Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Mar 15, 2018 at 8:46 PM
    #2101
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    speed limiter, CEL no problem (it would help to know exactly which CELs your truck gets you can use the handheld to read CEL codes)
    as for some of the other things you listed I don't recall ever saying I can remove key alarm noises, seat belt noises.. I don't recall even ever talking about this.
    also you can't get any actual or accurate horsepower measurement from a gauge
    your AFR is 9.6 through an entire pull or just at shifting or?
    I just posted 1-2 days ago I'm working on the TCU for the SC tunes. Updating the tunes on the handheld is super easy when updated tunes roll out. Updates are no charge just like 3rd Gen.
    Roostfactor, Brice and stickyTaco like this.
  2. Mar 15, 2018 at 8:49 PM
    #2102
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Don’t sweat it Mat, just keep doing your thing. People should know this is all rather new and bugs may have to be worked out here and there.
    Roostfactor, bdbrown and PapaBear like this.
  3. Mar 15, 2018 at 9:02 PM
    #2103
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Funny thing is I ordered and received my self tune kit back in early November for the pre BF sale and I’ve done nothing except get my files sent in and now am ready to head to my shop for tuning using the “new” software. @dbs1 even having the plug and play option, you’re much farther ahead than anyone would have expected by now. I know some trucks were tuned pre production and had medium results, but tuning takes time, especially when it’s all new. 3 months is nothing, if I recall from first thread in the 3rd gen section on OVTune, it was almost a year or over a year ago, and he just finished (for now) a solid tune available for the 3rd gen. Something good comes your way, but you pay the price in time.
  4. Mar 15, 2018 at 9:06 PM
    #2104
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you guys only knew the heart aches associated with getting a good tune on a standalone for my truck. You'd be happy it is only months. It's taken years of money, time, and battles. This is nothing, but part of the process. Checks and balances will get it all sorted out in due time. Quicker and easier than my venture, for certain.
  5. Mar 15, 2018 at 9:08 PM
    #2105
    PapaBear
    Austin
    SIN CITY
    The man has spoken :D
    Roostfactor and Brice like this.
  6. Mar 15, 2018 at 9:08 PM
    #2106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :hattip:
    PapaBear likes this.
  7. Mar 15, 2018 at 9:10 PM
    #2107
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    If you have done a standalone you know this is true, this is why I am patiently waiting for everything to be complete.
  8. Mar 15, 2018 at 9:14 PM
    #2108
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Where are you getting your tune done @PapaBear?
  9. Mar 15, 2018 at 9:18 PM
    #2109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers:
    bdbrown and arcenik[QUOTED] like this.
  10. Mar 15, 2018 at 9:22 PM
    #2110
    PapaBear
    Austin
    SIN CITY
    Rogue Offroad... When I'm not either working, dealing with family, or just busy in general :rofl:
    Already went down and talked with them since I had to pick up a part for my lift as well. My intention isn't to go straight for it at first, my first 3 hours with them will be a few full stock runs and then my simple add ons to get some solid dyno numbers for myself, then well play around with the files and figure things out as we go, of course asking for help when we need it.
  11. Mar 15, 2018 at 9:27 PM
    #2111
    OVTune
    OVTune
    OP is updated with current information, upcoming developments, etc
    Right now you have tunerpro based XDF / Defs right?
    my software I've build from the ground up for this is damn near completion, expecting by the end of the month, and will be better. I will update you to this once it is release. Much more maps, much better control. And Helpful information on maps that give explanations and simple tune examples. (and what not to do)
  12. Mar 15, 2018 at 9:28 PM
    #2112
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    I've had multiple vehicles tuned by folks on a dyno. Certainly a more precise way to do it, but I was not as concerned with hp on this truck as I was with those.
    My 3 big focuses where-1. Getting rid of the bothersome cel. 2. A little more hp. 3. A little more mpg.
    My last wot here at 6500' elev, prior to the tune showed 325hp on the aeroforce gauge (at the crank). I believe it to be fairly accurate based on dragstrip mph, but really it has helped to show what I've gained with each mod, IF weather conditions are similar. A quick run yesterday at 45 degrees here showed 307hp. Again, very cloudy, so obviously affected.
    And even a mpg test from a month ago is hard to square with what I observed today. But the other items are more black and white, and as mentioned, maybe those are going to be in tune 2.1??? I'd sure like to see this cel eliminated as well as the pig rich condition at wot and a few of these other things noted that the tune would accomplish.
    Roostfactor and PapaBear like this.
  13. Mar 15, 2018 at 9:30 PM
    #2113
    PapaBear
    Austin
    SIN CITY
    Yes, got the latest xdf from you probably month and a half ago lol just haven't had time to head down.
    Right on, I'll be here.
    Preach
  14. Mar 15, 2018 at 9:32 PM
    #2114
    OVTune
    OVTune
    a lot of the TCU stuff for the SC will be in the upcoming update yes.
    A better explanation of your AFR would be helpful. 9.6 through an entire pull? Only when you first get on it? When it shifts?
    however seat belt alarms, key alarm noises, and anything else like that will not.
  15. Mar 15, 2018 at 9:45 PM
    #2115
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    3YWG4000 is still not showing up, as of 2230 MDT. Plan to check again tomorrow.
    Thank you.
    tblizzard likes this.
  16. Mar 15, 2018 at 9:52 PM
    #2116
    OVTune
    OVTune
    I didn't receive a confirmation email yet so likely will be tomorrow
  17. Mar 15, 2018 at 9:58 PM
    #2117
    D-Rose
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Nice, they seem like a pretty good shop from the Vegas FJ page. I'm more of a DIY guy so haven't had a reason to go yet. If they can do tuning too though that's pretty badass like a one stop shop.
    PapaBear[QUOTED] likes this.
  18. Mar 15, 2018 at 10:07 PM
    #2118
    PapaBear
    Austin
    SIN CITY
    They can't do tuning per say for your truck as well being they don't have the ability to themselves, they're just willing to take a swing with @OVTune 's software that I provide on my own, though if I remember correctly they said something about trying to become an ovtune distributor because one of their guys is running the handheld on his 3rd gen.
  19. Mar 15, 2018 at 11:33 PM
    #2119
    dbs1
    Dan
    I guess I could go back and specify what posts where you addressed questions from I and others on getting rid of the buzzer for the seat belts and ignition as well as the speed limiter, but that's hardly what I'm interested in.
    Your dyno report showed 20hp which would be great. 1-2 more mpg would be fantastic. I've had the aeroforce gauges on a couple of different trucks and what they show as crank hp seems to line up with mph in the qtr. I sure wouldn't claim they are super accurate, but I believe they are accurate enough to tell what gains are from mods, IF weather conditions are similar. Within 5-8 hp on similar weather days would be close enough to tell me something. As stated..weather conditions are not close enough to hang my hat on either mpg or hp right now. The other items including the cel and AR are just what they are. The exact code I can look up via the aeroforce gauge, but I'm sure it's the same one that's been on related to cat inefficiency, due to the front cats being removed with the headers in place, regardless of the 02 sims.
    I get it's a hassle and I'm sure there will be updated tuning, but I'm reporting the results I'm seeing right now. Nothing more or less.
  20. Mar 16, 2018 at 2:31 AM
    #2120
    tblizzard
    tblizzard Well-Known Member
    He never said that he had the ability to remove the "buzzer for the seat belts or the ignition" once in this thread, but you did mention it a few times in the past. I did a search in the thread, check it out for yourself.
    Brice, jojotoo and taco2010trd like this.
