Tacoma comfortable with 23' trailer ?
Discussion in 'Towing' started by mccarroll, Aug 27, 2012.
  1. Aug 27, 2012 at 5:20 AM
    mccarroll
    mccarroll [OP] Well-Known Member
    Newfoundland, Canada
    2012 DC 4X4
    [FONT=Arial, Helvetica, sans-serif]So my family is planning to purchase a 23' travel trailer with a dry weight of 3,700 lbs, hitch weight of 380 and GVWR of 4,780. I will definitely be purchasing a weight distribution hitch and brake controller.
    Would this be a good size for a 2012 V6 Tacoma with tow package?
    [/FONT]
  2. Aug 27, 2012 at 6:42 AM
    shemp
    shemp Well-Known Member
    Neither length, nor weight will be an issue for you. A brake controller by itself is no good, you need to actually have brakes on the trailer. Depending on the type of brakes, a controller may not even be required.
  3. Aug 27, 2012 at 8:29 AM
    mccarroll
    2012 DC 4X4
    Yeah, the trailer will have electric brakes. I'm green, but not that green. More curious about hauling up hills and in wind?
  4. Aug 27, 2012 at 1:48 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I tow a 19' trailer (24') over all. Fully loaded it weighs about 4500. It pulls just fine. You will notice it back there on big hills but it will cruise on flat stretches. I pulled my over 2 mountain ranges here in Oregon last week with no issues.
  5. Aug 27, 2012 at 1:53 PM
    BC Overlander
    BC Overlander Active Member
    British Columbia
    2011 Tacoma 4X4 TRD Off-Road
    I tow a 23' toy hauler with my Tacoma that weights 5000 lbs with our gear and the motorcycle in it. The Tacoma tows it well but if the grade is too steep, it will fall below the posted speed. Other than that, it does fine with the size of trailer we have.
    One thing you should have is a anti-sway system incorporated into your weight distribution hitch. 5000 lbs behind a Tacoma is a lot in a strong side wind or even when passing an 18 wheeler.
  6. Aug 27, 2012 at 3:16 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    Watch the GVW and rear axle rating, that's where your real limit is. You'll run out of payload way before towing capacity.
  7. Aug 27, 2012 at 4:30 PM
    tractng
    tractng Well-Known Member
    You should be fine. I towed a 22'2 trailer about 3926lbs dry (hitch low 400lbs) and it tows great. You are not beating any records but it will get there.
  8. Aug 28, 2012 at 5:36 AM
    shemp
    If you were going up hills in a vacuum, the weight wouldn't be an issue at all. Wind is the big thing that most people don't account for, both in terms of resistance to forward motion, and being bucked side to side. As someone above has mentioned, sway control would be a good idea.
  9. Sep 2, 2012 at 5:22 PM
    erm626
    erm626 Well-Known Member
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    Access Tonneau Cover, EGR window Visors,Trail FX Step Bars
    I had just purchased a 21 ft TT same Gross weight and hitch weight. The Tacoma pulls just fine. I would suggest the 4 th gear for most of your travel, unless flat highway. The gas mileage will drop to about 10 mpg. WDH is also advisable. The one thing that I found out was when the Semi's pass you, hold on to your steering wheel they will suck you in their direction..
  10. Sep 2, 2012 at 8:01 PM
    12Tacoma
    12Tacoma Well-Known Member
    TN
    2012 trd off road 4x4
    husky liners, undercover tonneau, ome 885's, 2" aal, 265/75/16 duratracs.
    Sounds perfect for a tacoma I have seen people on here towing alot more.
    Post pics when you can!
  11. Sep 2, 2012 at 9:48 PM
    tractng
    I feel the same. When a semi passed me, the trailer floated. I had only the WDH that time (had the sway but didn't hook up the sway when I took delivery).
  12. Sep 2, 2012 at 10:20 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I tow frequently my crawler on a 16 foot trailer. The power to tow is there but braking sucks ass. Leave yourself plenty of distance in case of a panic brake situation even with trailer brakes.
  13. Sep 3, 2012 at 3:45 AM
    erm626
    Ed
    Norfolk, Virginia
    Tacoma 4x4 SR5
    The next time you are out, with trailer and you are using the sway bar. Let me know if you still get "floating effect" from the passing Semi's .. I was told I didn't need one, but if it makes a difference I will install one.
  14. Sep 3, 2012 at 11:23 AM
    tractng
    Will do. We are scheduled to take a 2 day camping trip on Sept 28 (driving distance will be 135 miles each way).
  15. Sep 4, 2012 at 12:15 PM
    12Tacoma
    TN
    They most certainly do work even something inexpensive like this makes a big difference.
    http://www.etrailer.com/Weight-Distribution/Reese/RP26660.html
    Keep in mind trailer sway is not normal, the push/pull from passing trucks (or getting passed) is somewhat unavoidable.
  16. Sep 4, 2012 at 12:22 PM
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DblCab,shrt bed,4wd,TRD Sport, tow pkg, mgntc grey
    katzkin leather, chrome toyota step bars, chrome sr5 grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflectorII, tinted windows, Firestone ride-rite air bags, UWS slimline aluminum toolbox, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, Tundra / Sequoia wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed.
    You will be just fine with the WDH, brake controller and anti-sway bar. I had an '05 5.4L F-150 and it really did not pull my TT that much better than my Tacoma. The heavier truck kept the trailer from moving around as much, but the Tacoma is still plenty comfortable once you get a few miles under your belt.
