Tacoma Differentials/Transfer Case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mibus, Dec 10, 2020.
  1. Dec 10, 2020 at 11:59 AM
    Mibus
    Mibus [OP] New Member
    2015 Tacoma SR5
    Hey all,
    New to the forum with a question since my google-fu has been failing me.
    Is there a handy table or listing of what type of differential is in each year/model truck and the axle location?
    I've been trying to figure out what exactly is in my 2015 SR5 (Access Cab, 4wd, 6' bed ETA: V6 6MT). I know it has a locker, but is that just the rear axle? What's in the front (Open, LSD, Locker?). Is the transfer case equipped with a differential?
    Thanks!
  2. Dec 10, 2020 at 12:20 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    With a SR5, it did not originally come with a locker.
    Front is wide open differential.
    Transfer case is electronically controlled, 2-speed with a 1:2.57 ratio.
    I'm not sure on the gearing of your truck since you don't specify 4-cyl/V6 and if your truck is manual/automatic transmission.
    Check out the 2015 brochure I have attached for more specs and post you your remaining questions.
  3. Dec 10, 2020 at 1:15 PM
    Mibus
    2015 Tacoma SR5
    Right! V6 and 6 speed manual and tow package.
    The brochure does fill in some of the gaps. I was wrong about the locker - I thought 4L switching meant locker - now that I've done some more reading yes the SR5 for my year should have an open rear differential and just use the traction control as a quazi LSD (ATRAC or whatever). I was reading that 4L/4H simply tweak the ATRAC system, in addition to actually kicking it into 4wd and setting the gear ratio there. Transfer case is fixed connection front/rear (no differential).
    Thanks for the info!
    JasonLee likes this.
  4. Dec 10, 2020 at 7:07 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
  5. Dec 10, 2020 at 7:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    cross linking this reference as well.
    https://www.tacomaworld.com/threads/2005-2016-tacoma-axle-codes.408019/page-4#post-23905887
    The front differentials were only offered as open, unless you had electronic traction control, it could be considered “LSD” due to using front brakes to control wheel slip. The transfer cases are all open differential in the Tacomas, no AWD versions were had from the factory, though some have swapped in limited slip transfer cases in with success.
