Tacoma Diesel for 2022
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConantTaco, Jun 7, 2021.
  1. Jun 8, 2021 at 7:47 PM
    #81
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    From my experience older fords were pretty stout. My ranger was as reliable as any Tacoma. My buddies also had great experiences with older fords.
    The newer fords, meh. My ex’s ecoboost escape needed engine replacement at like 25k miles. If I was to buy a Ford, it definitely would be with a 5.0 coyote. I actually wanted to get a 4x4 AC Fx4 but no MT offered, otherwise I would’ve been chilling at Ford forums right now.:)
    DavesTaco68 and averagejp like this.
  2. Jun 9, 2021 at 6:47 AM
    #82
    ashesofempires
    ashesofempires Well-Known Member
    2021 Blue Tacoma Sport ACLB 6MT Blackout
    MESO Customs Stuff.
    Don't know much about brakes, I take it.
    Front brakes have different requirements. Most of a vehicle's braking power comes from the front brakes. This is a product of momentum and the resulting weight transfer forward. You can feel it during braking as the friont of the vehicle squats down. You can really tell the difference on a bicycle; apply the same amount of force on the front brake as the rear and you'll go over the handlebars.
    Why does this matter for front brakes? It means they end up doing most of the work, especially in front heavy vehicles. So they are usually sized larger than rear brakes. Larger rotor, larger caliper, larger pads for more surface area to grip. That also generates a lot of heat, which needs to be transferred away. Disc brakes are much easier to cool passively with airflow. A lot of engineering goes into race cars to direct airflow into the brakes to avoid brake fade. Drum brakes build up heat inside the drum, and it takes longer to bleed away.
    One more thing: the air coming into the front brakes is, on the whole, 'cleaner' than the air going past the rear. Even just accounting for just the dust and debris being kicked up by your own vehicle, the rear brakes have to contend with all of the dust and debris kicked up by your own vehicle, and the front brakes don't.
    Ok, so all arguments in favor of discs at the front. Better stopping power, better heat dissipation, don't have to contend with the same amount of fine particulate debris intrusion.
    So many of those arguments don't matter so much for rear brakes, for the truck's design purpose. Tacomas aren't purely an off-road, vehicle. If they were, they'd have portal gear hubs to raise the ground clearance. They're multi-use vehicles, and Toyota engineers made compromises based on the truck's most popular use cases, alongside some more pragmatic considerations like cost. Drum brakes at the rear make sense because the rear brakes weren't intended to be under heavy load, and thus need to shed heat. They don't need to be big and meaty to stop the vehicle. They do need to keep out dust and fine debris, because Tacoma drivers are more willing to drive in places where it's dusty and dirty, than other truck drivers.
    So yes, drum brakes fit the bill better than discs.
    All engineering is compromises. Weight, reliability, power, cost, complexity. Toyota's engineers had to make a decision based on a lot of factors. I think they made the right decision. Drum brakes are proven to be reliable, durable, and suitable to the needs of the truck. I've had 4 Toyota trucks now, and across 650,000 miles I've only ever had to put on a single set of rear brakes, on a truck with 280k miles. I've never had to disassemble the drum to clean anything out, and I've lived all my life on gravel roads.
  3. Jun 9, 2021 at 10:09 AM
    #83
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Feel better about yourself now?
    Too bad you weren’t astute enough to pick up on the sarcasm. I wasn’t seriously suggesting that drums be put on all four wheels. Great dissertation on brake theory and application, but I think we can all generally agree that it is done primarily as a cost savings measure on Toyota’s part.
    Mmaira2018 and Lt. Dangle like this.
  4. Jun 9, 2021 at 10:24 AM
    #84
    Yoyo-2006
    Yoyo-2006 Well-Known Member
    Steven
    Reg cab 06 5speed 4x4
    None
    Here’s some food for thought, EPA regulations are so bad caterpillar quit making semi engines... think about the billions they lost.
    Mmaira2018 likes this.
  5. Jun 9, 2021 at 10:33 AM
    #85
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    People that buy diesels are usually towing heavy shit.
    Having a diesel is straight up pointless in a tacoma.
