Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. May 22, 2018 at 5:27 PM
    #2681
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Same here. I have the s/c and it really woke up. Cant wait for further adjustments.
  2. May 23, 2018 at 10:50 AM
    #2682
    tblizzard
    tblizzard Well-Known Member
  3. May 23, 2018 at 2:53 PM
    #2683
    tblizzard
    @White lightning boosted cool dude, is it on a stock pulley?
  4. May 23, 2018 at 4:01 PM
    #2684
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No. I have a 2.8 now going to a 2.55
    Athlaos and bobsuruncle like this.
  5. May 23, 2018 at 5:58 PM
    #2685
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ovtune on a stock pulley is more impressive than going from stock to a 2.8 pulley without tune in my opinion. By more than a little bit too. So I'm debating a quick change pulley or just committing to a 2.55.
    Athlaos likes this.
  6. May 23, 2018 at 7:42 PM
    #2686
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    z0mg, where is my damned ECU on the list.....
  7. May 23, 2018 at 8:01 PM
    #2687
    tblizzard
    Cool man, I got a 2.8 pulley. I can't say that I can't wait, because I've been waiting........... :jerkoff:
  8. May 23, 2018 at 8:03 PM
    #2688
    tblizzard
    Going to install the sc once I got the tune ready to go.
  9. May 24, 2018 at 4:44 AM
    #2689
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To follow up, was 30426300 ever added @OVTune ?
  10. May 24, 2018 at 6:49 AM
    #2690
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    I'm running a 2.55 pulley the OVTUNE. At wot it is still running rich. What air your a/f ratios ? And yes the tune did wake my truck up a lot.
  11. May 24, 2018 at 6:54 AM
    #2691
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Perfect at idle and light driving. Hard to get a wot here with traffic. 10's? But I have meth that's affecting #s too.
    rockporttaco likes this.
  12. May 24, 2018 at 7:56 AM
    #2692
    qjwright
    qjwright Well-Known Member
    Quintin
    2015 black Tacoma TRD sport
    Interested in buying this, how much does it cost, and are they even available at the moment?
  13. May 24, 2018 at 8:00 AM
    #2693
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    At the moment no. He is still work out some issues with the first batch. When that is done he will release more for sale
  14. May 24, 2018 at 8:34 AM
    #2694
    ThomasMore66
    Dallas/Fort Worth & Durango
    So you just have the hand-held? No special tune?
  15. May 24, 2018 at 10:00 AM
    #2695
    qjwright
    Quintin
    What about the actual tuning device?
  16. May 24, 2018 at 10:15 AM
    #2696
    rheath08
    Russell
    Bakersfield, CA
    that's what i was taking about.
  17. May 24, 2018 at 10:19 AM
    #2697
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Need Tune...
    Mas Powa..
    Can't wait any more.. I'm dying..
    BillDaCat8 and rheath08 like this.
  18. May 24, 2018 at 10:29 AM
    #2698
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Waiting is how things are going to be. As an early buyer, and pursuing aggressively I still waited a couple months. And I was one of the lucky few. It is worth the wait. I still need further updates that are going to take time.
    bobsuruncle and XPOTRPR like this.
  19. May 24, 2018 at 11:33 AM
    #2699
    ThomasMore66
    I have Amazon Prime! I expect things tomorrow. Sheesh.
  20. May 24, 2018 at 11:35 AM
    #2700
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Totally agree. I've just been waiting for Years for a 09 solution.. and now that it's within grasp.. it's Killin me. Lol
    But also this... Lol
