Tacoma Brakes Thumbs Down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jimp, Jun 5, 2021.
  1. Jun 6, 2021 at 6:26 PM
    #61
    RI_OR21
    RI_OR21 Well-Known Member
    RI
    21 TRD OR/DCLB Army Green (1st Taco)
    Really? Didn’t know that but I’m new to trucks and drums. I thought that was the entire reason for drums but after looking it up, clearly I was wrong haha.
  2. Jun 6, 2021 at 6:37 PM
    #62
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    weak rant. Brakes are fine.
    Junkhead, Hank Heel and tcjacado like this.
  3. Jun 6, 2021 at 6:43 PM
    #63
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Here, you dropped your tinfoil hat.
  4. Jun 6, 2021 at 7:19 PM
    #64
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Drum brakes ineffective???
    Consider the Semi-Tractors hauling 40 tons of goods loaded on a trailer. What type of brakes are on those trucks? DRUMS. Rear tractor wheels and on trailer wheels. Sorry, I'm not sure about the front wheels.
    The drums have enough force to lock up the wheels on these loaded trucks at highway speeds.
    Drum brakes are experienced technology that has been enhanced with the addition of ABS.
    Really, no need to change. I s'pose you could make a mod, but the gain would be small compared to the cost and effort.
    If you take a close look at vehicles with 4 wheel discs, then you will discover the rear discs are much smaller than the front discs. This should offer a clue as to where most of the braking force occurs.
    Junkhead likes this.
  5. Jun 6, 2021 at 7:25 PM
    #65
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Fronts are drum historically. Only in recent years have disk brakes become an option on class 8 semi trucks and trailers.
  6. Jun 6, 2021 at 7:27 PM
    #66
    Knute
    Thanks. My day is complete. I learned something. :thumbsup:
    gsubioguy likes this.
  7. Jun 6, 2021 at 7:31 PM
    #67
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    The brakes on the tacoma are kinda "weak" but thats just something you have to get used to.
    i came from a G37S with Huge rotors and 4 piston brake calipers on each corner in the front, along with steel braided lines. So after my g37, the tacoma did feel like it did have weak brakes. Butt it took about 4-6 months to get used to the pedal feel and travel. Its honestly fine. The truck always stops. you just have to get used to the "feel"
  8. Jun 6, 2021 at 7:42 PM
    #68
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    For a true weak brake experience try a 1970's Dodge pickup. Went well with the heater in those tin freezers.
    Lt. Dangle likes this.
  9. Jun 6, 2021 at 7:46 PM
    #69
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    And they won't get any cooling either.
    :facepalm:
  10. Jun 6, 2021 at 8:31 PM
    #70
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Don't give me ideas....
  11. Jun 6, 2021 at 8:39 PM
    #71
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    I know Chevy went four wheel disc on their trucks...and then back to drum....and now back to disc. Front brakes do most of the work anyway, but my truck doesn't seem to have any issues stopping. It really comes down to proper maintenance, rotor, drum, pad, and shoe choice than anything else.
  12. Jun 6, 2021 at 8:49 PM
    #72
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Drum brakes are self energizing so until they heat up to the point of brake fade they probably work better than discs.
    Also, if you are heating up your brakes to the point of brake fade, trade your license for a bus pass.
    JustJon and Vmax540 like this.
  13. Jun 7, 2021 at 1:12 AM
    #73
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    https://sosperformance.com/products...sion-with-parking-brake-fits-2005-2015-tacoma
    I just ordered this rear brake conversion kit since I already have the 6 piston fronts to match, I chose the master cylinder upgrade as well as the parking brake upgrade. I wasn't happy with the stock brakes either especially when towing or carrying heavy load with 2 passengers and the bigger calipers/rotors fill up the wheel space more for a cleaner look. Very noticeable braking performance increase and brake pedal feel, bled them with Motul DOT 5.1. Picture below of the fronts on 18x9 wheels, once I get the rears installed I'll update.
    jimp[QUOTED][OP] likes this.
  14. Jun 7, 2021 at 4:29 AM
    #74
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Ask, any full time mechanic that works on trucks driven in the north (rust) or in harsh conditions if drum or disc brakes on the back have fewer problems.
  15. Jun 7, 2021 at 4:44 AM
    #75
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Nothing beats drum brakes as emergency/parking brakes. The hoopty crap car/truck companies do to put little drum brakes inside disc brakes for parking brakes is truly staggering sometimes.
    Yeah they are boring, yeah they are old, but they work just like an old 1911a1 and I've yet to talk to someone who says they want to be shot in the chest with that ''old outdated'' round and pistol.
    Phlogiston likes this.
  16. Jun 7, 2021 at 4:48 PM
    #76
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Everyone is looking to the brake units. A big gain is to be made in the lines. Switch to all steel braided and see a big difference over rubber lines.
    Xplosiv likes this.
  17. Jun 7, 2021 at 5:22 PM
    #77
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    If you can lock the drums nearly immediately in a panic stop, brakes aren’t the problem. (Not directed at you specifically, but you reference a great point).
    Stickier rubber will help more than any brake upgrade in the world, unless you’re tracking or towing.
    You can change braking “feel” with lines and whatnot, but locking your brakes is effectively the ultimate test (for a street car). Once you get sticky enough rubber you can’t lock the brakes, that’s another story.
  18. Jun 7, 2021 at 6:49 PM
    #78
    Itchyfeet
    Itchyfeet Well-Known Member
    You must have not owned enough Toyotas with drum brakes. The rear bell-cranks are prone to seizing up and it's well known they're prone to getting stuck after being wet.
    The only reason Toyota uses them is because they're cheap and don't want to put anymore than they have to into R&D for the Tacoma. The money makers are cute utes like the Rav and Highlander for Karens and Rachels. I'll go out on a limb and say the Camry/Highlander R&D budget might be bigger than the Tacoma and the Tundra.
    I do find it funny that people complained about the Frontier being old as dirt, but the Tundra gets a free pass. Toyota is just as much asleep as Nissan when it comes to life cycles
    jimp[OP] likes this.
  19. Jun 7, 2021 at 6:57 PM
    #79
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol full of shitpost. I love ya man but not when you go full send on wrong.
    Vmax540 and Junkhead like this.
  20. Jun 7, 2021 at 7:05 PM
    #80
    Itchyfeet
    The truth hurts, let's call the 3rd gen what it really is
    Gen Two and a Half
