Tacoma Baja Edition announced!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MountainDog, Sep 29, 2011.
  1. Sep 29, 2011 at 3:49 PM
    #61
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    The shock/spring setup...
  2. Sep 29, 2011 at 3:54 PM
    #62
    malander
    max
    01 limited trd 4x4
    because IFS cv axles are inherently weaker than solid axles. Also keep in mind a locked front while turning on ground that has too much traction can equal an exploded diff.
  3. Sep 29, 2011 at 4:53 PM
    #63
    tpr676
    tpr676 Well-Known Member
    Instead of window dressing how about a special edition with let's say heated mirrors rear disc brakes here's one, the newer 4.0 with a side order of six speed auto. Ya listening Toyota ??????
  4. Sep 29, 2011 at 4:57 PM
    #64
    abtacoma
    abtacoma Member
    Sean
    Alberta
    03 Xtra Cab TRD
    I wouldn't mind the heated mirrors and the new 4.0 but not a big fan of the rear disc brakes...
  5. Sep 29, 2011 at 5:01 PM
    #65
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    Asked above but can someone explain the added suspension travel in more depth? For a "baja" edition I would expect different UCAs LCAs coilovers... something. but it doesn't sound like they are adding any of that.
    If the front is lifted 2" from the factory I'm assuming the truck is level. I was a critic at first but I don't think this truck is necessarily marketed for the people on this site. It will be a great truck for the average guy who does not mod vehicles and wants a capable stock configuration.
  6. Sep 29, 2011 at 6:11 PM
    #66
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    "Baja" is just a played out marketing gimmick to get the less informed truck enthusiasts to buy a package and feel they have bought a competitive vehicle in the trucks respective class. For "baja" edition one SHOULD expect stock or optional long travel.
    You are correct that this truck is not meant to be marketed to the typical enthusiast you may run into on this site. IMHO this truck is another example proving that you can just build up a base model to be the full package, and have the price be less or the same when your done. Minus DHA/UPA, and lunar orbiting capabilities.
  7. Sep 29, 2011 at 6:23 PM
    #67
    malander
    max
    01 limited trd 4x4
    Looks like different shocks is how they gained more travel. Not sure where the ride height came from but it's all speculation right now.
  8. Sep 29, 2011 at 6:24 PM
    #68
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Didn't the OP say something about different springs?
  9. Sep 29, 2011 at 6:27 PM
    #69
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Yeah, I don't see how they are getting that extra travel. No shock/spring setup I know gives an extra inch of travel without UCA's. The front end would have to be completely different, wouldnt it?
  10. Sep 29, 2011 at 6:29 PM
    #70
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    doesn't look all that cool. I'd much rather get a normal tacoma and do an LT kit....
  11. Sep 29, 2011 at 6:30 PM
    #71
    Tacomanator
    Clam Slammer
    Southern Cali
    Ah, maybe...
  12. Sep 29, 2011 at 6:37 PM
    #72
    CUtigerfan
    South Carolina
    04 Base
    Has nothing to do with the "baja" edition but does the updated front bumper not bother anybody but me??? I can't get over it every time i see a new picture. It doesn't line up with the fender flare and for whatever reason it looks half-ass to me.
  13. Sep 29, 2011 at 6:42 PM
    #73
    Palooka
    Palooka Well-Known Member
    Brett
    Crescent Valley, BC
    09 TRD Sport
    I would drive the shiet out of that... although I do agree with what most people have said. The graphics on the side are gross. Did they play dirt3 while designing that?
  14. Sep 29, 2011 at 6:46 PM
    #74
    malander
    max
    01 limited trd 4x4
    "The front suspension has been upgraded to include Ø60mm piston Bilstein race shocks with TRD coil springs that feature a protective zinc plated body and a one inch increase in wheel travel"
    So they either have new trd springs designed specifically for this truck or the coil seat on the shock is ~1" taller to gain ride height than previous versions.
  15. Sep 29, 2011 at 6:50 PM
    #75
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    just a tad misleading
  16. Sep 29, 2011 at 6:54 PM
    #76
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    That's the best they could do? Not impressed...and the graphic's look terrible IMO
  17. Sep 29, 2011 at 6:55 PM
    #77
    ColtsTRD
    Scott
    AZ
    x2...I was expecting a extended travel c/o or like a LT of some sort...nope... probably just some 5100s or a spacer lol
  18. Sep 29, 2011 at 7:00 PM
    #78
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Took the words right out of my mouth.:rolleyes:
  19. Sep 29, 2011 at 7:14 PM
    #79
    malander
    max
    01 limited trd 4x4
    very good call
  20. Sep 29, 2011 at 7:22 PM
    #80
    malander
    max
    01 limited trd 4x4
    I probably shouldn't say this without knowing it for sure but I doubt that its 5100s or spacers
