Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Apr 4, 2018 at 11:41 AM
    #2321
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I do not remember one way or the other.
    Thank you.
    inwood customs likes this.
  2. Apr 4, 2018 at 9:11 PM
    #2322
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Thanks, @OVTune. File received and loaded successfully. Only about 20 miles driven with the new tune, but the truck is definitely more responsive and smooth throughout the power curve; butt dyno says it pulls stronger as well.
    Your problem (i.e., being too busy) is a positive indicator for your business, at least in the short-term. Unfortunately, unfulfilled promises generally result in disappointed customers, which will have the opposite effect on your company's long-term stability. I echo recommendations others (including you) have made - "finish up this pending ECU list" before hyping new products or opening additional order lines. I realize that means some have to wait but, IMO, making and fulfilling reasonable commitments to your customers is better than setting them up for disappointment by establishing unattainable goals for yourself. You're selling a unique and highly desirable service. Let that, rather than overly optimistic promises, sell your "products."
  3. Apr 5, 2018 at 8:25 AM
    #2323
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Thanks. It's actually what I have been trying to do and work on, I still get a ton of requests but I am not re-opening orders until all other ECU versions are setup. The DIY software has been in the works long before I even joined this forum, as it actually began for Tundras.
    There will be an updated list for the ECUs on the main page soon.
    At the bottom of the main page will be list of original format ECUs that will require I have a version of this ECU in hand to support
  4. Apr 5, 2018 at 11:11 PM
    #2324
    Norton
    I was asked via PM if I experience this issue. Figured I'd post my very limited experience here for everyone's SA... I'm only up to about 50 miles on the tune, but I definitely have NOT experienced any abrupt throttle transitions. If anything I find throttle response SMOOTHER than before. Obviously, I have many more miles to drive before hitting "several thousand," so YMMV.
  5. Apr 6, 2018 at 3:58 PM
    #2325
    tblizzard
    tblizzard Well-Known Member
  6. Apr 6, 2018 at 4:53 PM
    #2326
    mattvan
    mattvan Member
    Is anyone else getting s*** mileage after flashing the 91 tune for n/a? I'm running 91 gas and driving like a grandpa and i went from 15mpg to 10mpg
  7. Apr 6, 2018 at 4:56 PM
    #2327
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  8. Apr 6, 2018 at 5:31 PM
    #2328
    OVTune
    OVTune
    this is one of the very few calibration versions that we need a physical ECU with this exact CAL ID.
    Does not sound normal, what mods do you have?
  9. Apr 6, 2018 at 5:36 PM
    #2329
    mattvan
    mattvan Member
    I have a drop off mbrp catback and a drop in air filter. 33 inch tires and a 3 inch lift. Some armor. I was getting around 15 with all of my stuff on before.... I'm gonna try the other tune file with 91 gas tomorrow and see if it gets any better. Any suggestions @OVTune ?
  10. Apr 6, 2018 at 6:23 PM
    #2330
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Mine has stayed around 15.5 and I’ve been flooring it all over town. But I do have probably the lightest wheel tire combo for 255/75r17 that you can get.
  11. Apr 6, 2018 at 6:23 PM
    #2331
    OVTune
    OVTune
    For people who have *original* file ECUs (I'll have a list) and have the handheld, which we need a ECU of it to support, I will offer a $200 refund from your handheld purchase if you can send your ECU. (and I will cover shipping)
    (will have list of ECU versions that are needed)
  12. Apr 7, 2018 at 3:28 PM
    #2332
    tblizzard
    That may be an issue Mat, a lot of us daily drive our trucks. I thought you ordered some ECU's from Toyota for this process?
    loginfailed likes this.
  13. Apr 7, 2018 at 3:46 PM
    #2333
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think that’s why he’s offering the $200 discount.
    Norton likes this.
  14. Apr 7, 2018 at 4:48 PM
    #2334
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    o_O
    Edit: just saw his post about that.
  15. Apr 7, 2018 at 4:51 PM
    #2335
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Might be able to do that for my 30433300 ECU Cal ID if needed. Just have to arrange a work truck to use for a week.
    tblizzard likes this.
  16. Apr 7, 2018 at 6:32 PM
    #2336
    tblizzard
    I get that, but I'm just saying it's going to be difficult finding some one plus his previous post mentioned that he had the ecu for this specific calibration.
  17. Apr 7, 2018 at 7:14 PM
    #2337
    OVTune
    OVTune
    I will post the ECU ID list of ones I can't get. I have some.
    This is why I am offering up some incentive. Some of these ECU IDs it's just not possible to get any other way except having the actual ECU
    bobsuruncle likes this.
  18. Apr 7, 2018 at 7:15 PM
    #2338
    tblizzard
  19. Apr 8, 2018 at 11:12 AM
    #2339
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    What kind of turnaround time are you expecting, to grab what you need off the ECU and ship it back out?
  20. Apr 8, 2018 at 1:53 PM
    #2340
    Jesse
    Poulsbo
    15' DCSB OR S/C
