Tacoma ECU Tuning for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OVTune, Jun 14, 2017.
  1. Sep 15, 2017 at 2:05 PM
    #361
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    you mean so that you can tune multiple trucks?
    PapaBear likes this.
  2. Sep 15, 2017 at 3:07 PM
    #362
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Correct
  3. Sep 15, 2017 at 3:35 PM
    #363
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Awaiting more info...
  4. Sep 15, 2017 at 4:20 PM
    #364
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    This is exciting... I'm game for a preset tuner!
  5. Sep 15, 2017 at 4:20 PM
    #365
    Justinlhc
    Justinlhc Not looking for a relationship
    I'd say the "majority" don't have the knowledge or equipment to self tune(effectively).
    I'm interested, but being N/A I'd need to see specific options since I have very little to gain. If I could disable the injector cut-off when coasting downhill I'd be all over it. :bananadance:
  6. Sep 15, 2017 at 4:21 PM
    #366
    Lord Helmet
    Nick
    '24 X3 M40i
    Anything for a 5th gen 4Runner? :D
  7. Sep 15, 2017 at 4:22 PM
    #367
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Why would you want to do that?
  8. Sep 15, 2017 at 4:25 PM
    #368
    Justinlhc
    It's annoying as hell to have to step on the gas when coasting downhill in order to keep speed. It also makes no sense to me to prevent the vehicle from maintaining speed when traveling downhill. It's like the brakes are applied when going downhill. It's a common complaint on the Tacoma. Is this the first you've heard about it?
  9. Sep 15, 2017 at 5:09 PM
    #369
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Is yours an auto?
    It is a normal tuning strategy to have a fuel cut for "X" amount of time after the throttle pedal has been lifted. Decel Fuel Cut. Then it should go back to closed loop fueling.
  10. Sep 15, 2017 at 5:19 PM
    #370
    Justinlhc
    Yes, auto.
    It seems counterproductive to make me press the gas pedal to maintain speed when coasting downhill. I know I'm not alone because I've read several complaints about it over the years.
  11. Sep 15, 2017 at 5:43 PM
    #371
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    Ok every vehicle with obd2 does this and it's for good reasons.
    All you're going to do is burn more fuel. The amount of engine braking when your throttle is closed isn't going to change if you turn off the decel fuel cut. What you are feeling is aerodynamic and mechanical drag from the truck itself. My buddies 2015 f150 has way more coasting decel than my Tacoma does and I'm on larger tires. If you want to maintain speed going downhill then guess What, just like on level ground you have to apply throttle. It's physics.
    Lord Helmet and Torspd like this.
  12. Sep 15, 2017 at 5:43 PM
    #372
    Justinlhc
    Every vehicle with obd2 does this? o_O
    Norton likes this.
  13. Sep 15, 2017 at 5:46 PM
    #373
    dipstiktaco
    canada
    Yes it's called decel fuel cut. Shuts off the injectors and uses the transmission too keep the engine turning to save fuel. Guys who switch it off are the ricers who want to spit flames when they let off lol
    Lord Helmet likes this.
  14. Sep 15, 2017 at 5:46 PM
    #374
    dipstiktaco
    canada
    Even my 1994 ford ranger did it.
  15. Sep 15, 2017 at 5:48 PM
    #375
    Justinlhc
    No, not all OBD2 ecm's use this feature and no, I am not trying to shoot flames out of my exhaust. Wtf.
    Norton likes this.
  16. Sep 15, 2017 at 5:49 PM
    #376
    dipstiktaco
    canada
    Name me ones that don't please.
  17. Sep 15, 2017 at 5:50 PM
    #377
    Justinlhc
    Are you being serious? o_O
    Norton likes this.
  18. Sep 15, 2017 at 5:50 PM
    #378
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    I would want hand held unit with pre-set Tunes please
  19. Sep 15, 2017 at 5:51 PM
    #379
    dipstiktaco
    canada
    100% I've worked on many different makes and I've never come across an obd2 vehicle that didn't use decel fuel cut.
  20. Sep 15, 2017 at 5:53 PM
    #380
    dipstiktaco
    canada
    Hell my 2012 brz with a full motec standalone has decel fuel cut
