Tacoma code P2443
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovemytacoma2, Jan 2, 2019.
  1. Jan 2, 2019 at 12:49 PM
    ilovemytacoma2
    ilovemytacoma2 [OP] New Member
    Bob
    2015 TACOMA sr5 4 DR CAB
    NONE YET
    I could sure use some help. My Taco with 72 K just threw this code. I recently changed my plugs to new Denso's and cleaned the Maf sensor. I have not seen any elimination codes for this year and this secondary air system. I have also changed out the foam air filter in the air pump to the recommended one in this site. Any help would be appreciated. Thanks
  2. Jan 2, 2019 at 12:55 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    BassAckwards likes this.
  3. Jan 2, 2019 at 1:05 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    That’s a common code on 2012 models, not so much for 2015. Is it a hard code with CEL or is it a “pending” code via a scan device?
  4. Jan 2, 2019 at 1:48 PM
    ilovemytacoma2
    Bob
    NONE YET
    it comes up on the dash as trac off and check engine. I have noticed no performance or other issues.
  5. Jan 2, 2019 at 2:16 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I know the 2012 has an extended coverage campaign for this. Search and see if your 2015 does as well. It’s over $1,000 to replace the system but yours should be covered, I believe.
  6. Jan 15, 2019 at 4:32 AM
    Extreme 4x4
    Extreme 4x4 New Member
    2014 4x4
    My 2014 Tacoma threw code 2443 yesterday. 38200 miles. Dealer wants $1000 to fix. He says there is no campaign to fix but corporate may be willing to help due to low mileage. I'll find out Monday. I called corporate and they seemed to want to help but didn't actually say they would.
  7. Jan 15, 2019 at 5:36 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    A realize this can end up being an expensive repair. What I post next may be part of a former TW thread pointed to in post #2, but I don't have time to read those 50 pages.
    I ran across this snippet on the web - pertaining to code P2443:
    Code P2443 is for the secondary air injection switching valve stuck closed and the exhaust may have melted the valve causing it to stick closed. Make sure you correct any engine lean condition that could be the reason the exhaust is getting hotter than normal. Correct all codes retrieved.
  8. Mar 12, 2019 at 2:40 PM
    aarondang
    aarondang Active Member
    Aaron
    Los Angeles
    '12 DCLB
    The letter that was issued does not specify an error code therefore it would cover anything even related to the Air Injection Pump and Air Switch Valves. I'm on the call with corporate right now.
  9. Mar 12, 2019 at 4:42 PM
    DirtTaco
    DirtTaco Well-Known Member
    Please post results- started getting this code recently on my 2012..
  10. Mar 12, 2019 at 5:53 PM
    aarondang
    Aaron
    Los Angeles
    '12 DCLB
