Tacoma cruise control ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtkkz, Oct 23, 2014.
  1. Oct 23, 2014 at 5:24 PM
    jtkkz
    jtkkz [OP] Well-Known Member
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    OME lift kit / Fifteen52 Analog wheels
    I have a 2005 Tacoma dbl cab 4x4, it did not come with cruise control
    Is it easy to install cruise control?
    How do we know if it is pre-wired for it?
    Has any one installed cruise control?
    thanks in advance for advise
  2. Oct 23, 2014 at 5:38 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Search for the DIY thread on this, its a ten minute job in your '05 if automatic, 1/2 hour if manual as you need to add a clutch switch.
  3. Oct 23, 2014 at 5:41 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
  4. Oct 23, 2014 at 5:47 PM
    Supramacy
    Supramacy Well-Known Member
    Very easy to do.
  5. Oct 24, 2014 at 7:47 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Cruise function is usualy built in, even if not sold originally. should be wiring in place, as Toyota makes is easy to convert their vehicles for hands/only control for folks who cannot use foot controls.
    MuddyJackson likes this.
  6. Oct 24, 2014 at 12:34 PM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    is there a way of telling if my Tacoma is pre-wired for cruise control?
    My Tacoma is automatic...
  7. Oct 24, 2014 at 1:19 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you can search Yaris forums for cruise control. a few people have made (me too) home made switches with a few resistors for Yaris CC. Yaris doesn't come with CC unless you fork over 500 bucks !!! for a 30 dollar switch....hence a lot of homemade ones
    it will be the same for the Tacoma. Use the yaris info (if you cannot get an immediate answer about tacoma) and open up yer steering column and look for the connectors. I am gonna bet it is there...
  8. Oct 24, 2014 at 1:24 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    It's prewired to the clockspring I believe
    You would need the harness and cruise control knob (all plug and play)
  9. Oct 24, 2014 at 1:35 PM
    midwestfourwheel
    midwestfourwheel Member
    I found on a 2015, if one removed the steering wheel shroud (split plastic) between wheel and dash, there is a twelve pin connector perpendicular to the steering column close to the wheel. Confirmation that the two lower left (closest to wheel) wires (brown and blue?) were present in the connector, confirmed prewire. If your vehicle is slightly older?, may be slightly different.
  10. Oct 24, 2014 at 2:39 PM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    ok thanks for the replies
    I found all the parts needed from Toyota Parts superstore in FL
    all parts for $108 including switch, wiring harness, cover, screws
    I just need to double check if it pre-wired, I did some research, need to check for brown/white & white / black stripe wires need to be present
  11. Oct 24, 2014 at 2:46 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you are manual look way up above the clutch pedal and there should be a white plug that would plug onto the clutch switch. If auto and by switch you mean stalk then you'll just have to follow your research.......
  12. Oct 24, 2014 at 3:13 PM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    my local toyota dealer said, that ECU will not read it
    you can install all the parts but it may not read the cruise control speed set etc....
    will I need to have ECU reset?
    or is it simply plug and play?
    I am getting a bit confused.....
  13. Oct 24, 2014 at 3:28 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Just plug in the switch stalk with the harness following the instructions, and you'll be good. No programming is required, its plug and play if pre-wired. And as far as I recall, all 6-lug trucks were prewired 2009 and previous. My '06 4X4 base was prewired. Whoever you spoke to at your dealer wasn't telling you the truth, either because they are ignorant of the facts, or purposely trying to mislead you.
  14. Oct 24, 2014 at 3:44 PM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    ok thank you for confirming
    I will check if it is pre-wired first....
    has anyone been able to upload pics with instructions?
  15. Oct 24, 2014 at 4:18 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
  16. Oct 24, 2014 at 5:00 PM
    Supramacy
    They are pre-wired. And as mentioned above it plugs into the spiral cable.
  17. Oct 24, 2014 at 5:29 PM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    thank you very much for instruction w/picture / forum
  18. Oct 24, 2014 at 7:59 PM
    Taco'09
    Taco'09 Well-Known Member
    No pre-wiring on my '09, I had to do everything from scratch.
    OP, its the S8 connector you want to look at. On your '06 if spaces 1 (brown wire/white tracer) and 2 (white wire/black tracer) are populated you will probably have the rest.
  19. Oct 25, 2014 at 8:26 AM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    what do I have to remove in order to check if it is pre-wired?
    I took the side knock out piece out but could not see the brown/black wire...
    Will I need to remove plastic cover under steering / ignition ?
  20. Oct 25, 2014 at 8:36 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No you need to remove the air bag...
    The wire probably isnt in there. But it's prewired up to the clockspring
    (That's how my girls Corolla was, and all I did was plug in the harness to the clockspring and cruise knob to the harness
