Tacoma Brakes-All or Nothing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickDJ, Mar 1, 2011.
  1. Mar 1, 2011 at 6:05 AM
    RickDJ
    RickDJ [OP] New Member
    Rick
    Wisconsin
    2006 Toyotal Tacoma
    Hi,
    I am new to the forum...have a 2006 Tacoma Crew Cab
    I have read several postings regarding "mushy brakes"...but I seem to have the opposite problem. When I press down a couple inches on the brake, there is no gradual stopping power...then I hit a certain point...and the brakes nearly lock up. It is like "all or nothing".
    Is this common with Tacoma's, or is there a fix?
    Thanks
  2. Mar 1, 2011 at 6:30 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    how much life is left on your pads? does the truck pull to one side or the other when stopping?
    edit: welcome btw
  3. Mar 1, 2011 at 6:39 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Check pad wear first, then fluid level and quality.
    How many miles on them?
  4. Mar 1, 2011 at 8:59 AM
    RickDJ
    Rick
    Wisconsin
    2006 Toyotal Tacoma
    Thanks for the responses. I just purchased the truck, and it has 70000 miles...not sure if the brakes have been worked on. The truck does not pull to one side when stopping. I will check the wear on the brake pads as well as the adjustment on the rear drums.
  5. Mar 1, 2011 at 9:11 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    At 70,000 + miles you need to flush all the fluid out and get some good stuff in there.
    Brake fluid is one of the most neglected items on all vehicles
    Being in a higher humidity climate will also affect the fluid as it absorbs moisture from the air quicker.
    Start there and at least check the pads to see if they are worn too much or ???
  6. Mar 1, 2011 at 10:09 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I need to check my brakes as well, I have to apply quite a bit of pressure to get my truck to slow down and stop. So I probably need to flush my system with 64k miles on it.
  7. Mar 1, 2011 at 11:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you say...*nearly lock up* - is that enough for your ABS to come on?
    Here's something to try:
    While parked (engine running), step on the brakes pretty hard till the pedal bottoms out. Does the pedal 'stay there' or does it continue to creep down as you press on it?
  8. Mar 1, 2011 at 12:48 PM
    RickDJ
    Rick
    Wisconsin
    2006 Toyotal Tacoma
    Further explanation on "Nearly lock up"...
    I do not press hard enough for the ABS brakes to kick in. (I know they work because I drive in snow)
    The brakes just do not seem to have any "gradual" pressure...
    Based on other comments on this forum, I have pressed the brake pedal, then turned the key to the on position...and I then feel the pedal go further.
    I will also test as follows to see if the brake pedal continues to creep down:While parked (engine running), step on the brakes pretty hard till the pedal bottoms out.
  9. Mar 1, 2011 at 12:55 PM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    Same brake situation with my 2010 since new. At times with light braking you can feel the bite but many times it feels like nothing. There's barely any feel to the brake pedal that tells you it's grabbing. That is my major pet peeve with the truck. If your behind me, you will always notice the jerky stop.
    If anybody have a solution to this please share. In the mean time I just ordered some ebc brake pads and see if that gives me better brake feedback.
  10. Mar 1, 2011 at 1:06 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I've seen worn out front pads do this before. They just grab hard or not hard enough. Do they act the same when you heat the pads up as well? (ride the pedal for a short while).. Make sure the rears are adjusted close also, get them working sooner, rather than later when stopping. Changing the fluid can't hurt, but it sounds like something different to me.
  11. Mar 1, 2011 at 1:49 PM
    Janster
    Jandy
    Lancaster, PA
    This is normal..... That's the brake booster applying 'boost' (or assist) to the pedal.
