Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Mar 21, 2018 at 8:31 PM
    #2201
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    What’s your end game? The ucon can control a 7th injector while the ovtune cannot. Ucon has the guardian feature. But if you have the trd flash the ucon won’t run optimally unless you get an ecu with the stock flash. The ov tune is a lot less pricey and no need to swap your cam gears.
  2. Mar 21, 2018 at 8:36 PM
    #2202
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Depending on cost I’d be interested in one for the 2.7 and the 4.0
  3. Mar 21, 2018 at 8:53 PM
    #2203
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    Good question.
    I don't know.
    I have the TRD flash.
    I would like more power, but I love it as is too.
    It is still a ways out so I have not really decided, so far the rough llan has been
    Spec U headers, custom mid pipe
    2.7 pulley, maybe 2.85
    Staying on pump gas, considered e85 but not worth the headache finding fuel.
    Water meth, and cooler upgrade I tow a lot and have been thinking of cooling the charged air more.
    Current lifetime MPG is 11.5, not a big concern but leaning it out some coukd helpn plus i would not have to clean the bed side as much!
    I love the roots power delivery, would like to stretch it a bit more but want to keep the roots.
    I would like to ditch the cats, and would rather run 6 larger injectors if needed than run a 7th.
    Really do not have huge plans, just would like to add a little more and also actually have it tuned.. vs the TRD flash which just appears to dump fuel in.
  4. Mar 21, 2018 at 11:51 PM
    #2204
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Several people (myself included) are already running the non SC tune. If your waiting you will like it. Nothing crazy like a SC but its a nice additona for the N/A folks.
  5. Mar 22, 2018 at 7:19 AM
    #2205
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    The handheld got a nice update last night. I won't be ripping out the UCON to try to connect again until there's a list of ECUs.
  6. Mar 22, 2018 at 7:20 AM
    #2206
    ThomasMore66
    Dallas/Fort Worth & Durango
    Get a supercharger. Your life will be better. Women will want you.
  7. Mar 22, 2018 at 7:21 AM
    #2207
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The panties come off before the booty even hits the seat.
  8. Mar 22, 2018 at 7:57 AM
    #2208
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    First page, first post. :thumbsup:
    Roostfactor likes this.
  9. Mar 22, 2018 at 8:58 AM
    #2209
    Voodoo Rufus
    Bakersfield, CA
    Sweet. But mine still is waiting in the wings.
  10. Mar 22, 2018 at 9:30 AM
    #2210
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    :D
    Konvict KROG likes this.
  11. Mar 22, 2018 at 10:32 AM
    #2211
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @OVTune @tblizzard
    89661-04J80
    tblizzard likes this.
  12. Mar 22, 2018 at 12:59 PM
    #2212
    Taco Reaper96
    Taco Reaper96 Well-Known Member
    2008 Black Tacoma TRD Offroad
    Fog Light Mod, Kenwood Head
    Recently took notice of how cheap v8 swapped s10's are around here. Eyeing that instead of the overpriced superchargers. Rather break that then my DD. Race truck and a mud truck. Best of both worlds!
    StuckinOhio likes this.
  13. Mar 22, 2018 at 2:40 PM
    #2213
    tblizzard
    tblizzard Well-Known Member
  14. Mar 22, 2018 at 8:58 PM
    #2214
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    No, he didn't. Shows how much you think you know, but don't.
    He an I are trading emails and although you'd like to think you're informed...you're not.
    Maybe you should just take care of the man in the mirror. I'm guessing that guy has got plenty of work to do...
  15. Mar 22, 2018 at 9:01 PM
    #2215
    dbs1
    Dan
    It's an easy fix. Don't read it. Just put me on ignore and erase the chalkboard.
  16. Mar 22, 2018 at 9:02 PM
    #2216
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That gave me a good laugh! Night all!
  17. Mar 22, 2018 at 9:14 PM
    #2217
    dbs1
    Dan
    Matt. I'm not going to bust your hump here, but this is the problem I have with ovtune...you give dates when your product and/or service will happen, and then it doesn't happen, even after YOU give dates it will happen.
    In response to your above quoted post here...I responded to your email that YOU stated-"should have the revised tune over to you tonight". That was an email you sent me Monday. No revised tune was sent. Had you simply emailed me that it might be a few weeks as you needed to catch up on other tunes, then fine. Just telling me something that doesn't happen is where I get my undies in a wad, especially when I'm responding to something YOU stated, that I take as your word as when things will happen.
    If I haven't received a revised tune in a couple of weeks, I'll email you. Thanks.
  18. Mar 22, 2018 at 9:16 PM
    #2218
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  19. Mar 22, 2018 at 9:22 PM
    #2219
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    :popcorn:
    Monitoring
    drama is fun.
  20. Mar 22, 2018 at 9:24 PM
    #2220
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    This thread has more BS than the Norcal threads
    outlawtacoma, nudavinci64 and Norton like this.
