Tacoma Double Cab Roof Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dvto2, Jul 12, 2023.
  1. Jul 12, 2023 at 8:41 AM
    dvto2
    dvto2 [OP] Well-Known Member
    I'm looking for a decent roof rack to haul a 60 lbs canoe. I have all the brackets and tie downs for the canoe but need rails and cross bars for the roof. What do people like? I don't want something cheap that will fall apart but I don't want to spend $800 either.
  2. Jul 12, 2023 at 8:51 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    banditcamp and PilotBoy352 like this.
  3. Jul 12, 2023 at 8:54 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
  4. Jul 12, 2023 at 11:05 AM
    vtdog
    vtdog Well-Known Member
    NH
    I installed the OEM racks on my '11 just after I bought it new. Install was easy and the cost was way less than $ 800. The "best" thing about them is they fold into a slot when not in use so they are oriented front to back. No wind noise, no wind resistance and are always available for use by unfolding. I carry my canoe on top without issue.
    If I were doing it now, I would check with a junkyard as (on occasion) drivers kill their Tacomas in wrecks. If it is not a roll over then rack should be fine.
    seedy_tea likes this.
  5. Jul 12, 2023 at 12:34 PM
    dvto2
    Got a link or brand?
  6. Jul 12, 2023 at 12:54 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I got an OEM set was on truck for 1 month removed. Paid 350.00 brand new from Toyota
    200 and it yours
  7. Jul 12, 2023 at 4:05 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    OEM works well. Advantage being that you can fold the bars back when not in use and there is no wind noise.
  8. Jul 12, 2023 at 7:55 PM
    vtdog
    NH
    Toyota brand. OEM
  9. Jul 13, 2023 at 12:05 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Installed a “red rock roof rack.”
    Yes it has many names but the CAD drawing is the same.
    Holds up very nice with me standing on it and holds 5pcs of shed 40 20ft steel pipe quite well.
    Yes it’s cheaper than prinsu or other brands. But I just don’t understand the “overlanding markup”.
    Only downside is that I feel that there is a plane following me everywhere I go past 70kph.
    https://www.extremeterrain.com/tacoma-off-road-roof-rack-tt6617.html
  10. Jul 13, 2023 at 4:25 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    I've the redrock, HD roof rack and that is better than the design you have you can adjust the front fairing a bit, but yes at 70mph, before i got it lined up sounded like a plane! and gave the worst vibration..
    RedRock Tacoma HD Roof Rack TT12769 (05-23 Tacoma Double Cab) - Free Shipping (extremeterrain.com)
  11. Jul 13, 2023 at 6:50 PM
    TacoTuesday1
    FL
    OEM is flimsy plastic overpriced garbage but if it works for you it works for you.
    my Hooke road did have wind noise and reduced aerodynamics. I hope Prinsu and Sherpa are slightly better. Dropping the headliner to put insulation probably helps.
    I wonder if it’s worth spending the extra money on Sherpa or Prinsu to be one and done right the first time. Especially if they have shell racks to match.
    because that red rock looks like a marked up price Hooke and only slightly better. Especially if you already had aforementioned issues with it
    in fact those blue truck pics look exactly like a Hooke
    Which doesn’t extend far back either
  12. Jul 13, 2023 at 7:18 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    That link shows that they are discontinued, but thats exactly the kind of thing I am looking for. Do you know of anywhere other than Amazon that may have them? Thanks.
  13. Jul 14, 2023 at 6:25 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    I just checked it and for me it says 1 left in stock.
    That said, I got mine from Desert Rat Off Road. Looks to be same price and free shipping.
    PilotBoy352[QUOTED] likes this.
  14. Jul 15, 2023 at 3:01 PM
    dvto2
    Got a used oem thanks to Geeves77. I had a bit of trouble getting the drivers side on I think because the curve had straightened out a bit and the holes did not line up until I leaned heavily on the back edge of the rack. They look great and I love the swinging cross bars. Psyched to get my new canoe up to our camp in Ontario. Thanks to all.
    Normshark and wmb67 like this.
  15. Jul 16, 2023 at 3:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    OEM order from McGeorge Toyota and usually ships same day best online prices.
    Amazon or eBay all have many clones about $100 but lower quality from posts.
    All have a 160 lb max load so as long as you tie that canoe down to front end and rear end wind should be handled - don't drive at 80mph.
  16. Jul 16, 2023 at 3:24 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  17. Jul 16, 2023 at 4:13 AM
    dvto2
    i use the Thule brackets and straps and a pair of the ratcheting tie downs on both the front and back of the canoe to stabilize the ends from shifting side to side. The quick release ratcheting tie downs make getting into the hatch or tailgate a breeze.
    Normshark likes this.
