Tacoma brake questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaME, Mar 21, 2011.
  1. Mar 21, 2011 at 1:11 PM
    TacomaME
    TacomaME [OP] Member
    I have a 2008 Reg Cab Tacoma with the Certified Used Toyota vehicle warranty. I purchased the truck a state over and I cannot drive to the original place of purchase. I have a slight thumping kind of noise from one of my back wheels I think. (maybe brake?) Does anyone have the exploded view of this Tacoma Rear Drum Brakes that I could look at, or know what the thump, thump, thump, When I APPLY the Brakes could be? Are there any tricks to taking the drums off or anything I need to know before I go poking around.
  2. Mar 21, 2011 at 2:21 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    not sure exactly what size, i have had these bolts for years.
    but you put in these two bolts, and alternating back and forth
    between the two, you tighten them.
    which basically slides the drum off the brake pads.
    make sure you dont have your emergency brake on at the time
  3. Mar 22, 2011 at 3:25 AM
    TacomaME
    Thanks I will google the bolt size,
