Tacoma bounce by hitting the manhole/pathhole on the road.
Discussion in '1st Gen. Tacomas (1995-2004)' started by akrinar, Sep 18, 2018.
  1. Sep 20, 2018 at 3:33 PM
    #41
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm sure he could find some used Icons for $500 that he'd then have to spend another $300 to get rebuilt.
    Again, high end (used or not) coilovers are not what he "needs" to fix his issues. All he "needs" are non-warn out shocks. If he *wants* upgraded shocks, go King or Icon all the way.
  2. Sep 20, 2018 at 4:38 PM
    #42
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    True... but they don't need to be re-built all of the time.
    And, warn does not make shocks. Winches, yes.
  3. Sep 20, 2018 at 4:40 PM
    #43
    jbrandt
    Justin
    I'm just typing with my southern accent...
  4. Sep 20, 2018 at 4:45 PM
    #44
    Ritchie
    Cool... my son is in Tennessee and I struggle with that at times.
    Honestly, if the OP has the cash and wants to up-grade at the same time, I'm only suggesting he go for it.
    Plenty of OEM type stuff available from Rock Auto which I've used plenty of times.
  5. Sep 20, 2018 at 4:47 PM
    #45
    jbrandt
    Justin
    I was kidding, I'm from California... :D
  6. Sep 20, 2018 at 5:18 PM
    #46
    Ritchie
    Ahh, you got me.
    Is it hot up there?
  7. Sep 20, 2018 at 7:26 PM
    #47
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I'd bet 85% of the people with high end high dollar coil overs would be perfectly fine with an off the shelf oe replacement shock,but gottafit in with the interweb
  8. Sep 20, 2018 at 10:18 PM
    #48
    illbeda
    illbeda Well-Known Member
    You might think about checking lower and upper ball joints while your at it.Worn BJ's can make handling
    and braking do strange things.2 cents.
  9. Sep 21, 2018 at 5:49 AM
    #49
    Ritchie
    You have a point there, especially if mall crawling.
  10. Sep 22, 2018 at 7:00 AM
    #50
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Hey now, those speed bumps and rumble strips are brutal!
    Ritchie[QUOTED] likes this.
  11. Sep 25, 2018 at 3:32 AM
    #51
    akrinar
    akrinar [OP] Well-Known Member
    2002 Tacoma 2.7 - 4 cylinder - PreRunner
    Thanks all of you...
    I will update you guys once I figure out the problem.
  12. Sep 25, 2018 at 3:39 PM
    #52
    Taco302
    Greenbow, Alabama
    The curbs can be nasty too, but nothing is worse than the big, red Target ball.
