Tacoma drives like a boat!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jrozz, May 6, 2015.
  1. May 7, 2015 at 12:57 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Of course it can be improved....slightly. If your chnages actually didn't make it handle somewhat worse, it would be a miracle. How you can raise a vehicle that much and put on this type tire and not expect worse handling is the bigger surprise. So, spend more money but don't expect a great improvement .
    Lowering and using lower aspect tires generally improves handling. Your asking for a low calorie Big Mac.
  2. May 7, 2015 at 1:06 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    holy crappy Caster Batman... How much preload are on your coilovers? If you have a lot you need to back it off a little and get caster set to 3.0 or as close as you can like everyone else probably told you already.
  3. May 7, 2015 at 1:23 PM
    Jrozz
    Jrozz [OP] Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    I knew it wasn't going to be better handling. Not asking for a perfect ride. Just was wondering what to expect, what was normal and if I could adjust anything to improve it a little lol
  4. May 7, 2015 at 1:26 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    My coilovers came with 1.5 inches of thread showing, icon said to not exceed 2" so I cranked it .5" and called it good. Icon said that amount of preload was fine.And this lifts me 3". I called the shop and they said they aligned to factory specs the first time. I'm taking it back and shooting for .0 camber and toe and 3.0 caster
  5. May 7, 2015 at 1:28 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    -0.5 camber
    +3.5 caster
    0 toe
    It will handle great, track straight, and fun to drive again.
    Jrozz[OP] likes this.
  6. May 7, 2015 at 1:32 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Take your sway bar off to see what a boat feels like.... I love it.
  7. May 7, 2015 at 1:33 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    Haha yeah I guess it can be worse! You do that for better off-road capability right?
  8. May 7, 2015 at 1:45 PM
    lemons
    lemons LOCO 4X4
    Virginia
    I have different springs on my icons but only have about 1inch-1 1/4 maybe of pre load with Total Chaos UCA's and have some caster issues also. the shop had bent the LCA alignment tabs and I had to loosen everything, hammer them back and weld them so they wouldn't bend anymore. so check your alignment tabs after they get done messing with it. also make sure they tighten the LCA bolts to 100ftlbs or you will most likely start hearing clunking noises from your front end.
  9. May 7, 2015 at 1:53 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Yep/ More flex and it makes the suspension actully independant
  10. May 7, 2015 at 2:21 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    You could back both sides off by .25 and not really affect the lift height very much. The upside is the ride and handling will be better. Definitely lose the sway bar
    Jrozz[QUOTED][OP] likes this.
  11. May 8, 2015 at 11:14 AM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    So I took it to re shop today and they are setting toe and camber at .0 and caster as close to 3.0 as possible. All the technicians came out and laughed at me and said I was an idiot but they would still do it for me. Is it that crazy to ask for that muxh caster?
  12. May 8, 2015 at 1:12 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You can take the advice of those who have Tacoma's and have had the alignment set to a specific setting, or you can take the advice of a bunch of alignment chain techs who set settings according to a range from a book.
    I'm not jumping on you, it's just time for you to quit analyzing the situation and just pick one and go :D
  13. May 8, 2015 at 2:02 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    They're the idiots. Take your money and your truck to professionals.
  14. May 8, 2015 at 4:48 PM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    haha no I get it. so I will need to take it somewhere else. they gave it back to me and said this was the best they could do.
    camber 0.3 caster 2.4
  15. May 8, 2015 at 7:58 PM
    #35
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Thats actually not bad. Might want to drive it a few days and see what you think.
