Tacoma Best oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C4S7R0, Sep 14, 2016.
  1. Sep 14, 2016 at 6:34 PM
    C4S7R0
    C4S7R0 [OP] New Member
    2010 Tacoma TRD Sport 4x4 Dcab
    King shocks. Scorpio Mud tires
    Go
  2. Sep 14, 2016 at 6:37 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Oil is cheap. I'll buy synthetic and keep changing at 3-5k. I've got a truck sitting at the shop with a $2000+ bill now that it's full of sludge and making no oil pressure.
    excorcist likes this.
  3. Sep 14, 2016 at 6:41 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Oil threads tend to get stupid. I use Mobil 1 every 5000 miles. I do it myself so and oil change is around $30 for oem filter and Mobil 1.
    Aussiek2000 likes this.
  4. Sep 14, 2016 at 6:41 PM
    Goosed
    Goosed Well-Known Member
    07 DC TRDOR
    None
    Synthetic for sure. Spend a lot of time on bobistheoilguy.com and there is a lot of evidence that synth is the way to go with low SAP's. The best oil I have run across is Mobil One ESP. Not EP but ESP. It's a euro spec blend for Diesel engines but guys run them in direct injection WRX's to prevent carbon build up. The UOA's are coming back with little viscocity loss over 5k.
    Only issue is that it is not a resource conserving oil.
  5. Sep 14, 2016 at 6:43 PM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    I use gold cap 5w-30 Mobil 1 ... it may be pricey if you walk into advanced auto and pull of shelf... order it online and go pick it up, and normally they have 30% off your order ;)
  6. Sep 14, 2016 at 6:46 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I called toyota directly, their 'technical' help, and asked about oil change intervals with synthetic. They stated that by design, whether you use synthetic or conventional, to change at 5000 miles. So thats what I do, synthetic at 5000. I stick with the synthetic because it has better cold start lubrication over conventional. As in winter cold.
