Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Jul 24, 2018 at 9:48 AM
    #2901
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  2. Jul 24, 2018 at 10:02 AM
    #2902
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Gonna go giver er a test right now. will update.
  3. Jul 24, 2018 at 10:05 AM
    #2903
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    see post above :
    These are all added, will be available by handheld software update next business day italy (this evening)
    they aren't in the update yet, they are submitted for update tonight
  4. Jul 24, 2018 at 10:09 AM
    #2904
    Brice
    Brice Turbo Member
    Brice
    Texas
    Ah my bad then. I just saw the numbers that matched mine and didn't read to much else.
    bobsuruncle likes this.
  5. Jul 24, 2018 at 10:22 AM
    #2905
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Patience, young Padawan.
  6. Jul 24, 2018 at 6:09 PM
    #2906
    smokierfrostie
    smokierfrostie Active Member
    Bozeman MT
    2015 Tacoma TRD PRO
    TRD Supercharger with a Magnuson fit kit, Volant CAI with scoop, JBA Off road Upper Control Arms, 1.5" rear Blocks to level out the TRD Pro stance, Rough Country LED Light Bar, Rough Country Step Bars, JL Stealth Box, Truxedo LoPro Tonneau cover, Anzo Tail lights
    When are you going to add 3YWG4300 TRD SC file, so I can flash my ecu?
  7. Jul 24, 2018 at 6:51 PM
    #2907
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    kickoff plans are NA with offroad exhaust, long tube headers & CAI
    i need a little info on i0TECH to get started
    - when will the cable be available or can we buy a generic obdii - usb cable?
    - can we replace the narrow band o2 sensors with wide band sensors and datalog onboard via i0TECH?
    - demo version?
  8. Jul 25, 2018 at 6:10 AM
    #2908
    OVTune
    OVTune
    Tactrix cable works, do not have a demo version right now.
    All file versions listed above are updated and now available
  9. Jul 25, 2018 at 8:33 AM
    #2909
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    @OVTune any ETA yet when us NA owners can buy your product? Thank you
  10. Jul 25, 2018 at 9:16 AM
    #2910
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Ok. Now we're getting somewhere.
    I updated my handheld this morning and plugged it into my truck as I was leaving for work. Instead of the "CALIBRATION FILE NOT FOUND 3YWG2800" message I've been getting for months; It actually did something different! It went kind of quickly and I was in a bit of a rush to get to work. I believe it basically downloaded the existing calibration from the truck ECU to the handheld. Which is cool. Forgive me for not knowing exactly what to do next. But, What do I do next? :notsure: I've haven't gotten this far before. I'm guessing that I need to bring the handheld back inside to the PC and upload the file maybe?
  11. Jul 25, 2018 at 9:23 AM
    #2911
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yessir! Idk if you have the newer style hand held or not, but basically you plug in the hand held, open the ovtune software, and save the files from the hand held to your pc. Then email those to ovtune and he will send you a tune package that you will upload to the hand held.
  12. Jul 25, 2018 at 9:41 AM
    #2912
    OVTune
    OVTune
    Run the software save the file and email it to support@ovtune.zendesk.com
    We will have handhelds back sometime next month after we get caught up and have a smooth process for sending tunes.
  13. Jul 25, 2018 at 2:29 PM
    #2913
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    @OVTune Is there any way to check to see if the handheld is on the latest update? I ran the update twice today, and it still says "Calibration not found 30455000" when trying to connect to the truck, even though it's been updated to the supported ECU list.
  14. Jul 25, 2018 at 5:33 PM
    #2914
    BillDaCat8
    Jake
    PHX
  15. Jul 25, 2018 at 6:26 PM
    #2915
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    After 8 long months, I have successfully read the stock calibration file and emailed it off. @OVTune Thank you for your hard work on this daunting project. Sorry i was not one of the cool kids and took a picture to post. lol! Now time for a celebratory beer. CHEERS!:drunk:
  16. Jul 25, 2018 at 6:31 PM
    #2916
    Brice
    Brice Turbo Member
    Brice
    Texas
    I have also sent in my file :D Hoping all goes well :goingcrazy:
  17. Jul 25, 2018 at 8:31 PM
    #2917
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Was asked on page 145 but will pester and ask again:
    Wondering if there is a way to disable the problematic Secondary Air Injection system on 2012-2015 1GR-FE trucks.
    I'm likely a buyer already, but that would seal the deal.
  18. Jul 26, 2018 at 7:14 AM
    #2918
    OVTune
    OVTune
    Yes it can be disabled
    let me double check this one, was definitely added a while back
    Will add this one in tonight
  19. Jul 26, 2018 at 7:17 AM
    #2919
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Will this delete allow us to remove the air injection? Or must it decorate the engine bay?
  20. Jul 26, 2018 at 7:25 AM
    #2920
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Either way I’d be ok with it. It might be less of a headache to just leave it be.
