Tacoma Blunder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mdean1107, Jul 28, 2023.
  1. Jul 29, 2023 at 4:07 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Happens to the best of us. I've done 99% of my own oil changes, and told my girlfriend I'd just change her Fit's oil in my garage instead of her taking it to the dealer. After grumbling about how the drain plug had a weird square-drive head(foreshadowing), i popped the drain plug and marvelled at how clean the oil looked. Then noticed how much it STANK. Then was horrified at the sudden realization that I drained the CVT a completely unknown amount. I went through all 5 stages of grief in 2 mins, followed by frustration that I couldn't just top it back off. Had to rent a uhaul dolly and tow it an hour and a half to the honda dealer for a refill, because sealed CVTs are picky and need special fittings/pumps that neither I nor nearby shops had.
    The different plug should have tipped me off. Total brainfart. As well as the fact that I was on the wrong side of the car. In my feeble defense, I've owned many vehicles, and none had been a transaxle in over a decade. Trans plugs are usually at least behind the front wheels lol.
    Also, never get CVT fluid on you. Holy shit, the smell. Took weeks to wash off and some of my tools still reek of it
    Blockhead likes this.
  2. Jul 29, 2023 at 4:25 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Because the bellhousing.
    amyracecar and Hayden334 like this.
  3. Jul 29, 2023 at 10:26 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Shit happens, especially if you've done something a million times.
    Another example (although less serious): this morning I dumped old coolant into my windshield washer fluid. Label your waste containers...
    Another oil change story: my girlfriend was interested in car stuff, so I was going to show her how easy an oil change is on the 4.0. I couldn't get the filter loose, and ended up mangling and basically beating it to death with some channel locks and a screw driver, and turned the whole thing into a two hour job.
    deanosaurus likes this.
  4. Jul 29, 2023 at 6:22 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Another plus of a fumoto valve: Once you install it, you know 100% you're draining the correct thing.
  5. Jul 29, 2023 at 7:59 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    How much does it stick out beyond the surrounding frame/plates?
  6. Jul 29, 2023 at 8:04 PM
    Kwm5067
    Kwm5067 Well-Known Member
    21' Cement DCSB TRD Off-Road
    I work in automotive and you wouldn't believe how many "trained" mechanics do this to people's cars. Recently had a pretty reputable shop drain 2 fluids out of a rear sport diff and only filled 1 back up.... $10,000 later car is back on the road.
    Steves104x4 likes this.
  7. Jul 29, 2023 at 8:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    and you still made it to Boise! Gotta love these trucks!
    OffroadToy likes this.
  8. Jul 29, 2023 at 10:29 PM
    Naveronski
    Fort Worth
    Mine is covered by a regular skid plate.
    tcjacado likes this.
  9. Jul 30, 2023 at 3:24 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Why would Toyota do that? They want you to ruin your truck, they don’t like DIY folks like us…
  10. Jul 30, 2023 at 5:38 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I did that once, and noticed the transmission slip after driving about 5 miles. Parked it. Got it towed to the dealership, and let them replace the transmission fluid. I felt so dumb, but it happened, because my mind was elsewhere when I "changed the oil". Lesson learned.
  11. Jul 30, 2023 at 9:23 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I don't know about the OEM skid, but mine's tucked in at least a half-inch above the aftermarket plate on mine.
  12. Jul 30, 2023 at 10:30 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WTF would they put the OIL Drain Plug on the transmission pan?
    Blockhead and OffroadToy like this.
  13. Jul 30, 2023 at 11:26 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just need to remember that "engine" oil drains out from under the engine... not in the middle of the truck. :facepalm:
    amyracecar, Jimmyh and tcjacado like this.
  14. Jul 30, 2023 at 11:35 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    Yeah, I wonder if people who have this issue crawl in from the side (behind the wheel) vs. the front. From the front, I can't see how you'd mix the two up.
    amyracecar likes this.
  15. Jul 30, 2023 at 11:46 AM
    #35
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    That's exactly it (for me). I always crawl under directly behind the front tire on the driver's side, and from that vantage point the first drain plug you see is the transmission. The oil drain pan is out of view, and further towards the front than expected. You have to pull yourself much further under and towards the front than you think should be needed.
    Having made the mistake, I always have to tell myself, "Nope, not that one. Keep going towards the engine, and you'll see it."
    David2431 likes this.
  16. Jul 30, 2023 at 12:05 PM
    #36
    OffroadToy
  17. Jul 30, 2023 at 12:28 PM
    #37
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I read these threads and understand THAT this sort of thing happens.
    I just dont understand HOW this sort of thing happens.
    amyracecar, Jimmyh and Kwikvette like this.
  18. Jul 30, 2023 at 12:34 PM
    #38
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    I don't feel as silly now - did that on my son's '95 Subaru Legacy years ago. It was still a bonehead move because before that I changed the oil on Subarus for years. I probably still have a Fram PH3593 filter in the garage.
    When I refilled the Subaru with transmission fluid, I had bottle (quart?) left over. Probably because it wasn't completely drained.
  19. Jul 30, 2023 at 12:41 PM
    #39
    Texmax
    Texmax Well-Known Member
    Randall
    Aubrey, Tx
    2017 SR5 4X4
    Glad your truck is ok. Check that dipstick next time.
  20. Jul 30, 2023 at 12:56 PM
    #40
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Or how about we all take notice that 1) Burnt motor oil doesnt come out red or 2) the motor doesnt have a bell housing hanging infront of it where you would normally see a radiator or 3) the motor doesnt have a tranfercase and/or drive shaft hanging directly off the back of it.
    I understand being in a hurry/stressed/rushed or even working in a place thats uncomfortable/unfamiliar but still.
    amyracecar and Kwikvette like this.
