Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Dec 9, 2018 at 6:07 AM
    #3721
    NLMOOmar
    NLMOOmar Well-Known Member
    13 DCSB TRD OFFROAD SC
    Shrockwork Sliders, ICON (C/0, Tube UCA and 2.0 Rear), Dakars, US OFFROAD winch mount bumper. 2014 Nav Radio, SOS rear bumper and shackle flip, Pelfreybilt Skids. BAMF Bar mount and CMC, SCS-F5, Magnuson SC
    Do a search on (Pig or pig rich) in this thread plenty of examples mostly a function of system going open loop, the positive thing is the OV tune is incrementally making the recovery from open loop a little faster as the version progress. I started with the BullyDog tune that was part of the Magnuson SC group buy, installing that tune into my 2013 4x4 OR ECU was a fatal error for my particular case it ran like crap had knock, crazy shift points just overall awful, and at the time a reflash to the TRD tune was not within easy reach so I eventually found myself with the OV Tune which dramatically made the truck drivable again.
  2. Dec 9, 2018 at 6:08 AM
    #3722
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    @OVTune, can you clarify for me...
    I have one of the first 25 or so handhelds for my NA 4.0 running the 91 tune. Is this handheld going to still provide me future tune improvements or do I need to restore the Toyota tune and buy your new software and cable to be able to tune my truck going forward by myself? I only want simple, plug and play solutions.
    There’s so much info and back and forth details in this thread now, it’s hard to keep things straight.
    Thanks.
    JuanitoBonito likes this.
  3. Dec 9, 2018 at 6:22 AM
    #3723
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Updates that we create will be available for both the handheld and the flash software
  4. Dec 9, 2018 at 6:25 AM
    #3724
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    Even in open loop you shouldn't be running anywhere near that rich boosted or otherwise
  5. Dec 9, 2018 at 6:27 AM
    #3725
    OVTune
    OVTune
    10.5 AFR with boost and a higher amount of advance is just fine.
    The leaner you go with boost the more heat and the more ignition you have to pull out.
    These engines make power with ignition, you will make more power with more ignition and richer AFR than you will with less ignition and leaner AFR. Considering that with boost you should see be under 12.0 AFR generally.
    Lets say you tune it like a traditional low psi supercharger.. AFR *around* 12.0 12.2... well I've tried and the engine knocks a LOT. you have to remove a lot of advance and end up with less power than a TRD tune.
  6. Dec 9, 2018 at 6:49 AM
    #3726
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I'm just spitballing here but, it may be so rich that with any internal deficiencies of the engine, IE worn rings or shitty injectors the amount of fuel intro
    Are you still planning to produce custom tunes tailored to user supplied data logs?
  7. Dec 9, 2018 at 1:27 PM
    #3727
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    So, run it fatter and keep the timing. Shoot for say, 11.5-ish AFR for boosted trucks then? Or richer?
  8. Dec 9, 2018 at 4:12 PM
    #3728
    dipstiktaco
    canada
    Spiking to 8.5 the coming up to 10 is way too rich I don't care what kind of engine or combustion chamber design you have. It should spike to 10.5 then settle at 11
  9. Dec 9, 2018 at 4:56 PM
    #3729
    OVTune
    OVTune
    The sudden rich spike isn't from tuning it's from how this ECUs fuel control is. There is only so much that can be done, the ECU is not at all setup like a normal forced induction ecu should be. It relies on a pretty on really basic fuel concepts.
    When the ECU reaches those switching points it will change to power demand / power equiv ratio and it's unmetered, the ECU does not take any feedback at that point.
    Same reason these trucks will be rich when shifting,
  10. Dec 10, 2018 at 5:43 AM
    #3730
    BillDaCat8
    Jake
    PHX
    So, these switching points you mention. Can we play with where these happen ?
    I am having an issue where I’m running lean at partial throttle acceleration. Say, 40-60% throttle accelerating in 4th gear. Boost goes to like 4-5 psi. AFR is staying lean in the mid 14’s and I hear knock.
    Now, if I really mash on the gas pedal and get it over what I’m assuming you’re referring to as “switching point” it fattens up. But, that’s not really conducive to smooth driving.
