Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Mar 14, 2018 at 6:54 PM
    #2061
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I could be wrong... But I doubt a larger heat exchanger would help such a small intercooler especially with heat soak. 7th injector with water/meth or e85 much more efficient
  2. Mar 14, 2018 at 6:58 PM
    #2062
    ThomasMore66
    Dallas/Fort Worth & Durango
    And what about emission inspection?
    loginfailed likes this.
  3. Mar 14, 2018 at 7:02 PM
    #2063
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    The menthol injection would be best it would cool down the charge air fast
    Roostfactor likes this.
  4. Mar 14, 2018 at 7:12 PM
    #2064
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    For me they just do the computer check with the odb2. It’d just be a matter if the ovtune shuts that off.....will the emissions inspection pick up on it, even if there are no cels???
    Roostfactor and loginfailed like this.
  5. Mar 14, 2018 at 7:32 PM
    #2065
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That’s what I meant about catalyst monitoring and P0420/P0430. The front o2 is what the ECM uses to run the engine. The rear o2 is how the ECM monitors the catalytic converter performance. It compares what it sees before and after the catalytic converter. If there is no cat or the cat is bad, it will set P0420/P0430 (catalyst efficiency below threshold). If we can turn that functionality off, the CEL won’t come on.
    Depends on where you live. Many places just use a computer to check your OBD2 port. If the ECM doesn’t have any codes and the emissions monitors are complete, it passes.
  6. Mar 14, 2018 at 7:45 PM
    #2066
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    All this is great to know. I have no rear cats now......in time I wouldn’t mind getting rid of the front 2 and having that tuned into the ecu.
    loginfailed[QUOTED] likes this.
  7. Mar 14, 2018 at 8:55 PM
    #2067
    ThomasMore66
    I passed TX emissions with no rear cats already.
    loginfailed and Roostfactor like this.
  8. Mar 14, 2018 at 9:39 PM
    #2068
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Might sound dumb but I'm going to use a product from red line called water wetter. Back when I built 2 stroke hi po motors it made noticeable temp drops even only mixed with water, no glycol. Kept motors together much longer. Wanted to hook up a temp gauge so I could do a before and after test. Online reviews are great. From industrial diesels to bb Chevy motors. I know it works, just want to see how much. I know red line to be great stuff, and it's only 10 bucks.
    5thGearPinned likes this.
  9. Mar 14, 2018 at 9:40 PM
    #2069
    Jesse
    Poulsbo
    15' DCSB OR S/C
    May the laughter ensue.
  10. Mar 14, 2018 at 11:30 PM
    #2070
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Water Wetter works great with water. Straight water is better at heat transfer than water/coolant mix.
    You might want to check that Water Wetter is compatible with our red/pink coolant.
    I don't think anyone has to worry about heat soak unless they were in high boost for extended periods of time. I.e. racing. Our system can easily accommodate 3-5 psi continuous boost and remain cool. The occasional romp of 10 psi lasts for maybe 10 to 15 seconds tops then your out of boost and the system cools back off.
    I have an intercooler inlet and outlet gauge and have seen a 30° temp differential between inlet and outlet for at least 3 minutes during a long incline going up a mountain. This was at freeway speeds though so the fmic had plenty of airflow. Long slow runs in deep sand where you are in constant boost combined with the torque converter not locked up would create the highest demand on both the intercooler and the engine cooling system.
    I have seen almost 50° max difference in inlet/outlet temps so our intercooler is definitely working!
  11. Mar 15, 2018 at 5:02 AM
    #2071
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    @loginfailed ....So if you have the emission stuff tuned off. Would you necessarily have to block off anything? Could you just leave everything as is??
  12. Mar 15, 2018 at 5:13 AM
    #2072
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You could just leave it on there if you wanted to.:thumbsup:
  13. Mar 15, 2018 at 5:35 AM
    #2073
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks for the data share. My over active brain thinks of how to improve things. Toyota really did their homework on making this supercharger for this truck.
  14. Mar 15, 2018 at 5:50 AM
    #2074
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I definitely like the sound of that. I think adding in the disabling of emissions & cat monitoring will be in my future.
  15. Mar 15, 2018 at 6:46 AM
    #2075
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Water wetter works great. Especially when pushing an engine to the limits for extended periods. Redline Oil products are made by engineers that race their vehicles and constantly tinker to improve.
    Roostfactor and 5thGearPinned like this.
  16. Mar 15, 2018 at 6:48 AM
    #2076
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Do you run it? Or just recognize it being a good product?
  17. Mar 15, 2018 at 7:07 AM
    #2077
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Ran it on all out race bikes back when I was a tech. It's a great product and works great. I can't imagine anything on our trucks bein an issue with running it so long as you flush out any glycol based coolant good first.
  18. Mar 15, 2018 at 7:12 AM
    #2078
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Water Wetter definitely works, ive been using it on all my two stoke dirt bikes for the last ten years at least. The stuff I have though doesn’t keep the water from freezing however.
  19. Mar 15, 2018 at 7:27 AM
    #2079
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's understandable. Definitely a warm climate liquid.
  20. Mar 15, 2018 at 7:51 AM
    #2080
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Sorry to be a party pooper..... but @OVTune Where's the complete list of added ECUs that you said was going to be appended to the original post?
    My TRD ECU calibration file 3YWG2900 is STILL not recognized on my OVT Handheld.
    Brice, Norton and tblizzard like this.
