tacoma cam miss alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tarpon24, Mar 14, 2013.
  1. Mar 14, 2013 at 5:35 PM
    Tarpon24
    Tarpon24 [OP] Well-Known Member
    Frankie
    Fl
    Trd
    Leveling kit, 20 in rims, flowmaster true duals, bullying watch dog,
    has anyone else had this problem ???
  2. Mar 14, 2013 at 5:43 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Truck getting towed ?
  3. Mar 14, 2013 at 5:45 PM
    Tarpon24
    Frankie
    Fl
    Trd
    no having a camshaft miss alignment
  4. Mar 14, 2013 at 5:46 PM
    OZ-T
    Peter North
    British Columbia
    Oh , my bad , when you said cams , I was thinking alignment cams
  5. Mar 14, 2013 at 5:47 PM
    Tarpon24
    Frankie
    Fl
    Trd
    oo gotca.
  6. Mar 14, 2013 at 5:47 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    So what happened to your cams?
  7. Mar 14, 2013 at 5:49 PM
    Tarpon24
    Frankie
    Fl
    Trd
    idk i guess they got thrown out of place. the trucks just started running really rough and its been at toyota for a month now.
  8. Mar 14, 2013 at 5:49 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    That sucks man!!
  9. Mar 14, 2013 at 6:02 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    So...did the timing chain tensioner go bad causing the timing chain to get loose and jump a tooth or something? What's the story?
  10. Mar 14, 2013 at 6:07 PM
    Tarpon24
    Frankie
    Fl
    Trd
    i honestly couldnt tell you all i was told is that it was a cam mis alignment and their was metal in the oil. cant believe it happened the trucks only got 30k on it
  11. Mar 14, 2013 at 6:49 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Probably just a manufacturing defect, that happens sometimes regardless of make or model. Warranty should take care of it.(Im assuming it still has warranty?) Keep us posted.
  12. Mar 14, 2013 at 7:08 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    If not a manufacturing defect, i would then guess it would be a problem with the timing chain tensioner, or a VVT-I controller malfunction. I know you didn't ask what we thought the problem was, and these are just my guesses at what the problem might be. Hopefully you have it fixed and back home soon.ImageUploadedByTapatalk1363313292.106958.jpgImageUploadedByTapatalk1363313305.939109.jpg
  13. Mar 14, 2013 at 7:34 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Did the engine make any loud knocking noises while it was running rough? If the cams were that out of whack the valves may have been hitting the tops of the pistons.
  14. Mar 14, 2013 at 8:41 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    The cams can't be misaligned. I would start questioning the tech who diagnosed it.
  15. Mar 14, 2013 at 8:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Misaligned may be a poor choice of words, but it sounds like he means the timing is off. Which in its own way is a misalignment between the Camshaft and the crankshaft positions.
  16. Mar 14, 2013 at 9:02 PM
    moondeath
    Pa, Gardners
    ^^This. If the timing chain became loose for some reason and the cam gears jumped a few teeth it would run horrible and possibly cause engine damage.
  17. Mar 19, 2013 at 3:50 PM
    Tarpon24
    Frankie
    Fl
    Trd
    it ran like shit and yea toyota had it for over a month. i guess then have no idea what their doing so they just started replacing everything. i went to pick it up three times and the first 2 i only got 500 ft and it screwed up again. plus they scratched the shit out of my bumper and broke my keyfob :mad:
  18. Mar 19, 2013 at 9:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is insane. I think you need to locate a new dealer. Is this being repaired under the drive train warranty? If so I would be calling Toyota Corporate for some answers. You could rebuild the entire frigging truck ( engine transmission and all ) in a month.
  19. Mar 20, 2013 at 9:43 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    At this point I would be pushing for an entire engine replacement.
  20. Mar 24, 2013 at 3:32 PM
    Tarpon24
    Frankie
    Fl
    Trd
    yea no one knows anything anymore they basically just started replcaing things until ti worked