  11. Dec 10, 2018 at 5:55 AM
    #3731
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    @OVTune Is it possible to get an aftermarket ecu that can be programmed to overcome these limitations and operate like a normal forced induction ecu. If you can program it or provide a better ecu to work with these trucks there is a lot of us that would be on board.
    The capabilities to better adapt to bigger injectors, methanol injection, rev hang, air injection deletion, etc, would be awesome.
  12. Dec 10, 2018 at 6:49 AM
    #3732
    OVTune
    OVTune
    Everything, the switches and otherwise can be adjusted in the stock ECU. The stock ECU is a better idea for most trucks because it communicates with the entire truck. A standalone is a serious job and not really ideal for a daily vehicle.
    Everything can be adjusted. The sucky part is that the ECU is load based but relies almost completely on adjusting by : Accelerator / throttle position / MAF air load / closed or open loop. But it's not impossible to tune perfectly. We really just got to get our own R&D truck to play with all the little settings.
    Biscuits, RedLantern, Norton and 2 others like this.
  13. Dec 10, 2018 at 7:00 AM
    #3733
    TodayWasTHeDaY
    Russ
    Calgary
    Awesome, thanks for the response and can't wait for awesome tunes! My kit should be arriving in the mail tomorrow so I'm very excited to get set up soon.
    BassAckwards likes this.
  14. Dec 11, 2018 at 3:40 PM
    #3734
    Yoeveryone23
    Yoeveryone23 New Member
    David
    2012 X Runner W/supercharger
    No, FL. I found another shop who had the licensing for my ECU already and was willing to set me up for $400. Appointment is set for next week!
  15. Dec 11, 2018 at 6:19 PM
    #3735
    dipstiktaco
    canada
    How can a full standa
    How can a full standalone not be a good option for a street vehicle? Once you're past a certain point the stock ecu is your limiting factor and can be detrimental to your drivetrain if you're not careful. A standalone is fully adjustable usually on the fly so you can make adjustments much easier which makes drivability much improved. Haltech, aem, motec etc all have ecus that would fully integrate to our trucks no problem. Just search Ekanoo racing to see what's possible with a 1gr with a standalone.
  16. Dec 11, 2018 at 6:21 PM
    #3736
    dipstiktaco
    canada
    And with a standalone you can ditch the MAF and switch to a map based tune which is way more boost friendly.
  17. Dec 12, 2018 at 6:04 AM
    #3737
    OVTune
    OVTune
    Anyhting is possible with a standalone. What I mean is that for a majority of people it's not ideal because unless there is a plug and play standalone you have to wire it in, calibrate sensors, etc and have a full dyno tune. I've tuned many standalones and in my opinion unless there is a plug and play that connects to stock harness ( I have not looked for this truck, there might be) with a starting calibration by the manufacture of the standalone, then rarely is it as good as a stock ECU in terms of overall driving. What I mean is cold start, hot start, cruise, etc etc. All the *little* things the stock ECU is perfectly designed to do.
    now if you want to make big power, or easier power yes standalone for sure is the best solution.
    RacecarGuy and TodayWasTHeDaY like this.
  18. Dec 12, 2018 at 11:54 AM
    #3738
    dipstiktaco
    canada
    Most people whom are pushing big ppwer would have no issue spending some more money on a proper fully programmable ecu ro bettee control that power. Yes there are several companies that make patch harnesses for different ecus for our trucks it's just a matter of buying them.
    TodayWasTHeDaY likes this.
  19. Dec 14, 2018 at 8:16 AM
    #3739
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Any update on V2 Calibration for 6MTs?
  20. Dec 14, 2018 at 9:37 AM
    #3740
    OVTune
    OVTune
    Working on it. All these changes for 2019 and holiday orders have us going as quick as we can.
    MT V2 will have adjustments to throttle, airflow demand, and a few other tables.
    Speaking of that I do have some questions for SC owners for some developments for next year. Once we get our full blog post out for 3rd gens major transmission / tune update out today I'll post about that.
    JacksonTacoma and Norton[QUOTED] like this.
