TACOMA BUMPERS, Which one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Mar 6, 2008.
  1. Mar 6, 2008 at 3:38 PM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Manufacturer ShrockWorks
    Part #:TACO4-FBPR-01A
    - 3/16", 1/4" Plate steel consrtuction
    - Black powder coat
    - Accepts most non-integrated solenoid winches up to 9500 lbs.
    - Tubular center hoop and headlight guard hoops. 2"x.120 & 1.5"x.120 Tube
    - 304 Stainless steel Front skid plate, .134"
    - Holes for mounting driving lights on top of bumper under center hoop
    - Place to mount 4" aftermarket fogs or Driving lights (PIAA 510)
    - Two Recovery Points. They are a FULL 1/2" THICK steel. Welded front and rear. Accept 3/4" Clevis shackles.
    Fits: Toyota Tacoma 2005-2008
    $1,409.00 [WITH 2 SETS OF PIAA LIGHTS (FOG & DRIVING) AND TWO CLEVIS SHACKLES]
    Options
    Select Finish
    Black Powder CoatGray Powder Coat (+$10.00)White (+$50.00)Bare Steel (-$90.00)
    Select Tube Work
    Center Hoop & Headlight GuardsCenter Hoop Only (-$20.00)No Top Tubing (-$45.00)
    Lights in Bumper
    NonePIAA 4" 510 Ion Crystal Fog (+$199.00)PIAA 4" 510 White Driving (+$199.00)
    Lights Top of Bumper
    NonePIAA 580 7" Xtreme White Driving (+$279.00)PIAA 520 6" Super White Driving (+$199.00)PIAA 520 6" Ion Crystal Driving (+$199.00)
    Clevis Shackles
    none3/4" Clevis Shackles -Qty2 -Black (+$32.00)
    TOTAL:
    $1,409.00
    ARB BUMPER
    The Deluxe Winch Bars are carefully designed to accommodate an electric winch and the inherent stresses that exist when winching. This Winch Bar completely replaces the original front bumper with a protective steel bumper designed specifically for each application.
    • 250 Heavy Grade Wall Tubing
    • Cold Rolled Sheet Steel<LI class=partAttrName>Color
    • Paintable
    All Pro Front Bumper
    All-Pro Off Road has designed a Tacoma Front Winch Bumper to protect the front end and help your Tacoma to work even better in the backcountry! This bumper is built from heavy-duty, .120 wall, 1.75" tubing. Approach angles are greatly improved because it tucks up out of the way, providing much more clearance that the stock bumper and trim. This bumper also allows for the mounting of a remote solenoid winch of up to 9500-lb capacity. In addition, this bumper now features an integrated steel skidplate that not only looks great, but adds even more protection up front. The stock skid plate can also be retained. Ships unpainted.
    ROAD ARMOR
    This heavy-duty front winch bumper from Road Armor offers the best off-road approach angle over any competitor. Each bumper offers full underside skid plating, shackle mounts, recessed lighting mounts for 4" driving or fog lamps, and a lifetime guarantee against breakage.
    The Tacoma winch bumper will accomodate any integrated Warn winch up to 12,000 lbs.
    Item# RA90104X $1,449.00
    http://www.yotatech.com/f117/new-rear-bumper-05-tacoma-105237/
  2. Mar 6, 2008 at 3:54 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Go full custom:
    I can vouch for Shrockworks' build quality. I just received a set of their sliders and they are remarkably well made. You can see them unfinished in the above picture.
    ARB has a great name that stands on its own -- I just wanted to make sure Shrockworks was properly represented. You won't go wrong with either of them so it's really just personal preference.
    Note that either will add a lot of weight to the front of your truck so you may want to factor in some new springs when your calculating total cost.
  3. Mar 6, 2008 at 5:01 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I remember seeing your truck on TTORA. Hows the build going on that? Last time I saw it you had just got done installing the cage.
    To the OP: I personally like the ARB. Shockworks makes a great product as well.
