Tacoma earned its striped today at Gorman PICS
Discussion in 'Off-Roading & Trails' started by DAVE94LIGHTNING, Jun 8, 2011.
  1. Jun 8, 2011 at 10:58 PM
    DAVE94LIGHTNING
    DAVE94LIGHTNING [OP] Well-Known Member
    Bone stock truck with wheels and tires :) Low experienced driver too. We did the Pronghorn trail. DAMN that one hill climb was fun. :eek:
  2. Jun 8, 2011 at 11:18 PM
    DAVE94LIGHTNING
    Airing down for some fun
    Cannot believe that I made it up this hill. Insane
  3. Jun 8, 2011 at 11:22 PM
    StaticTaco
    StaticTaco Well-Known Member
    Mitch
    Oahu
    2011 SR5 4WD
    awesome looking pics! its really interesting to see how much a set of wheels and tires changes the whole look of a 'stock' truck.
  4. Jun 8, 2011 at 11:28 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Nice looking setup you got! Great rim and tire combo as well. White trucks are great for not showing the scratches as bad. Thats what Ive got.
  5. Jun 8, 2011 at 11:40 PM
    BIG MoFukin SERG
    BIG MoFukin SERG Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    Nice...Hungry Valley is a lot of fun...what kind of tires are those? Toyo's?
  6. Jun 8, 2011 at 11:41 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    You sir have a sexy truck
  7. Jun 8, 2011 at 11:52 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Did you wheel alone?... usually not a good idea... but looks like you had a good time
  8. Jun 9, 2011 at 3:09 PM
    DAVE94LIGHTNING
    Tires are BFG mud terrains.
    We aired down to 45psi and did the hardpack in 2wd, the soft river sand in 4 hi, the hills in 4 low and only used the locker on the big hill climb at the very top.
  9. Jun 9, 2011 at 3:20 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    :eek: I only run 32psi on the street try about 15psi to 20psi next time you will be amazed on how well your truck will do.
  10. Jun 9, 2011 at 3:21 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Nice pics man! Awesome wheel/tire combo. I like those BFG MT's better then the KM2's.
  11. Jun 9, 2011 at 3:24 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Air down to 20 PSI.
    45 isn't really airing down at all. When you start seeing the tire bubble is when you know you're starting to gain the benefits of airing down. Just don't do donuts while aired down, you're more likely to push the tire off the bead.
  12. Jun 9, 2011 at 5:03 PM
    DAVE94LIGHTNING
    Yes I'm used to my F-250 super duty. I ran 65 psi on street and dropped to 40 psi for sand. On the taco I run 60 psi street also
  13. Jun 9, 2011 at 5:03 PM
    DAVE94LIGHTNING
    Exactly why I hunted for them for so long. Not a huge fan of the KM2s
  14. Jun 9, 2011 at 5:04 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    holy crap dude! Thats a lot of PSI :eek:
  15. Jun 9, 2011 at 5:08 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    ...when you said earned its striped I thought you were referring to pin stripes from off roading in tight trails :drevil:
  16. Jun 9, 2011 at 5:09 PM
    JLee
    Jerry
    Grass valley CA
    Well sorry to tell you bud 40 is not low enough for these little trucks and running your tires at 60 is not good for your tires.
  17. Jun 9, 2011 at 5:12 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    you better quit that shit before you ruin your tires. run 35 tops.
  18. Jun 9, 2011 at 5:26 PM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Im pretty sure that those BFG MTs are 55psi max cold, so you should be running them at 45 to 50 psi on the street and air down to15 or 20 psi when offroading. but if they are 55psi max then you definitely cant run them at 35psi on the street, the side walls are not built for that. Im running the grabber red letter 33x12.50 r17 and the max psi for those cold is 36psi so yeah on the street i can run them at 30 psi on the street and i air down to 15psi all around in the soft stuff!:cool:
  19. Jun 9, 2011 at 5:31 PM
    RecklessTaco
    Topaz Lake, Nv.
    He cant run those tires at 35psi on the streets. those tires are meant to hold 55psi max cold so on the street he can only safely run them at around 45psi to 50psi! They are not the same as tires that only require 36psi max cold!
  20. Jun 9, 2011 at 5:37 PM
    CopDoctor
    Trinidad, CO
    how in the world did you know that? i've run all my bfg at 32-34..you know somethin I don't? ay wise guy!? :)
