Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Sep 28, 2018 at 1:05 PM
    #3501
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I recall emailing a while ago about switching to the flash kit??
    When people link my username in this thread I dont see it, I have 1000+ notifications on this forum it's impossible to keep up with them
  2. Sep 28, 2018 at 1:15 PM
    #3502
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    No you said you would purchase an ecu with my part number on August 10th after I had offered to buy a used one and send it in. Calibration ID # 30473000 Toyota part # 89661-04E30
    *Edit Also emailed you over the last few weeks with no response and I figured you check this thread often.
  3. Sep 29, 2018 at 6:11 PM
    #3503
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I'm about getting to this point too. Unless I'm missing something ECU 30426300 still isn't supported... I wont bother @-ing OVTUne, but I have emailed him multiple times now at the Zendesk thing and no responses. *sigh*
    D-Rose[QUOTED] likes this.
  4. Sep 29, 2018 at 7:47 PM
    #3504
    Bartlett18
    Bartlett18 Well-Known Member
    Edmonton, Alberta, CANADA
    2009 Silver Tacoma ShBx DBLC 4X4
    3"Lift, 285/70/17, OVTune, fog light mod, oil, volt, vacuum gauges, map light mod, RI light bar/pods, Leer 100XQ, bedliner lights, LR UCAs, Rear airlift bags, tinted side windows, XD Revolver rims, colour coded door protectors, 100/90 headlight bulbs and harness, 65 fog bulbs and harness, side splitter mirrors, Bilstein 5100s, OME 887 springs, 4:30 gears, TruTrac, Hurst/Core short shifter, CC grill,
    Thanks for the response! I'm in Edmonton, so not close at all. I've been running Shell 91 zero ethanol since new, so I'll be able to notice the difference, if it makes one, as I know the feel with only 91 and no tune. Having a manual will take away the benefits of the shift point modifications of the tune, obviously. If there is no MPG increase, then that's a wash. So, I guess I'd be paying for a smoother feeling engine and a little more power above 3000 rpm, if I'm reading you right? I, usually, shift at or just under 3000 while driving in the city, so I may not be utilizing the increased power anyways. Hmmmmm, now I'm more conflictedo_O.
    Might just be that the tune is best suited for the "problems" that the auto community has with the truck.
    If anyone else has first hand experience, especially with a manual, that'd be awesome:bananadance:.
    Thanks for the input Brandon:canada:
    Barrett
  5. Sep 30, 2018 at 9:49 AM
    #3505
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    @Bartlett18 I have a manual and the tune. I'm running the 91 tune. The truck does run smoother. It also has way better throttle response. Especially in the low end and off idle. Makes it a lot nicer to drive in town and slow speeds. I feel I can keep it in a higher gear when slowing with out stopping. E.g., I can actually use down to 1500 rpm and in third I can let it drop closer to 1000 rpm and re-accerate. I like that better than the down shift to second. It just seems like a big jump between those 2 years.
    livpool14 likes this.
  6. Sep 30, 2018 at 1:19 PM
    #3506
    Bartlett18
    Hi Russell,
    thanks for that info! That sounds like something that would be beneficial and make driving the truck more enjoyable too. It sounds like the torque has been adjusted to come on sooner? (more usable power sooner and spread across wider RPM's? No more; waiting...waiting...waiting...THERE IT IS!! in the power band?) I am by NO MEANS well versed in mechanical "lingo". Have you noticed any change in MPG? By "better throttle response", do you mean a touchier pedal or the truck gets going quicker then you do use the gas? (less lag).
    Your thoughts are appreciated! I, typically, do a lot of research and question asking when modifying and spending $$$, so this is very helpful.
    Thanks again,
    Barrett:thumbsup:
  7. Sep 30, 2018 at 1:32 PM
    #3507
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    I might need in on this too, calibration ID 30442300 is still not recognized by the handheld. I updated it a few hours ago. I sent an email to the zendesk email.
  8. Sep 30, 2018 at 1:36 PM
    #3508
    rheath08
    Russell
    Bakersfield, CA
    @Bartlett18 for the throttle response I would say it's some of both. To me the bottom end feels more like what it should have from the factory. This is a large v-6 and feels like a engine of half the size below 2500-3000. That my opinion.
