Tacoma Down!
Discussion in '1st Gen. Tacomas (1995-2004)' started by DHis2Dogs, May 1, 2025.
  1. May 1, 2025 at 3:23 PM
    DHis2Dogs
    DHis2Dogs [OP] New Member
    Dave
    2001 Toyota Tacoma
    So anybody have experience with a 2001 Tacoma being submerged in a creek? My son drive my truck into a creek front/passenger side was submerged which is where the aftermarket air intake is. Truck will start but will not continue running. No water in Oil. pulled the plugs and turned it over no water came out. Also no water in oil via the dip stick. Also changed the ECM still nothing but after replacing the ECM does spit a code of P1300 Which is igniter failure. But the truck will start just will not continue to run? Water did come out of exhaust when it did start and you can hear water in exhaust. Any helpful ideas would be greatly appreciated.
  2. May 1, 2025 at 3:33 PM
    02hilux
    Planet: EARTH
    Pictures of how deep it was submerged?
    The truck crank, runs, then shut off? Or just crank?
    I’m guessing the Crank sensor or wiring is soaked. How long has it been out of the water?
  3. May 1, 2025 at 3:41 PM
    DHis2Dogs
    Dave
    2001 Toyota Tacoma
    02hilux,
    It was in about 2 feet of water just the passenger side. Also yes it will start and run and when you accelerate or not it dies. It has been out of the water for almost 2 weeks. Bought an ECM from salvage place because some of the components looked corroded put it in last night and nothing changed but the codes when scanned. Now showing P1300.
  4. May 1, 2025 at 3:45 PM
    Clearwater Bill
    Billy
    Largo Florida
  5. May 1, 2025 at 3:46 PM
    02hilux
    Planet: EARTH
    The symptom almost sounds like a bad MAF. But it can also be a no IGF signal to the ECM and check your ground wires in the engine bay.
    theesotericone likes this.
  6. May 1, 2025 at 4:58 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    One thing worse than fixing a Flood vehicle….a Lightning Strike vehicle
    (Good News!)
    follow codes
    Buy both ignitors
    See what next code pops
    Moonrman likes this.
  7. May 1, 2025 at 5:41 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
  8. May 1, 2025 at 5:49 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
  9. May 1, 2025 at 7:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Resident Sub Captain is @Running Board Man
    His was completely submerged if I recall. He might be able to offer up some wisdom.
    Running Board Man likes this.
  10. May 1, 2025 at 7:11 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    That was my first thought.
    02hilux[QUOTED] likes this.
  11. May 1, 2025 at 8:54 PM
    Running Board Man
    Running Board Man Well-Known Member
    The truck was fully submerged but ran without replacing any parts... ecu was damaged so it idled at 3k rpm but other than that... nothing
    I forgot all my old toyota widom after working on and owning domestics honestly
    Area51Runner[QUOTED] likes this.
  12. May 1, 2025 at 8:57 PM
    Running Board Man
    Unplug pretty much every sensor not vital to the engine running
    So maf, both o2 sensors, throttle position sensor, coolant temp sensor... I've done this for vehicles that start but don't run to get them to stay running... helps isolate the problem
    renots, ztwatson and Area51Runner like this.
  13. May 1, 2025 at 9:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You need to address the P1300 code, Toyota disables fuel when it doesn't get an ignition feedback (IGF) signal from the igniter which would explain the start-run-stall and P1300 code.
    My hunch would be that water got in a connector and is pulling down the IGF circuit.
  14. May 2, 2025 at 6:33 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Buy a quality scanner that allows you to data stream each component and read faults of each module. I have a Launch. It scans all the modules for faults. They are expensive.
  15. May 10, 2025 at 3:48 PM
    renots
    renots 15mpgTaco just entered the chat
    Doug
    Southern Illinois
    04 Tacoma SR5 TRD OR 3.4L M/T 4x4
    OME suspension lift 882 coil overs Aftermarket UCAs and upper ball joints with zerks Arb bumper with warn winch All new dakkar leaf springs Diff drop kit Suspension parts purchased at wheelers off road 32” all terrains and nicer bullet hole rims.
    That’s just my game.
  16. May 10, 2025 at 3:59 PM
    renots
    Doug
    Southern Illinois
    Change the maf change engine oil just to be safe igniter is on passenger side, expensive but change that. We need to know how far you got in the water but this sounds identical to my situation. Passenger side only. Get a can of deoxit.
    If I can fix mine, you can too.
