Tacoma Diesel Swap (VW or otherwise)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Apr 13, 2011.
  1. Oct 31, 2018 at 2:58 AM
    #61
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    To all who view this thread, I have a OM617a Mercedes TD sitting in the shed right now. 123 hp, 190 ft lbs torque at 2000 rpm. Very very easy to put a variable waste gate and turn up the mechanical pump. 160 hp, 270 ft lbs with no reduction in reliability. I am searching for a company to make an adapter to the r155a as we speak
    swerveverything likes this.
  2. Oct 31, 2018 at 6:28 AM
    #62
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    First....way to bump a 3 year old thread.
    Second....why? Really, why would you want to do that? 160hp and 270lbft are both less than what the 1GR-FE puts out stock. And since you mentioned you are concerned with reliability; nothing will be more reliable than the stock drivetrain. Nothing. You'll end up with less power and torque with marginally better fuel economy that has little to no hope of saving you money due to the initial money you invested to do the swap. Sooooo, what's the point?
  3. Oct 31, 2018 at 12:12 PM
    #63
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    Assuming you've got the talent or the pockets -hook up the mini cummings 2.8. DT has crapped on that motor, but I've seen otherwise.... working with a company belting out an 800 hp version of it. Of course, the wiring will be $$$ to cover and cross... again, assuming you have the talent and $$$$.
  4. Oct 31, 2018 at 1:47 PM
    #64
    Nomad_Pilot
    Clay
    Ft Collins
    I have a 4 cylinder, not the 6. I am so sick of the lack of power. I have the engine, and I have already converted a Toyota and an Isuzu trooper to turbo diesels. So I definitely have ze skillz
  5. Oct 31, 2018 at 1:57 PM
    #65
    ItalynStylion
    Steven
    DFW, Tx.
    Why not just buy a Tacoma that already has the V6? Or buy a turbo kit for the 4 banger? A 4 cylinder diesel would have been cool from the factory but as a retrofit it makes very little sense in my opinion.
  6. Oct 31, 2018 at 2:08 PM
    #66
    xplorn
    xplorn Well-Known Member
    Ken
    Oregon, USA
    '10 DCSB OR
    I have a couple OM617s as well, one slated for an '85 pickup that I sold before getting to it. Nice mild I5 motor.
    If I were chomping to do this (it makes little sense imo), I'd look at a Benz OM642 aluminum block V6 (sprinter vans, GL350s, etc.), or the Toyota 1VD-FTV V8. You're staring at 20k for the Cummins I4, so why not go with better motors.
    But then, why not experiment with a turbo setup for the stock Toyota 4cyl? Could be fun and would be a good learning experience. Much cheaper.
  7. Oct 31, 2018 at 2:50 PM
    #67
    Nomad_Pilot
    Clay
    Ft Collins
    Because an aftermarket fuel management system will not be as reliable as stock. Plus I have the engine just sitting there!
