tacoma clutch replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylanmclean, Apr 22, 2020.
  1. Apr 22, 2020 at 11:59 AM
    Dylanmclean
    Dylanmclean [OP] Active Member
    Dylan
    Red 2005 tacoma
    I'm planning on replacing the clutch on my tacoma pretty soon. I have all of the parts including the parts I need to stop the bearing squeak that is happening to my truck. One of my friends has a 4 post lift but were not sure if it works so if it doesn't work we will do it on the floor with a jack. Is there anyone that has done this before and has any helpfull hints/recommendations for me?
  2. Apr 22, 2020 at 12:54 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I just did mine. I highly recommend the Clutch Masters hydraulic TOB if you can afford it.
    Things that help:
    -Battery powered impact gun
    -Lots of extensions. You need to sit at the back of the tranny and extend a 17mm socket the length of it to get at the top two bell housing bolts.
    -this dude has really good walk throughs of exactly what to do.
    https://youtu.be/LP00caN7q0s
    -a creeper helps tons
    PM me with any questions you might have. It's an easy job, just time consuming.
    EDIT: a lift would be amazing to have, I dont own one so I used jack stands and drive up stands. Got the job done. Just had to shimmy the tranny around on the motorcycle jack I used to get it out from under the truck.
    TnShooter likes this.
  3. Apr 23, 2020 at 8:16 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I've R&R the 5 speed. One issue I had was getting the truck high enough for the transmission to fit under the frame rails for removal. It was easy to get it high enough, but then my floor jack wouldn't reach the transmission. So I had to pull the transmission and then raise the truck a few more inches so I could remove the transmission from under the truck. I've since bought another long floor jack that raises much higher.
    Get an air or battery impact, impact swivel sockets, and a 3 foot extension for the top bolts as said.
  4. Apr 23, 2020 at 8:24 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    We used to call working on a vehicle on your back "ground hogging". It can be done much more fun with a lift.
  5. Apr 23, 2020 at 9:18 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Personally I’d split the transfer case from the tranny, makes it easier to handle. Hopefully the lift works.
