.
  6. Feb 21, 2024 at 11:25 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I only did the front doors, tweeters, and put in a 20 watt JVC head unit. I'm most impressed with the sound. Hell I can even hear the stock rear speakers.
  7. Feb 22, 2024 at 7:03 AM
    Cboody69
    Cboody69 Well-Known Member
    GA/SC
    ‘22 AG TRD Sport XP DCSB 4x4
    TRD Lift
    Maybe its just me, but I have been perfectly satisfied with my OEM sound system. I'm not saying there is not a difference or that it is great. I would just rather throw my money at other truck mods and accessories before I even considered changing speakers.
  8. Feb 22, 2024 at 7:50 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You might be the first person to say such a thing.
    cosmic65charlie likes this.
  9. Feb 22, 2024 at 7:55 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    I'll be the second :bored:
  10. Feb 22, 2024 at 8:03 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Turning off the ASL (automatic sound levelizer) in the headunit really improved the sound quality at lower volumes for my ears.
    I'm running higher end gear SQ type gear, recycled from 2 previous cars where they sounded fantastic, and it's meh in the Taco. I'm blaming the source.
  11. Feb 22, 2024 at 9:57 AM
    Cboody69
    GA/SC
    TRD Lift
    Revolutions gotta start somewhere. With one person person with a radical idea lol JK
  12. Feb 22, 2024 at 10:46 AM
    Gear Jamin Jamie
    Gear Jamin Jamie Well-Known Member
    Jamie
    Lacey, WA
    2022 Access Cab Sport MT Super White
    Gun safe, predator steps, rear bumper step
    I had a expensive aftermarket sound system in my Jeep Wrangler (awarded worst factory sound system ever). That was in 2005. My 22 access cab has lame sound and I have considered sound deadening and speakers. I don’t have room for a sub tho. Am I hearing it won’t make much a difference?
  13. Feb 22, 2024 at 5:58 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    change the head unit.
    garbage in/garbage out.
    the factory radio has a custom eq curve specifically developed to try to make the oem speakers sound better than they are. problem is, once you start tweaking the pieces installed, that eq no longer works as intended, and tends to make things worse, not better.
    definitely check out the audio section. lots of us doing everything from simple installs to overly complex full-active installs...