  6. Jun 9, 2021 at 10:37 AM
    #86
    Mmaira2018
    Mmaira2018 Well-Known Member
    Click bait title OP
  7. Jun 9, 2021 at 10:49 AM
    #87
    Pilotjoe123
    Pilotjoe123 Well-Known Member
    Joe
    Eastern, NC
    2012 Pyrite Mica Tacoma Sport
    Trd Supercharger URD 2.8 pulley AFE momentum GT Cam gears DT shorties DT mid pipe Vibrant res Borla Pro XS HPtuners custom dyno Aem 340lph fuel pump agm x2 power 34 battery dynomat sso slimline Icon 2.5 coilovers Icon 2.0 rear RR All Pro 3” expedition leafs flip kit superbumps SPC ucas Whitelines 4.88 nitro gears Detroit Truetrac front/rear Mayhem Prodigy 35/12.50/17 Mickey Thompson Baja Boss M/T
    Ford’s latest piece of shit
  8. Jun 9, 2021 at 12:04 PM
    #88
    Tacopycho
    Tacopycho Well-Known Member
    2021 Toyota Tacoma Off Road
    None
    I certainly like older, well built. Fords. Too much plastic nowadays. Tupperware automobiles.
    Junkhead[QUOTED] likes this.
  9. Jun 10, 2021 at 5:27 AM
    #89
    ashesofempires
    MESO Customs Stuff.
    JUST JOKING GUYS, HAHA.
    Well, now that we've cleared that up.
    Marley&Me likes this.
  10. Jun 10, 2021 at 6:07 AM
    #90
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Most folks who want a diesel, have never owned a diesel.
  11. Jun 10, 2021 at 6:34 AM
    #91
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    TRUTH!!!!!
  12. Jun 10, 2021 at 6:46 AM
    #92
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    People love busting Fords balls about reliability but my buddy has a Ford F-150 for a work truck, put on over 200k miles last few years, he's done nothing but oil changes to it with no issues, my wife's car is a 2016 Ford, zero issues in almost 5 years of ownership. That said I'm driving my Tacoma with no plans to ever get rid of it.
    Gunshot-6A likes this.
  13. Jun 10, 2021 at 11:03 AM
    #93
    Mike402
    Palm Springs, CA
    :deadhorse:
    Ha yes. As I come back and reread this, pretty dumb thing to go back and forth about.
    Carry on :cheers:
  14. Jun 10, 2021 at 11:15 AM
    #94
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Just like the Dodge / Cummins issues of old, once a rep gets established, it takes literally forever to rewrite your future.
    DavesTaco68[QUOTED] likes this.
  15. Jun 12, 2021 at 4:53 PM
    #95
    Tacopycho
    None
    Diesel equals DEF, DPF, SCR, Equals Limp Home Mode at the worst time, weather and at the furthest geographical vector from home and competent Dealership service department.
  16. Jun 12, 2021 at 7:10 PM
    #96
    Itchyfeet
    Itchyfeet Well-Known Member
    and the tacoma isn't full of plastic shit, hell even the bed is plastic
  17. Jun 12, 2021 at 7:32 PM
    #97
    YellowFootPrints
    YellowFootPrints Well-Known Member
    2021 Tacoma TRD-OR
    Zero
    also the new gen diesels in the big 3 are a mess, you have to delete them to get the true diesel advantages
    Foster1[QUOTED] likes this.
  18. Jun 12, 2021 at 7:44 PM
    #98
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Pretty sure they'll offer a new color! and add a few grand to the MSRP!
    Oh new TRD stickers too can't forget that.
  19. Jun 12, 2021 at 7:44 PM
    #99
    Itchyfeet
    I'd venture to say only a small fraction of people delete their late model diesel truck anymore. It's sure talked about a lot like we're still in the early 6.0 and 6.4 days.
    The 6.7 powerstokes in the company fleet have been dead balls reliable and have no deletes. IMO the delete stuff is just saying hey punch my anal v-card if you get caught in some states or if you're running DOT reg
    skiploder and Tacopycho like this.
  20. Jun 16, 2021 at 8:25 PM
    #100
    awesomeandy013
    awesomeandy013 Well-Known Member
    Andrew
    Pittsburgh, PA
    '17 MGM DCLB TRD OR, '16 TRD Pro 4RNR QS (wife)
    265/75R16 Wildpeak AT3W, Softopper, Kicker speakers, shift knob, Ventvisors, Tint, Husky Weatherbeaters, Hondo Garage radio knobs. The to do list: Bilstein 6112/5160, 3 leaf add-a-leafs, lights, alu skid, PRP seat covers...
    I'm pretty sure in 2019 or 2020 the EPA made it where its illegal for you to pass inspection in any state if your truck has been deleted. Whatever the fine is it must be not worth the risk because there have been local diesel shops that have restructured and will not delete trucks anymore. I remember my buddy has a '99 F350 with a 7.3L and was laughing cause the pre-DEF trucks jumped like $6-8k overnight when it got passed.
    edit: https://www.epa.gov/sites/production/files/2020-12/documents/tamperinganddefeatdevices-enfalert.pdf
    I think AFE removed most of their delete parts and what is left is strictly marketed for off road use.