    Biscuits, EdinCincinnati and XPOTRPR like this.
  9. Sep 30, 2018 at 5:50 PM
    #3509
    Bartlett18
    Thanks Russ!
    Biscuits likes this.
  10. Sep 30, 2018 at 9:21 PM
    #3510
    Bartlett18
    @OVTune
    or anyone that knows...
    Just wondering if altitude (elevation) is taken into consideration (or needs to be) for this tune?
    What I'm wondering is if each persons experience will be different, based on their elevation and the tunes' reaction to it or if elevation has no effect, or is compensated for, and everyone will have the same results regardless of elevation. It might matter when asking different people from different elevations their experiences with the tune.
    Please be kind.
  11. Sep 30, 2018 at 10:19 PM
    #3511
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  12. Oct 9, 2018 at 7:27 AM
    #3512
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Wake me if this thread ever comes back.
  13. Oct 9, 2018 at 7:38 AM
    #3513
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @OVTune any updates for supercharger V2 handheld tunes?
  14. Oct 9, 2018 at 5:16 PM
    #3514
    Brice
    Brice Turbo Member
    Brice
    Texas
    I'm happy to say that a few days ago Matt got me my tune.
    My initial non-scientific impressions are this:
    3500rpm~ to redline has noticeably more power on the 91 octane tune.
    1000-3400 or so seems like it may be lacking a bit of power however. My 0-60 is still the same and the truck seems to feel more sluggish in that range.
    The transmission seems to shift at more appropriate intervals as well. Overdrive doesn't happen until 30ish mph versus 25mph before. The transmission also shifts at the factory redline now whereas before it shifted a few hundred rpm before hand.
    All in all it seems pretty good.
    I ran the truck hardish for the first half tank of gas and got 18.7mpg. At the moment I'm driving a bit slower in order to compare my previous best mpg (20.1) to the 91 octane tune.
    I haven't tested the 87 octane tune yet.
    Biscuits, XPOTRPR, cdelgado14 and 7 others like this.
  15. Oct 11, 2018 at 1:10 PM
    #3515
    Brice
    Brice Turbo Member
    Brice
    Texas
    MPG update to previous post.
    After 159.0 miles and 8.0 gallons of gas I have achieved 19.8mpg with the tune on.
    I had aimed to hypermile but I was late to class a couple times this week so I definitely think it can get better.
    I'm going to do another mpg focused half-tank of gas then switch to the 87 octane tune and review it as well.
    Note: Half a tank is 10.5 gallons. I refilled at half-ish, but will try to get closer to 10.5 till empty next time.
  16. Oct 11, 2018 at 2:32 PM
    #3516
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What was your prior best?
  17. Oct 11, 2018 at 2:48 PM
    #3517
    Brice
    Brice Turbo Member
    Brice
    Texas
    20.1mpg on the stock tune
  18. Oct 14, 2018 at 11:43 PM
    #3518
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Anyone interested in selling their self tuning software hit me up
    cdelgado14 likes this.
  19. Oct 16, 2018 at 10:58 AM
    #3519
    Lordaca
    Lordaca Well-Known Member
    Melbourne, FL
    TRD SPRT DC LB 4x4
    Weathertech floor liners and wind deflector, OEM roof Rack, Wet Okoles seat covers, cb installed
    I feel OV Tune is focused on the 3rd gen right now and not the 2nd gen. Hopefully, soon they will give more love to the 2nd gen. I want to try this out but I am waiting on more reviews on the 2nd gen. Maybe more options will be given as I would love to learn how to tune, but would want to start with something that was a good baseline.
  20. Oct 16, 2018 at 11:12 AM
    #3520
    dwrecks
    dwrecks Active Member
    Derek
    Oakville, Ontario
    2014 Tacoma Doubl Cab TRD Sport
    Stage 2 Lift Kit XD Monster Rims TRD Exhaust General Grabber At2 Tires
    At before and after DYNO will open my wallet.
    Shadowhunter and Biscuits like this.
