Tacoma Dash lights problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trinimd, Jul 26, 2008.
  1. Jul 26, 2008 at 9:52 PM
    Trinimd
    Trinimd [OP] Member
    I have a 2000 Toyota Tacoma Prerunner
    I just noticed the dash lights (speedometer) do not light up red when I turn on the head light.
    The head light and tail light works
    blinker lights work
    Oil light door like all work
    Also the lights by the a/c don't work.
    Any suggestions?
    Thanks
  2. Jul 26, 2008 at 9:58 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    not sure...
    but welcome to the forum :D
  3. Jul 26, 2008 at 10:51 PM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    Did you check the panel light adjustment? Maybe they're turned all the way down. I know...simple, but sometimes we miss the obvious...I know I have.
    Patcakess24 likes this.
  4. Jul 27, 2008 at 6:15 AM
    Trinimd
    Trinimd [OP] Member
    Yea I checked the dial. Is there a fuse just for that dial? Or is just one fuse for the whole dash?
    Thanks
  5. Jul 29, 2008 at 8:44 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    I'm having the same problem actually. I just got an aftermarket stereo installed and I was wondering if we had left something unplugged or if it were a fuse or what. Any ideas would be appreciated.
  6. Jul 30, 2008 at 9:23 PM
    ILove2Drive
    Casey
    WV
    I tried changing fuses this evening but no luck. did you happen to get the problem figured out trini?
  7. Jul 31, 2008 at 5:27 PM
    Trinimd
    Trinimd [OP] Member
    Are your tail lights lighting UP?
    I just noticed my tail lights are not lighting up.
    The brake light works but not tail lights.
    I will PM U
  8. Aug 1, 2008 at 4:06 PM
    ILove2Drive
    Casey
    WV
    My tail lights work fine. In my truck under the hood on the panel, is the fuse that it keeps blowing. Where I just installed the radio it's probably something not ground in there or something. Because as soon as I flip the switch to turn the lights on the fuse immediately blows.
  9. Aug 1, 2008 at 4:46 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Take your new radio out of the dash, grab a test light and with the keys out and everything off see what is pulling power (should just be one wire that keeps the clock and memory). Mark that wire and then flip on your lights with the radio off. Check off your wires again and the one thats pulling juice is your problem. Make sure it is not grounding out against something and you should be able to trace it quickly. Lastly make sure your new radio does not require a larger fuse to support it. While you are in there you can install an inline fuse for your radio so it will quit messing with your lights. Good luck. Jay
  10. Aug 1, 2008 at 4:47 PM
    Trinimd
    Trinimd [OP] Member
    Yep same problem. If you flip the switch the first click (park mode) I bet your tail light is not on. Its only on when hit the brakes?
  11. Aug 1, 2008 at 4:49 PM
    JJ Customs
    Jay
    NV
    Your other option is if you paid a place to install your radio take it back and make them fix it. However if they screwed it up the first time you can't really trust them to find, fix or repair the problem.
  12. Aug 1, 2008 at 4:50 PM
    Trinimd
    Trinimd [OP] Member
    Nah I put them in myself. ILOVE2drive do you have a hitch?
  13. Aug 1, 2008 at 4:54 PM
    JJ Customs
    Jay
    NV
    You know I had a problem a lot like this back in 99 and it turns out my dog simply used my taillight wiring harness as a chew toy. I wonder what ever happened to that dog?
  14. Aug 1, 2008 at 5:01 PM
    Trinimd
    Trinimd [OP] Member
    I do have a hitch with wire harness. I noticed the wire harness is a tear in it. I disconnected both tail lights from the original Toyota wire harness. The fuse still blows.
  15. Aug 1, 2008 at 5:17 PM
    JJ Customs
    Jay
    NV
    Well I would start at the radio. It only makes sense that you started having the problem after the new install.
  16. Aug 1, 2008 at 5:33 PM
    Trinimd
    Trinimd [OP] Member
    Yea but the radio was installed 2 months ago. maybe electrical tape slipped off. lol
  17. Aug 1, 2008 at 8:50 PM
    ILove2Drive
    Casey
    WV
    No I didn't have a place install it, I had some help but it was a DIY install. I'd say it traces back to that because they worked fine before that. We did remove the fuse for the radio so no power was coming to it at all and it still blew my panel fuse, so it's probably a ground or something. No that's the place where our problem differs Trini my tail lights work fine, everything works perfectly except for those dash lights and the lights over where the AC and everything is. So I'm not sure exactly what fuses you're blowing. But for your dash if you haven't already checked it under the hood check your panel fuse that is what keeps blowing on mine. And I don't have a hitch either, so maybe that would have something to do with why your tail light fuse is blowing as well? Lol at least we got each other to go by as we make progress on this. :)
  18. Aug 1, 2008 at 9:06 PM
    Trinimd
    Trinimd [OP] Member
    So there is a gage fuse in the cab and then there is a panel fuse under the hood?
    I am going to be working on it tomorrow. I will keep you posted.
    thanks
  19. Aug 1, 2008 at 11:23 PM
    ILove2Drive
    Casey
    WV
    Yes, I tried the gauge fuse in the cab, and I don't believe that one is blown. So my problem comes from the panel fuse, yours might too. I also will be working on mine tomorrow, so I'll do the same for you. Thanks in advance!
    ...and good luck to you!
  20. Aug 3, 2008 at 12:45 PM
    Trinimd
    Trinimd [OP] Member
    FIGURED it out as well! Thanks. It was the illumination wire (orange) that was shorting out. My deck didn't have the illumination option so I just left it out. The wire was exposed and was shorting out. So I just covered the wire and replaced the fuse.
