Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Nov 22, 2018 at 9:57 AM
    #3621
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
  2. Nov 22, 2018 at 11:23 AM
    #3622
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Shit man that sucks!! Where are you sourcing a motor from? Just curious. Are you sticking with the same mods?
  3. Nov 22, 2018 at 3:01 PM
    #3623
    GeoScout
    GeoScout Calgary Geo
    Vill
    Calgary, AB
    2015 MGM TRD SPORT 6MT
    MAGNUSON Superchager URD 2.85 Pulley Icon Stage 9 Pelfreybilt Armor AFE INTAKE TRD EXHAUST TRD QUICK SHIFTER Warn Zeon 10S Icon Alloy - Six Speeds Nitto Ridge Grapplers TRD Pro Grill Leer XR Canopy Front Runner Roof racks Treeline Outdoors RTT
    That's interesting since its not what it sounded like from the shop that will be doing it.
    From what I understand is that they Flash the ECU in house with the OVtune. Definitely curious to know more about the process.
  4. Nov 22, 2018 at 5:21 PM
    #3624
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    That's interesting to hear. I wonder if the new flash tuning OvTune offers allows a person to overwrite the BD tune themselves? Unfortunately ov is away for a few days so can't answer questions.
    General consensus among the supercharged crowd here is the TRD tune, while often pig rich, is the safest and most reliable tune thus far. People are still waiting for proper tunes from ov and the urd ucon is hit and miss for some people and requires a stock, virgin ecu to work properly.
    Is KRave dyno tuning?
    JuanitoBonito likes this.
  5. Nov 25, 2018 at 5:04 AM
    #3625
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    I've had the handheld since February this year. I uploaded the 91 tune for The Supercharged version and I am still seeing at wide open throttle in the high nines still running super rich
    Norton and Hacktacular like this.
  6. Nov 25, 2018 at 5:48 AM
    #3626
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Have you done any data logging to see what is being commanded vs actual?
  7. Nov 25, 2018 at 6:43 AM
    #3627
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Are you seeing that AFR throughout a pull, or only as you approach the limit and during shifting?
  8. Nov 25, 2018 at 7:03 AM
    #3628
    ThomasMore66
    Dallas/Fort Worth & Durango
    FPR modded? What pulley?
    TodayWasTHeDaY likes this.
  9. Nov 25, 2018 at 7:29 AM
    #3629
    TodayWasTHeDaY
    Russ
    Calgary
    Hey @OVTune, does your flash tuning software allow a person to overwrite the bully dog tune yourself or is it still a send the ecu in to you to fix type of thing still?
  10. Nov 25, 2018 at 9:34 AM
    #3630
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Any update on Supercharged V2 Calibrations?
  11. Nov 25, 2018 at 9:46 AM
    #3631
    TodayWasTHeDaY
    Russ
    Calgary
    Bump and lol
  12. Nov 25, 2018 at 10:02 AM
    #3632
    OVTune
    OVTune
    Once we have all of them ready we will send them. Not sure what else could be said, if we haven't sent it then it's not ready to send to everyone.
    henryp and JWL like this.
  13. Nov 25, 2018 at 10:06 AM
    #3633
    TodayWasTHeDaY
    Russ
    Calgary
    Bump
  14. Nov 25, 2018 at 10:15 AM
    #3634
    OVTune
    OVTune
    Yes the bulldog tune can be overwritten
    GeoScout likes this.
  15. Nov 25, 2018 at 10:49 AM
    #3635
    Norton
    It's about customer service and managing expectations. You first mentioned V2 cals over four months ago. Multiple commitments to get them out have come and gone. The only updates we receive come in response to our inquiries. To be clear, Mat, many of us are happy with the magic you've worked with our ECUs. I'm sorry if it seems harsh, but we're just looking for proactive updates and realistic timelines, especially when it comes to commitments made last summer.
  16. Nov 25, 2018 at 10:56 AM
    #3636
    TodayWasTHeDaY
    Russ
    Calgary
    If I can overwrite myself with the flash tuning software then you may have just made a sale. Trucks my daily driver so I can't just send my ecu in.
  17. Nov 25, 2018 at 4:20 PM
    #3637
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Hmmmm @OVTune is a 1grfe tuner able to be used on a 07 scion? My new commuter might be up that alley while I figure out a replacement motor for the Tacoma....
  18. Nov 25, 2018 at 5:21 PM
    #3638
    OVTune
    OVTune
    I understand and we are trying. When we first started the 4.0L tuning it was around the same time, or shortly after the 3.5 3rd gen. We had no idea just how much of a mess the 3rd gen is, it has taken up nearly all of my time and Rafael is working over time to get every else sorted as quickly as possible. We absolutely will have a v2 calibration out for all SC trucks, and it does not stop there. There are so many things we can do with the 4.0L platform, we just don't have the man power right now.
    We still want a 2006 - 2007 truck for development but good condition ones of that year are difficult to find, or highly modified.
  19. Nov 25, 2018 at 5:25 PM
    #3639
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I've got one with a hole in the block.... $6k and it's yours. :D
  20. Nov 25, 2018 at 5:26 PM
    #3640
    OVTune
    OVTune
    otherwise stock everything else? is it for sale. Also you're on the other side of America
    Depends what scion