  4. Mar 6, 2008 at 7:51 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I'm planning on the Shrockworks one whenever my money tree bears fruit. :rolleyes:
    Unfortunately, shortly after(if not before) the bumper I'll need to get some 886 coils. Would like to do 886 coils, OME shocks all around, and Dakars in the rear.
    But then I want sliders too, so I better find a damn good paying job. :D
  5. Mar 6, 2008 at 9:31 PM
    mjp2
    NJ
    It's getting there. Heck of a process but I'll hopefully have it out of the shop in the next month. At this point it's just the fuel cell, bed cage, and detail work left (switches, harnesses, window nets, paint, etc).
    I've got a Garage thread over on that site if you're interested. I'm always psyched when Saturday rolls around and I get to stop in and check up on the progress.
    If anybody in or near NJ is looking for a fabrication shop, I can't say enough positive things about Carroll's Rod & Racecraft in Spotswood! :cool:
  6. Mar 6, 2008 at 9:48 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    This bumper is the shit, although the website is not very useful at all and not sure if you can actually order it.
    As for the front, Shockworks.
  7. Mar 7, 2008 at 6:53 AM
    mvega1969
    Laredo
    I always thought on the ARB (the name and all what it carries) but now Shockworks shows a better fit bumper that really goes with Tacoma's front and it keep (apparently) the use of your OEM fogs and you can then add more lights if need it
  8. Mar 7, 2008 at 7:15 AM
    piercedtiger
    Jon
    Southern Tier, NY
    OEM fogs won't fit because they have plastic tabs holding them to the stock bumper. If you could fab up something you might be able to get them to wrok. But it'll take some time.
  9. Mar 7, 2008 at 7:44 AM
    mvega1969
    Laredo
    That is why they send you the option for FOG and Driving ligths... man! great way to do more money from a base requeriment: the bumper.
  10. Mar 7, 2008 at 8:15 AM
    corywilson13
    corywilson13 Canadian Taco
    Vancouver Island, British Columbia
    08 Taco sr5 Access 6spd Std
    Grom-Ipod, Bed Mat, Tool Box with TRD mat, Inifnity 6x9's.
    I think this thread should have been made a poll. I am really interested to see what everyone thinks as well, I am been trying to make the same decision.
  11. Mar 7, 2008 at 8:21 AM
    mvega1969
    Laredo
    Is there any other bumpers as these from ARB and Shockworks? Does anyone has a picture of it or them? once there are more options we can make the requested POLL.
  12. Mar 7, 2008 at 8:23 AM
    corywilson13
    good idea!
  13. Mar 7, 2008 at 8:25 AM
    mjp2
    NJ
    AllPro recently came out with a new bumper for the 05+ Tacomas:
  14. Mar 7, 2008 at 8:35 AM
    corywilson13
    700$ unpainted for the allpro, seems like a good deal.
  15. Mar 7, 2008 at 8:36 AM
    mjp2
    NJ
    BentUp.com made this sweet thing for a guy on ttora. Not sure if it'll be brought into full production but there's a chance!
  16. Mar 7, 2008 at 9:00 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I like hte ARB
  17. Mar 7, 2008 at 9:40 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    I like the ARB too we have done a lot of those.
  18. Mar 7, 2008 at 10:11 AM
    mvega1969
    Laredo
    Unfortunate bentup.com does the bumper for Toyota Truck / Tacoma 1989 - 2004, same thing for Allpro, I visited theri web site and they does not show any for 2gen Tacoma's.
  19. Mar 7, 2008 at 10:32 AM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    I'm going with the ALLPRO just after I get tires. The ARB is a great bumper but they will not custom it for fog/driving lights. I have turn signals on my lights and don't need another set on my bumber! Shrokworks is great as well but for the price you can't beat the ALLPRO they look the same.
  20. Mar 7, 2008 at 10:38 AM
    mvega1969
    Laredo
    hey Kilo, other picture than the one posted by mjp2, Do you have a weblink for these bumpers? I went to their site and there are none of them.
