Tacoma cruise control ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtkkz, Oct 23, 2014.
  1. Feb 28, 2019 at 7:46 AM
    #41
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    You're right about taking apart the connector to get the horn ground, the best way to see if your pre-wired for CC is to see how many pins are in the clockspring (should be 3 pins).
    Newfiebruh[QUOTED] likes this.
  2. Feb 28, 2019 at 9:08 AM
    #42
    Taco'09
    Taco'09 Well-Known Member
    Sorry about that. I tried responding twice to you and it kept defaulting to......well nothing.
    You wanted to know why the cruise light was not illuminating. In my post that disappeard I said that you would need to run a wire from the connector on the engine ECU up to the connector on the back of the instrument cluster. I also wondered whether you ran any other wires, such as the one to the engine ECU, the clutch cancel, and the ground as it was not mentioned and it occurred to me that you may only be part of way there.
    Do not assume that anything is pre-wired. Like I said earlier my '09 had absolutely nothing, NADA, zero anything to work with. Some are and some are not. The only thing that seems to be consistent that I have seen is the wire from the engine ECU to the back of the instrument cluster seems to be already there much of the time on later year trucks, but not the earlier.
    the macf[QUOTED] likes this.
  3. Mar 15, 2019 at 3:40 PM
    #43
    the macf
    the macf Well-Known Member
    Daily Driver - 09 RCLB Barcelona Red base, Sold - 08 BSP X-Runner TRD SC 332rwhp
