Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. May 24, 2018 at 5:15 PM
    #2701
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Me too on prime. Just got new plugs, but have to wait to find help to do it. No wrenching allowed here. I get the waiting game. At least there is a great option to look forward to. Much better than my dating life.
    XPOTRPR likes this.
  2. May 25, 2018 at 12:50 PM
    #2702
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lmao! ugh, plugs were a pita. which method you gonna do? removal or non?
    and agreed.. which makes it that much harder.. I want the good stuff!!
  3. May 25, 2018 at 1:13 PM
    #2703
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Spark plugs that is. Is there a way to do it without removing the supercharger? If so I'd like info on that.
    XPOTRPR[QUOTED] likes this.
  4. May 25, 2018 at 1:15 PM
    #2704
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Pickup a set of swivel sockets and I am told it can be done.
  5. May 25, 2018 at 1:27 PM
    #2705
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yep. I'm not sure where the thread is, but a quick search should pull it up.. even just googling it. I went with the removal method, because I didn't feel like searching for and buying tools and making it all work... BUT.. after doing it that way, I would probably try the non removal method first. Especially if you haven't broken that factory seal yet.
    Pretty much. I think there's a couple other little details iirc.
  6. May 25, 2018 at 1:29 PM
    #2706
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    You don't even need swivels. Just a few short extensions.
    XPOTRPR likes this.
  7. May 25, 2018 at 2:14 PM
    #2707
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I've got lots of those. Thanks a lot fellas. I wouldn't have known.
    XPOTRPR likes this.
  8. May 25, 2018 at 2:36 PM
    #2708
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    really? nice.. I just read all the threads referring to swivels... and I guess extensions too... but the swivels were what I didnt have on hand.
  9. May 25, 2018 at 4:14 PM
    #2709
    Voodoo Rufus
    Bakersfield, CA
    I use two short extensions. First I drop the spark plug socket into the well. Then feed one extension in and plug into the socket. Then feed the second into the first. Then unscrew the spark plug. Remove in reverse order. Installing the plugs I use a plug socket with no rubber inside that will keep you from removing it when the plug is tight.
    Tried downloading my ECU again to no success. Guess it'll have to wait for OVTune to return from overseas.
    jojotoo likes this.
  10. May 25, 2018 at 4:53 PM
    #2710
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks so much for the instructions. I wouldn't have thought to use a socket without the rubber cushion.
  11. May 26, 2018 at 6:42 AM
    #2711
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    Yes that's correct. The handheld came with a 91 tune and a 93.
  12. May 26, 2018 at 8:20 AM
    #2712
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Just not sure what you do if you add more mods. Have a 2.6” pulley waiting for install.
  13. May 26, 2018 at 10:28 AM
    #2713
    tasq
    tasq Active Member
    Dave
    Colorado
    '13 TRD Off-Road
    Wait, your handheld came with tunes already on it? I thought we had to send off ECU data and wait?
  14. May 26, 2018 at 11:16 AM
    #2714
    tblizzard
    tblizzard Well-Known Member
    He possibly bought it from someone. 2nd hand
    If you bought it new, you have to send Mat your data file, and from there he sends your tune
    tasq likes this.
  15. May 27, 2018 at 5:26 AM
    #2715
    rockporttaco
    Henry
    Rockport
    S/C 4x4
    I bought it brand new in February. Matt sent me a tune 4 months later.
  16. May 27, 2018 at 5:27 AM
    #2716
    rockporttaco
    Henry
    Rockport
    S/C 4x4
    Slap it on. The trdtune can handle it just as long as you have an upgraded fuel pump
  17. May 27, 2018 at 7:23 AM
    #2717
    ThomasMore66
    That’s the plan. Need to put the shift kit in the trans at the same time. Planning...
  18. May 27, 2018 at 9:43 AM
    #2718
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You'll love the combo. :cool:
    I've had my IPT kit in for about 4 years now.. added the 2.6 about 6 months ago.. it's damn fun. All I'm waiting for now is the tune. Gives me time to grab an E fan setup before then too i guess.
  19. May 27, 2018 at 12:07 PM
    #2719
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I cant wait to catch up to you guys!
  20. May 27, 2018 at 12:18 PM
    #2720
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Want me to make you a 2.0"?
