Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. May 19, 2018 at 2:37 PM
    #2661
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I just got my handheld back from mat. It was unable to load to my handheld from my, or others computer. I asked for a refund but that isn't going to be the case I see. Without instructions I guessed and loaded a tune. I am impressed with how it runs. Idles smoother than before, and it was smooth to begin with. Through the revs it really goes. More of a hp punch than when I changed pulleys! There is too much traffic now for me to do further testing. Later on today I will. The limited communications are frustrating for me too. I dont know what tune I've loaded, if or when I can change it. Must i always mail the tuner back via ups and wait for it to return? I hope these issues can be resolved. Upside is mat really knows what he's doing. I'm very impressed with the results.
    rockporttaco and rheath08 like this.
  2. May 19, 2018 at 3:01 PM
    #2662
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I simply need more space for testing. Its challenging to view afr #s as I'm dodging cars. Initial but dyno is a conservative (A)! If the bugs get worked out and communications improved this ovtune has amazing potential.
  3. May 19, 2018 at 3:02 PM
    #2663
    ThomasMore66
    Dallas/Fort Worth & Durango
    Afr’s better? Shifts better?
  4. May 19, 2018 at 3:10 PM
    #2664
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Gopro
  5. May 19, 2018 at 3:11 PM
    #2665
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The afr gauge is hard to focus on when in heavy traffic. The glance I took on the freeway was 10ish. Granted, I'm running meth. Might need that on off switch on my meth today for testing. Transmission seems unchanged. If anything it needs the ratiotek kit more than ever.
  6. May 19, 2018 at 3:13 PM
    #2666
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I have seen your emails, but as I mentioned I still am working on getting everyone elses done. I do recall in the beginning you asked for so many things, much of which was never even offered or even said possible. There are people I am working on getting their ECUs finished and tunes setup. I recall telling you that I would do custom things, transmission shift updates, etc after that. The process has been painfully slow and if you check I have even considered to stop using the handhelds in the future because of how the software and updating process is so slow and ever since they updated to the 3+ version handhelds it has been buggy, The customer I quoted below is a perfect example. For some, totally unknown reason he tried on multiple computers and can't even load the software. Why? No idea. I wish I knew. I am trying to take care of customers that are still having issues with their original purchase before I start going into custom / fine tuning later.
    As I said below while my site is down I am putting a new system in place so that it will no longer be to just email me.
    I thought the plan was that we talked you would flash the "original" so to return it because for some reason the software would not work on your computer. There are 2 tunes in it, a 91 and 93, and are labeled, you had to flash one of them.
    I am working on a new system for communication, part of the reason my website is down, I am putting an all new system in place so that it won't just be to email me anymore and wait. Things get lost, get delayed, and it's not working as good as it should. Part of the reason for taking my site down, I'm redoing everything so that I can better communicate with my customers and get back to them quickly.
  7. May 19, 2018 at 3:14 PM
    #2667
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Without knowing what was altered I can only guess. A second opinion would be great but I dont have anybody here that cares. Maybe I'll hit up @crashnburn80 for his thoughts. He's local.
  8. May 19, 2018 at 3:16 PM
    #2668
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Mat @OVTune. I understand all the work you are doing. Bottom line, the product you turn out is great.
  9. May 19, 2018 at 3:18 PM
    #2669
    OVTune
    OVTune
    send me a PM I can tell you exactly what's altered.
    Also I want to expand a little further on why things have taken so long and communication has been dismal. I know I could do better and I know that my communication with you guys has been, well shitty. It is my fault and I accept that, and am trying to get a new system setup so this does not happen again. I've taken my site down so that there are no new customers until then. I want everything done, updated. I'll be honest here ever since I started doing the 3.5L tacoma I've been up to my eyes in stuff. The 3rd gen trucks are a never ending problem-fest. Two trucks exactly alike, run completely different. It's been rather difficult.
    It's not in any way any 4.0L's fault.
  10. May 19, 2018 at 3:22 PM
    #2670
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Must have been a misunderstanding on my part. I thought I had to mail it back a second time for a return option. When I got it today it said factory ecu already loaded. So I didnt know what to think. I loaded the 93 tune. Any guess what hp change that could be? Should I experiment with the start time on the meth? Once again, great job. Drives like I've got one notch smaller pulley. Smooth running from idle to redline.
    rockporttaco likes this.
  11. May 19, 2018 at 3:25 PM
    #2671
    OVTune
    OVTune
    Yea unfortunately these handhelds are picky.. but if you load the "original file" now it will go back to stock then you could erase your VIN from it then it would be possible to return. Meth would definitely be a great upgrade for these I think. I can't recall the pulley size of the truck I did testing on but the blower definitely got hot, and if people go smaller I could only imagine they are blowing fire in the engine after running it hard. Anything that cools down intake temps + boost octane is a plus. Although if you spray a lot fuel will need trimmed out
  12. May 19, 2018 at 3:33 PM
    #2672
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I am running meth. I might go crank it up. Before your tune I could run it hard on the freeway, pull over, and check. My supercharger wasn't even warm. Like you could hold an infant's hand on it without problem.
  13. May 19, 2018 at 3:34 PM
    #2673
    tblizzard
    tblizzard Well-Known Member
  14. May 19, 2018 at 3:58 PM
    #2674
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Letting you be the guinea pig first. :)
  15. May 19, 2018 at 4:08 PM
    #2675
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That I am. Respect your feedback. Good to compare similar tunes trucks.
    crashnburn80[QUOTED] likes this.
  16. May 22, 2018 at 4:42 PM
    #2676
    qjwright
    qjwright Well-Known Member
    Quintin
    2017 trd sport
    does anyone know a good tuner(device) or tuning company for a 2015 4.0 naturally aspirated? Haven't had any luck finding one.
  17. May 22, 2018 at 4:46 PM
    #2677
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'd say wait for ovtune to get theirs out. If it's done as well as supercharged applications it's worth the wait.
  18. May 22, 2018 at 5:07 PM
    #2678
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I have a NA 2014 and bought one of the few handheld tuners OVTune sold for the NA trucks and I’m thrilled. Just wait till he puts them back on the market. He’s the only one that tunes the Engine ECU...all the rest add an additional module to try to modulate the signals in and out.
  19. May 22, 2018 at 5:13 PM
    #2679
    Jesse
    Poulsbo
    15' DCSB OR S/C
    What kind of hp gains do you estimate? Are you on a 91 or 93 tune?
  20. May 22, 2018 at 5:25 PM
    #2680
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    HP gains?? I’m not good at estimating that BUT I can tell you there IS more power... but additionally and maybe more importantly, it’s the improved shift points and the removal of the lag from pressing the gas pedal until the engine responds that makes my truck quicker and much more fun to drive!!
    Only had 87 or 91 tune files from OVTune but I run 93 Octane.
