Tacoma Build Straight Out Of Jamaica
Discussion in '1st Gen. Builds (1995-2004)' started by Ricky876, Jun 20, 2016.
  1. Dec 5, 2017 at 12:45 PM
    #121
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I've been in contact with FN to get price quote, originally needed 5 wheels and they only came in 4 on the web page. contacted them by email they said its no problem to get 5 ordered. I don't see why they wouldn't sell you just one if they can sell me 5. btw I went a different direction with my wheels but just a heads up I think FN is experiencing high orders with Christmas right around the corner so expect delays. Took about 3-4 days before I would get reply to my email.
    Ricky876[QUOTED][OP] likes this.
  2. Dec 5, 2017 at 1:03 PM
    #122
    Ricky876
    Ricky876 [OP] Well-Known Member
    2002 Toyota Space Cab
    Under construction
    I got a reply!!!!!!!!!!!! thank god lol
  3. Dec 5, 2017 at 1:14 PM
    #123
    Ricky876
    Under construction
    Im going to make the order for a replacement rim
  4. Dec 5, 2017 at 1:57 PM
    #124
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @indetrucks
    indetrucks likes this.
  5. Dec 7, 2017 at 9:26 AM
    #125
    Ricky876
    Under construction
    So now that everything is back on track and ive ordered all the parts and just here waiting...
    took some pics from the rally on sunday
  6. Dec 18, 2017 at 5:48 AM
    #126
    Ricky876
    Under construction
    any one can help me out here..... my Centerline bearing aka carrier bearing is shot this is the 3rd time im changing it... is there an upgrade i can use vs the stock one??
  7. Dec 18, 2017 at 6:34 AM
    #127
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  8. Dec 18, 2017 at 7:08 AM
    #128
    Ricky876
    Under construction
    thanks alot... im gonna go that route and use some washers to drop it a bit
  9. Dec 18, 2017 at 7:09 AM
    #129
    Ricky876
    Under construction
    that bearing will fit my shaft with no issues right?
  10. Dec 18, 2017 at 7:12 AM
    #130
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  11. Dec 18, 2017 at 8:09 AM
    #131
    Ricky876
    Under construction
    Dalandser[QUOTED] likes this.
  12. Feb 5, 2018 at 7:40 AM
    #132
    Ricky876
    Under construction
    new brake set up
    Torspd and ChadsPride like this.
  13. Feb 5, 2018 at 7:47 AM
    #133
    Ricky876
    Under construction
    i went and got the carrier bearing that was recommended it definitely wasn't a direct bolt up... i had the machine my drive shaft to fit it and modify the bearing bolt up a bit.... however i have a very harsh vibration at around 40-50mph i take it i need to drop it some more with spacers?
    ChadsPride likes this.
  14. Feb 5, 2018 at 7:55 AM
    #134
    Ricky876
    Under construction
    end result
    RedLantern and ChadsPride like this.
  15. Feb 5, 2018 at 8:00 AM
    #135
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could be the angle, and need more washers, could be the drive shaft needs to be balanced, or could be both.
    Those brakes look fantastic.
  16. Feb 5, 2018 at 8:03 AM
    #136
    Ricky876
    Under construction
    thanks man gonna try more spacers and see
    Torspd[QUOTED] likes this.
  17. Feb 5, 2018 at 8:08 AM
    #137
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tremec has a phone app, to to help you make sure your drive shaft angles are all good. I believe it also works for two piece drive shafts.
  18. Feb 5, 2018 at 8:52 AM
    #138
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Cr250jumper did you have to machine your ds when you installed your carrier bearing?
  19. Feb 5, 2018 at 8:53 AM
    #139
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  20. Feb 5, 2018 at 9:20 AM
    #140
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    No mine fit, that carrier bearing looks a little different than the one I used
