Tacoma Drive line wrap/clunk.
Discussion in 'Technical Chat' started by Bearskill, Sep 6, 2009.
  1. Sep 6, 2009 at 6:46 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I just found this online and as of yet is the best explination for my prob. If anyone else is experiancing this, here you go
    "Thank you for your detailed reples. You have just eliminated the transmission and brakes from the situation here then.
    Your problem is in the rear driveshaft.
    First you need to be sure all the grease fittings have been well lubed on the shaft, a dry shaft will cause this and get worse over time.
    I have dealt with this on several toyota and Lexus vehicles in the last few years, it's much worse and more pronounced on the luxury line with automatic leveling suspension.
    What happens here is that when you brake for a stop it causes the truck to dip down in the front, ......this lifts the rear end up and extends the driveshaft so that the splines of the driveshaft extend outward in the slip yoke. When the truck comes to a full stop the rear end tries to settle and go back down, ......this does NOT happen because the weight of the turck is being suspended by a binding driveshaft, the splines hold position inside the slip yoke....then when you let off the brakesit unloads the rear driveshaft and allows it to rotate and force the splines back down into the slip yoke. If greasing/lubricating the shaft will not resolve this and it is a concern to you then a driveshaft replacement is the solution here. I hope that made sense......"
    Read more: http://www.justanswer.com/questions/1ssh6-fix-2005-tacoma-driveline-wrap#ixzz0QNdDqlUu
  2. Sep 6, 2009 at 6:49 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i clicked it and think im stupid..whats the solution?
    nevermind if greasing doesnt work then a new driveshaft sorry
  3. Sep 6, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Mostly what happens (with automatics) when you are stopping, power is still being sent to the axel. As the power is being sent, the pinion angle moves up, and when stopped, the brakes are holding it in that position. When the brakes are released, the axel is free to return to its original position, causeing a "Thump".
  4. Sep 7, 2009 at 9:36 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I bought my '06 with 40,000 miles on it. It had very noticable driveline clunk on stopping/starting from a stop. I figured it had not seen the 30k maintenance, so I greased all five zerks in the driveline. Dry as a bone. No grease came out as I slipped grease in. This greasing of the u-joints totally eleviated the driveline clunk noise. Grease is good.
    Now to get to the plugs....
  5. Sep 10, 2009 at 4:54 AM
    tacobale
    tacobale Well-Known Member
    I have an 09 Prerunner. I checked my u joints and I don't see any grease zerts. Should there be some?
  6. Sep 16, 2009 at 5:25 PM
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    Hey!, thats what that annoying thump is.I'm glad to hear that. I'm going to lube my shaft!:D
    Toyota was supposed to be lubricating the drive shaft already. They must not be doing what they are supposed to be doing. I'll have to try that.
  7. Sep 17, 2009 at 9:13 PM
    MGRS
    MGRS Well-Known Member
    '20 Tundra OR
    Using even Mobil 1 on my grease zerks made no difference.
    I got the TSB, the clunk went away until the springs settled. It came back, so I installed an AAL. The clunk left and is still gone.
  8. Sep 17, 2009 at 9:18 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Can someone post pictures of the zerks on 05+ Tacomas? I'm really interested.
  9. Sep 18, 2009 at 5:00 AM
    tacobale
    Aal ??
  10. Sep 18, 2009 at 5:13 AM
    Warren Thompson
    Warren
    Elko, Nevada
    AAL= Add a Leaf. This beefs up the rear suspension. Decreases axle wrap, thus less clunk. Greasing the zerks was the ticket for my '06.
  11. Sep 25, 2009 at 5:46 AM
    machman
    machman Well-Known Member
    NE Alabama
    03 DC PreRunner TRD V6
    What is TSB?
  12. Sep 25, 2009 at 5:55 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Prerunners don't have any zerks. The drive shaft is completely sealed for what ever reason. I hope you read this post before you go hunting for something that isn't there (like I did). Nearly drove me insane lying on my back, rolling around on my creeper for half a day! :D
  13. Sep 25, 2009 at 7:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    I get this in the Tundy
    Technical
    Service
    Bulletin
  14. Sep 25, 2009 at 10:58 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Man, I wish my truck had sealed shafts like that.:rolleyes: That's a really good idea. I wonder why they don't have this on all Toyota trucks?:confused:
  15. Sep 27, 2009 at 12:01 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I was only able to find three on mine.None on the front shaft and three on the rear universal joints.:confused:
  16. Sep 27, 2009 at 12:37 PM
    Warren Thompson
    Warren
    Elko, Nevada
    You will have to rotate the shaft to expose them. They are not as easy to see as the rear ones. Just feel around and you will find them. They are there.
  17. Sep 27, 2009 at 1:59 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    After adding the cheap helper springs, i no longer have this problem
  18. Sep 27, 2009 at 3:56 PM
    Warren Thompson
    Warren
    Elko, Nevada
    I too added the Superior helper springs. It made a big difference in stability and traction.
  19. Sep 27, 2009 at 5:03 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    OK,I looked again I did find 2 more grease fittings on the front universal joints. They are in the center of the universal. The rear ones are on the end of the universal joints.
  20. Sep 28, 2009 at 5:17 AM
    Warren Thompson
    Warren
    Elko, Nevada
    Just enough difference to throw you off. Doing your own maintenance is always fun!! Greasing those zerks will help in many ways!!
