Tacoma Build Straight Out Of Jamaica
Discussion in '1st Gen. Builds (1995-2004)' started by Ricky876, Jun 20, 2016.
  1. Nov 16, 2017 at 7:25 AM
    #81
    Ricky876
    Ricky876 [OP] Well-Known Member
    2002 Toyota Space Cab
    Under construction
    Installed my oil pressure gauge and put on a coupler this is as close as it will get to being connected to my snorkel.... im paranoid about it being connected straight
    ChadsPride likes this.
  2. Nov 16, 2017 at 7:28 AM
    #82
    Ricky876
    Under construction
    well a supercharger is forced induction which is driven buy belt and pulley which is taken from the crankshaft
    turbo is forced induction which is used from waste exhaust....
    loool do you remember the name of the river?
  3. Nov 16, 2017 at 7:29 AM
    #83
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    And a turbo produces more power?
  4. Nov 16, 2017 at 7:53 AM
    #84
    Ricky876
    Under construction
    yep wayyyy more power
    Thunder Fist[QUOTED] likes this.
  5. Nov 27, 2017 at 6:45 AM
    #85
    Ricky876
    Under construction
    dyno tuned yesterday... had some issues initially but got them rectified.... wastegate wasnt opening boost spiked to 20psi
    pulled it apart and changed the wastegate springs and was getting 8psi so i added a manual boost controller
    plugs needed to be gapped... boost was killing the spark
    went back and did couple pulls to lock in the boost controller at 13psi... wanted 15psi but with that much power the van would be pointless to drive... let me tell you at 13psi now.... its disgustingggg rips the backend straight up to 3rd gear
    sorry for the captions on the pic... just saved them from my snapchat story
  6. Nov 27, 2017 at 7:08 AM
    #86
    2BeersPlease
    2BeersPlease Well-Known Member
    Damn. I'd settle for 240 hp. Looking forward to seeing this thing out in the wild.
  7. Nov 27, 2017 at 11:31 AM
    #87
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    wait are you running stock internals?
  8. Nov 27, 2017 at 11:42 AM
    #88
    Ricky876
    Under construction
    stock stock internals correct
  9. Nov 28, 2017 at 10:03 AM
    #89
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    How much timing was pulled at 13psi? Soon as I can get back to the track I'm going for 15psi like I've successfully done in the past. I've only added in 5* of timing retard at 15psi shooting for 11.5 afr. Curious where your numbers are at.
  10. Nov 28, 2017 at 10:11 AM
    #90
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  11. Nov 28, 2017 at 10:37 AM
    #91
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Here to follow the adventure.
    TacoLeeSD, Dalandser and ChadsPride like this.
  12. Nov 30, 2017 at 1:24 AM
    #92
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He's got a lot more videos of the truck and his cars on Instagram under the same name!
  13. Nov 30, 2017 at 11:07 AM
    #93
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    If you know, I'd still like to know what total timing is at these boost levels please.
    Dalandser likes this.
  14. Dec 1, 2017 at 6:10 AM
    #94
    Ricky876
    Under construction
    Asked my tuner he laughed and said you would have to get him to tune your truck for you to kno that:burnrubber:
    Tuners here are pretty savage lool
    Clay_916 and Dalandser like this.
  15. Dec 1, 2017 at 6:37 AM
    #95
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    You're running 50/50 methanol right? Do you know what your nozzle size is? I'm guessing you're pulling around 15 degrees at WOT.
  16. Dec 1, 2017 at 6:57 AM
    #96
    Ricky876
    Under construction
    50/50 correct... nozzle 250cc... i think its somewhere along those lines 15-17degrees not sure
  17. Dec 1, 2017 at 7:32 AM
    #97
    2010tacoma2tr
    2010tacoma2tr Well-Known Member
    Sweet setup man. Where in JA are you? I've got family down in white house
  18. Dec 1, 2017 at 7:41 AM
    #98
    Ricky876
    Under construction
    thanks man i live in Kingston
    2010tacoma2tr likes this.
  19. Dec 1, 2017 at 7:48 AM
    #99
    YouJamaicanTRUCK
    YouJamaicanTRUCK Active Member
    Jay
    Jamaica
    '09 4x4 4.L V6
    6" Fabtech Lift Kit, K&N Intake, 20" LED Light Bar (behind grille), Borla Catback Exhaust System, JL Audio Custom Sound System (10" woofers x2), Gen 3 Grille,Bumper, Front Fenders & Hood
    Love watching your build bredda, hit me up if ur ever in Ochi would love to see the beast in person!
  20. Dec 1, 2017 at 7:57 AM
    #100
    Ricky876
    Under construction
    respect man will do
