Tacoma Deflector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ylua, Jan 9, 2014.
  1. Jan 9, 2014 at 10:07 PM
    ylua
    ylua [OP] Member
    Hawaii
    06 4x4
    3in Suspension lift with 32inch Firestone A/T
    Should i remove my deflector on my tacoma? I want to, but have heard only bad things from removing them.
  2. Jan 9, 2014 at 10:09 PM
    AMH3RST
    AMH3RST eat, sleep, work
    Mitch
    Las Vegas, NV
    06 PreRunner Dbl Cab
    Camburg +3.5" LT; King Shocks 2.5x8"; King Shocks 2x2" Bump Stops; Maxtrac 4" spindles; Deaver J66 leafs; King Shocks 12x2"; BAMF Rear Shock Relocate; KMC Enduro 16x9; BFG KM3 315/75R16; BAMF BTG Light Bar; 2 20" Toughlight Pro Series LED Light Bars; Cab Cage
    Bad thing like what? Lose it..
  3. Jan 9, 2014 at 10:10 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Is it an OEM bug deflector?
    I had an OEM, took it off, and the metal clips that grasp the hood....took paint with them... :(
    I had to lose it...but some times the paint chips bother me even though i've filled them in with touch up :/
  4. Jan 9, 2014 at 10:17 PM
    ylua
    ylua [OP] Member
    Hawaii
    06 4x4
    Yeah it's one of those. It's been on the truck for over 4 years. Not sure if i should but like the look without them a lot better.
  5. Jan 9, 2014 at 10:20 PM
    .MarkyMark.
    .MarkyMark. Jesus follower
    Mark
    Oceanside, CA
    2007 Regular Cab, 5-Lug
    ReadyLift SST w/AAL, Rancho RS5000 shocks, Volant CAI, 1.25" Hub-Centric Spacers, FJ Cruiser Seats, Tint, Stereo, more to come
    You've made your mind up... just commit. I mean, worst case you put it back on.
  6. Jan 9, 2014 at 10:21 PM
    AR15xAR10
    I very much prefer it off. I think it didn't do much but look like a mustache. I can take pictures of my paint chips tomorrow and post them so you know what you're in for. I'd hate to be the reason you couldn't make your truck what you want but i think you might want to see anyway. :) i'd take paint chips and no bug deflector over covered up paint chips and a bug deflector....but thats just me
    Off :thumbsup:
  7. Jan 9, 2014 at 10:49 PM
    ylua
    ylua [OP] Member
    Hawaii
    06 4x4
    yes please! I would love to see the damage it did.
  8. Jan 10, 2014 at 6:49 AM
    AR15xAR10
    Give me a few hours and i'll grab some up. :)
  9. Jan 10, 2014 at 7:42 AM
    AR15xAR10
    These are two chips from two different angles. These should be the only places that will chip...any where else will just be a haze that i removed with rubbing compound and wax.
    Also keep in mind mine was on for roughly 4 years as well.
    Also take notice to the duplicolor touch up paint that doesn't match :(
    I intended to get OEM touch up paint to really cover it but never did. OEM from the dealer is the best way i have found for touch up paint on other toyotas. You can definitely cover it up better than i did and most people will never know the difference! Hope i've helped!
  10. Jan 10, 2014 at 12:22 PM
    AR15xAR10
    Any thoughts?
  11. Jan 10, 2014 at 12:30 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Lose it.
    I have never got a paint chip on the hood of either of my 2 Tacomas. The hoods on the Tacoma are so flat that it would have to hit just right to chip it where the hood deflector sits. IMO it breaks up the lines of the truck and makes it look much worse. That's JMO.
  12. Jan 10, 2014 at 1:01 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I like mine. I've had one on every truck I have ever owned: Silverado, Tundra and Tacoma.
    It's all a personal choice. If I had to choose between a deflector that is already on or paint chips, I pick the deflector. Again, all a personal choice.
  13. Jan 10, 2014 at 1:22 PM
    amcorley
    amcorley Active Member
    Adam
    Hill AFB
    '06 PreRunner SR5 Sport
    Running boards, BOSS audio system with backup cam, nav, dvd, and bluetooth
    Pretty sure they're talking about paint chips caused by the clips holding the deflector in place, not caused by rocks (or ridiculously large bugs).
    Lose it. The lines on the Tacoma are already beautiful, using that is like asking a super model to paint on a mustache.
  14. Jan 10, 2014 at 1:49 PM
    newtacomaowner13
    newtacomaowner13 Member
    emsmedic
    Durham , NC
    13 Tacoma Limited Long Bed
    Procomp 3" Lift Nfab Nerf Bars
    You should have a small silicone strip that is placed on the hood before the clips are applied. This protects the hood from scratches or chipping and is included with the oem Toyota Deflector. I just installed my deflector a few weeks ago.
  15. Jan 10, 2014 at 2:02 PM
    AR15xAR10
    The metal clips on mine vibrated through the protective clear tape....
    taking it back off is really hard on it too :(
  16. Jan 10, 2014 at 2:25 PM
    looking4vr
    looking4vr Well-Known Member
    Brad
    Lusby, MD
    17 DCSB TRD OffRoad 6MT
    Bone Stock, for now
    Mine too. It was the first thing I took off the truck when I brought it home... Going to play hell getting the tape off for starters, got one pad off and it took a half hour, and then have to fix all the chips in the paint. I am NOT a fan of these things :(
  17. Jan 10, 2014 at 2:27 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Take it off and if need be just use touch-up paint.
  18. Jan 10, 2014 at 3:13 PM
    ylua
    ylua [OP] Member
    Hawaii
    06 4x4
    This is what it looks like now after i took it off. It took a while because I had to scrap off the old residue left behind from that 3m tape, but overall I think it looks much better! What do you guys think?:cool:
  19. Jan 10, 2014 at 3:33 PM
    amcorley
    Adam
    Hill AFB
    It sucks, put it back on!
  20. Jan 10, 2014 at 3:37 PM
    AR15xAR10
    Hot!!! Love that red!!!
